Focal 6.5" PolyKevlar Power Components 165K2P UV (sold,thanks modcom....)
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/151317
    Cool Focal 6.5" PolyKevlar Power Components 165K2P UV (sold,thanks modcom....)
    165K2P UV (Upgraded Version) - Focal 6.5" PolyKevlar Power Components kondisi muluuus,lengkap dus buku........sold
    focal k2 6,5 inch price list :
    165K2P UV (Upgraded version) $1,199.99
    165K2P $999.99
    165KP $949.99
    165KF $649.99
    165KPS UV (Upgradaed Version) $899.99
    165KR $729.99
    165KR2 $949.99
    165KRX2 $1,099.99
    Description:
    Developed to allow you to reach the very top levels of acoustic resolution and sound pressure, the K2 Power range symbolises Focal's expertise. Combining an evocative mix of pure sound control with detail and dynamics, speed and sophistication; the "Power Hi-Fi" concept developed by Focal has all the hallmarks of a reference quality range
    The Tioxid 5 inverted dome tweeter combines smoothness and precision without directivity, optimizing imaging and producing an astonishingly broad and realistic soundstage. This key component, tooo often neglected, makes the difference between a good and an excellent installation.
    Another element essential to Focal's reputation for creating the very highest quality sound, are the woofers and subwoofers from this range. They combine very high power handling and an extremely detailed sound thanks to the exceptional rigidity of the K2's composite sandwich cone technology.
    And because precision, impact, and the culture of car audio define "the Spirit of Sound", our common passion will always make the difference.
    Tioxid 5 Inverted Dome Tweeter:
    Unsurpassed dynamic performance is the basis for the excellent staging derived from this technology. Staging even reaches surgical accuracy on KP series thanks to the TN-52 wave guide. A 5 micron Tioxid surface coating cancels all metallic colorations, while the double-magnet "push-pull" structure generates an important magnetic Flux in the air gap.
    Composite Sandwich Cone Woofer:
    This cone structure features a thermoformed, structural foam central core, coated with an Aramid fiber layer on the front side and a glass later directly derived from the Utopia series, on the back side. This hybrid technology significantly improves membrane rigidity without raising the weight. Long coil, distortion free even at high level.
    Crossover:
    K2 Power crossovers are equipped with the leading performance audiophile components, therefore following Focal's long standing high standards. Aluminized Polyprolylene capacitors provide very high definition alongside the air core inductors which offer great dynamics. For optimal integration, KP series kits are equipped with a tweeter level control switch (0/-7dB, 1dB per action) and midrange position matching.
    Specifications:
    # Nominal power: 100 Watts
    # Maximum power: 200 Watts
    # Sensitivity: 92.5 DB
    # Cone: K2 Composite Sandwich
    # Surround: Butyl
    # Impedance: 4 Ohms
    # Xmax: 4.5mm
    # Mounting depth: 3.03" (77 mm)
    # Fs: 68.88 Hz
    # Frequency response: 65 Hz - 22 kHz
    # 100mm (4") magnets
    # 45mm (1 3/4") Tweeters
    # Speaker Grilles Included Tweeters
    call
    081388575788
  2. Hokinusa
    up.....................
    klaten
    bantu angkat buat speaker mantab....
    1 Day 13 Hrs 13 Mins 38 Secs
    skg dollar tuh brp yah??
    hehehe
    wah,kurang jelas sich bos pastinya,harus tanya money changer nich,he..he..he...
    up...............
    u.p................
  1. ((((( WTS:2WAY FOCAL POLYKEVLAR 6" )))))
    By mr.naim in forum Speaker - SubWoofer
    Last Post: 3rd August 2011, 21:09
  2. Replies: 46
    Last Post: 26th January 2010, 15:35
  3. Replies: 32
    Last Post: 23rd December 2009, 05:01
  4. 3 way focal polykevlar 165k3 muluuuus.......(sold,thanks modcom....)
    Last Post: 10th August 2009, 00:42
  5. Replies: 68
    Last Post: 9th August 2009, 19:35
