Upgrade Ur Braking System
Results 1 to 10 of 38
  • Short URL:  http://modifika.si/152391
    Phone: 08179845168 - Klender Jakarta
    4 Days 23 Hrs 46 Mins 8 Secs
    Run Stop Brake Rotor
    When stopping is the only thing that matters
    The most elegant street brake-rotors on the market that combines out-standing performance with aggressive and purposeful appearance.
    Each Rotor is analyzed for its specific application, vane structure, and construction to determine the ideal and optimum design and pattern.
    The Drill and Slot Patterns and designed using a 3D CAD system to insure all the design specifications are achieved. The programmed patterns are the run on several CNC machines.
    Runstop Advantages
    The bore holes reduce mass, radiate break temperatures, and help battle “out-gassing” or “de-gassing”
    The special slots, which are non-directional and designed to work in combination with the cross-drilling, help dissipate water, dirt and dust, and further combat “cut-gassing” or “de-gassing”
    Slot deglazes the pads, ensuring improved contact between pad and rotor. In combination, the cross drilling and slotting functions give more stopping power and less fade during repeated heavy break application.
    The Cross-drilled or Slotted rotors improves convection heat transfer, thereby lowering brake temperature.
    40% better cooling, 20%-30% better stopping, and improved wet bracking compared to standard OEM rotors.
    Runstop Rotors are engineered to keep the temperature of your brakes cool, which improves pad bite and reduces brake side. This will enhance brake performance.
    Ready Stock:
    Honda Civic Ferio - Front + Rear
    Honda Civic VTI - Front + Rear
    Honda Civic FD1 - Front + Rear
    Honda Jazz - Front
    Honda City - Front
    Toyota Soluna - Front
    Toyota Yaris - Front
    Toyota Yaris - Rear (yang bawaan mobil sudah rear disc brake)
    Toyota Avanza - Front
    Toyota Vios - Front
    Tertarik, silakan hubungi saya, di nomor telpon di bawah atau post di thread ini atau PM juga boleh kok...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    1 Wk 2 Days 2 Hrs 47 Mins 40 Secs
    Bos accord 2002 ada bos?
    Quote Originally Posted by pret View Post
    Sorry bos blom ada...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Solo-Jogja
    2 Days 3 Hrs 57 Mins 51 Secs
    manteb jualannya nih Hydra Performance...bantuin upp :smt020
    Quote Originally Posted by krezzie View Post
    Thanks ya Paaakkk...
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    depok-binus
    2 Wks 5 Hrs 31 Mins 37 Secs
    bos, yg buat vios brp yg dpn? klo buat yg blakang ga ada yah? apa bisa pake pny yaris? Thx.
    Jalan Panjang, West Side
    4 Days 2 Hrs 28 Mins 5 Secs
    Quote Originally Posted by Hydra Performance View Post
    Runstop Advantages
    Ready Stock:
    Honda Jazz - Front
    Honda City - Front
    Toyota Vios - Front
    Thanks,
    Bro.. kalau buat fortuner ada? kena berapa dan dapat apa saja? thx
    13 Hrs 26 Mins 53 Secs
    Buat Swift ada bos?
    Tx
    Quote Originally Posted by Widisti View Post
    Buat Swift ada bos?
    Tx
    Untuk saat ini belom ada yang langsung plug and play ke swift sih yaaa...
    Kalo mau brake kit masih ada merk wilwood (6pot) seken...
    Kabar2in aja deh yaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    2 Wks 3 Days 10 Hrs 28 Mins 25 Secs
    sy cari buat volvo 960 (depan) ada, klo yg avanza depan kena berapa ya?
Mega Glodok Kemayoran MBtech
  1. upgrade exhaust system
    By niel9090 in forum Diskusi Knalpot
    Last Post: 31st January 2011, 23:35
  2. Ask system...mo upgrade
    By frostbitez in forum UnSCAC- Hwely Audio
    Last Post: 26th April 2009, 10:42
  3. Upgrade system... Mohon pencerahan
    By h.tommy in forum Diskusi Instalasi
    Last Post: 8th May 2006, 17:49
