ASK Air flow & Map sensor
  • Short URL:  http://modifika.si/15291
    1 Wk 4 Hrs 35 Mins 23 Secs
    mau nanya nih, Air flow & Map sensor itu sama gak ? gunanya buat apa ?
    bandung-papua
    4 Hrs 6 Mins 1 Sec
    beda....
    tp gw tau ngejelasin detilnya...
    hehehehehehehehehe........
    6 Hrs 11 Mins 41 Secs
    Air flow contoh di MITSU engine bagian deket air filter
    MAP sensor deket TB (SKEP) contoh di Aerio, Swift etc.
    Aerio_standard
    Syd - Australia EGK24A 11.73sec @113.17mph , 1.64 60ft
    49 Mins 58 Secs
    Manifold Absolute Pressure sensor
    a variable resistor used to monitor the difference in pressure between the intake manifold at outside atmosphere.
    This information is used by the ECU ( electronic control unit ) to monitor engine load (vacuum drops when the engine is under load or at WOT wide open throttle). When the engine is under load, the ECU may alter spark timing and the fuel mixture to improve performance and emissions.
    www.jdmyard.com
    EGK24A 11.73@113mph
GT Radial NGK Busi
  1. WTB:Air Flow Sensor Suzuki Escudo 2.0
    By nanangsurya in forum Jual Beli Mesin Lainnya
    Last Post: 7th April 2011, 17:41
  2. [WTB] cari air flow sensor mitsubishi eterna gti
    By sirpsycho in forum Jual Beli Mesin Lainnya
    Last Post: 13th March 2011, 01:15
  3. [JUAL] Air Flow Sensor Mitsubishi Eterna
    By arie_kickass in forum Jual Beli Mesin Lainnya
    Last Post: 3rd January 2011, 15:42
  4. Air mass / Air flow Sensor untuk BMW 320i E36
    By alvinwij in forum Jual Beli Mesin Lainnya
    Last Post: 3rd August 2010, 15:52
  5. ada yang tau tempat betulin AIR FLOW SENSOR??
    By dejan400 in forum Diskusi Mesin
    Last Post: 5th February 2009, 22:29
