HUSTLER AR 75.2 tube amplifier (sold,thanks modcom...)
Results 1 to 10 of 56
  • Short URL:  http://modifika.si/152339
    Cool HUSTLER AR 75.2 tube amplifier (sold,thanks modcom...)
    HUSTLER AR 75.2 tube amplifier kondisi muluuuuus,lengkap dus,buku n segel.....sold
    The Hustler amplifier distinguish itself world-wide as they have been engineered after much research and study of the world�s top notch hybrid amplifiers, their �strengths� and particularly their �weaknesses�, thus, producing a product line of the highest performance level. With matched 6N9P Twin Triodes tubes applied, Hustler Audio�s Hybrid amplifier has a warm golden tonality designed as a top-range, hi-fi systems, output stage amplifier where sound quality is indeed the primary objective. The components have been upgraded as its sound effect is coupled with a felt vibe of the music, courtesy of its prominently researched, new age technology and are currently available together now in the new Blockbuster: The AR 75.2
    Features
    Open Ended Audiophile Circuitry
    Zero negative feedback
    Regulated Tube Heaters with 15sec Delayed Soft Start
    6N9P Twin Triode tubes
    Warm, musical and dynamic
    Regulated Mosfet Power Supply
    Short Circuit Protection Circuitry
    Dual Color indicative LED: Green=Normal / Red=Fault
    Specifications
    Rated Power (All channels driven)
    Rated Power (all channels driven):
    - 2 x 75 Watts RMS per channel @ 4 ohms
    - 1 x 300 Watts RMS Bridged (Mono) @ 4 ohms
    2-Ohm Stereo, 4-Ohm Mono Stable
    Freq response: 5Hz to 50kHz (+/- 1dB)
    THD: <0.16% (30kHz bandwidth)
    S/N Ratio: >110dB (A-Weighted)
    Idling Current: 1.7 Amps
    Input Sensitivity: .450v - 12v RMS
    Fuses: 1�30A ATC
    Dimensions: 310 L x 240 W x 80 D (mm)
    Weight: 8 Lbs.
    call
    081388575788
    Wah, dulu pengen barang ini chris.. Angkat aja chris, mulus abis neh..
    thanks ya nal......
    up...............
    up..................
    up.......................
    up............
    up.............
  1. Jual: 1 Power Amplifier Hybrid Tube Hustler AR 75.2
    By d3cibel in forum Power Amplifier
    Last Post: 23rd May 2013, 13:16
  2. Replies: 78
    Last Post: 19th March 2010, 23:41
  3. Replies: 20
    Last Post: 9th September 2009, 07:08
