High-end "Top of the line" McIntosh MX-5000 kondisi muluuus....(sold,thanks modcom..)
Results 1 to 10 of 27
  • Short URL:  http://modifika.si/150585
    Cool High-end "Top of the line" McIntosh MX-5000 kondisi muluuus....(sold,thanks modcom..)
    High-end "Top of the line" McIntosh MX-5000 kondisi muluuus...............sold
    new price : 2700 €
    The MX5000 is a reference control center, providing traditional volume and balance functions as well as full
    changer controls. The MX5000 brings the instant look of class, as well as familiar toucheslike the rotary volume control and analog bass/treble controls
    AM/FM Tuner, CD, *HDCD 24 bit, Burr Brown Convertor
    *HDCD – High Definition Compatible Digital
    The traditional McIntosh standards of excellence in the MX5000 audio control center. It is an elegant instrument that allows enjoyment of outstanding music reproduction and includes a wide range convenience operating functions to enhance your listening experience. The McIntosh Sound is “The Sound of the Music Itself
    HDCD® Decoder with 24 Bit 8 Times Over-Sampling Digital Filter
    The MX5000 is equipped with a powerful 24 Bit digital signal processor. This digital signal processor can provide automatic HDCD decoding and 8 times over sampling digital filter function for both CD and HDCD. The HDCD decoder provides a wider dynamic range when the HDCD disc is used.
    HDCD® Indicator
    The MX5000 is equipped with a HDCD Indicator. The indicator will be lit when the HDCD Digital Audio Signal is present at input
    Selected Grade 24 Bit Digital-to-Analog Converter
    The MX5000 is equipped with a selected grade 24 Bit Digital-to-Analog Converter per channel. This advanced Digital-to-Analog Converter can provide low-distortion, low-noise and high fidelity sound.
    Performance Features :
    Gold Plated Terminals
    McIntosh provides gold plated input and output terminals on the MX5000 for superior corrosion resistance.
    HDCD Circuitry with Indicator
    Centralized Control System
    FM Diversity Circuit
    Automatic Loudness Circuit
    DC/DC Converter
    Digital Coaxial Input/Out
    Ground Isolation Input Circuit
    MX Power Guard
    Golden Plated Connectors
    External CD Multi-Disc Player (The MX5000 has provisions for the connection and operation of an external CD Multi-Disc Player MCD5000)
    Specifications
    FM
    Useable Sensitivity: 9dBf with is 0.8 V across 75 ohms
    Signal to Noise Ratio: 70dB (IHF-A0
    Frequency Response +3, -3dB from 30 to 15,000 Hz
    AM
    Sensitivity: 28dBf
    Signal to Noise Ratio: 50dB at 100% modulation
    Frequency Response: +0, -15dB 30Hz to 4kHz
    CD
    Frequency Response: +- 5dB 5 Hz to 20,000 Hz
    Signal to Noise Ratio: 100dB (EIAJ)
    Audio
    Rated Output: 3.0Vrms
    Output Impedance: 47 ohms
    AUX input sensitivity: 700mV for high setting, 1,400mV for low setting
    AUX input
    Digital Decoding
    call
    0813885757888
    2 Days 13 Hrs 1 Min 59 Secs
    mantap bener dagangan nya, buruan mcintosh lover, rare nih.
    thanks ya bos nelson.........
    2 Hrs 16 Secs
    keren......
    thank you bos jeam..........
    up..................
    PangkaL Paha
    2 Wks 5 Days 7 Hrs 1 Min 33 Secs
    barang sadis nih
    thank you juga nich bang kane..........
    1 Wk 3 Days 15 Hrs 55 Mins 7 Secs
    Waahhh.... yang ditunggu2..... akhirnya nongol juga nih cris
    iya nich win,baru nongol nich,he..he...he....
MBtech Mega Glodok Kemayoran
  1. Replies: 22
    Last Post: 6th January 2010, 06:34
  2. Replies: 13
    Last Post: 23rd December 2009, 04:05
