Ultra high-end SEAS EXCEL CRESCENDO (sold,thanks modcom....)
Results 1 to 10 of 31
  • Short URL:  http://modifika.si/150191
    Cool Ultra high-end SEAS EXCEL CRESCENDO (sold,thanks modcom....)
    Hi-end SEAS EXCEL CRESCENDO .....sold
    SEAS Excel T29CF-002 (E0040) Crescendo fabric Dome
    The T29CF002, ”CRESCENDO” is an Ultra High End 29mm soft dome tweeter with a
    HEXADYM magnet system.
    An optimally shaped dome and integrated wide surround manufactured by SEAS
    from SONOMEX ensure excellent performance and consistency.
    A high efficiency HEXADYM magnet system (US Patent 6020805) based on 6
    radially magnetized NdFeB magnet blocks provide efficient ventilation and damping
    of cavities behind the dome, surround and voice coil. Moderate magnetic stray fields
    represent no problems in AV installations.
    A generously underhung voice coil with flexible lead-out wires, ensures low
    distortion even with low crossover frequencies.
    A 6mm precision machined aluminium front plate with moderate horn loading
    ensures linear frequency response and reasonable efficiency.
    The central part of the horn is made from chrome plated precision machined brass.
    A substantial injection moulded rear chamber made from zinc eliminates unwanted
    chamber wall resonances and conducts heat away from the magnet system.
    The rear chamber and the front plate are Nextel painted to obtain a durable and attractive
    finish.
    Outside diameter 110.3mm
    Cut out 75mm
    Depth 37.5mm
    25.4mm = 1" = 2.54cm
    SEAS Excel W18NX-001 (E0042) Nextel Cone 7" Woofer
    An adaptive rubber surround provides an ideal match to the cone over the total frequency range.
    A paper cone with a unique Nextel coating ensures smooth frequency response and low distortion.
    A large magnet system with bumped back plate, together with a very long and light weight CCAW voice coil allow extreme coil excursion with low distortion and excellent transient response.
    Heavy copper rings mounted above and below the T-shaped pole piece reduce non linear and modulation distortion and increase overload margin.
    Extremely stiff and stable injection moulded metal basket keeps the critical components in perfect alignment.
    Large windows in the basket both above and below the spider reduce sound reflexion, air flow noise and cavity resonance to a minimum.
    Suggested Box Alignments:
    Sealed box of 7 liters (0.3cf); f3 80Hz
    Vented B4 Alignment of 14 liters (0.5cf); 2" diameter port 6" long; f3 50Hz
    call
    081388575788
  2. 36Goal.com
    Serem chris..
    Pertamaxin ajahhhh..
    mending diborong ke pulau dewata aja bro rinal....,he..he...he.....
    PangkaL Paha
    2 Wks 4 Days 22 Hrs 15 Mins 42 Secs
    ini bukannya uda laku chris ? ada lagi ya
    15 Hrs 23 Mins 26 Secs
    up...........
    10 Hrs 15 Secs
    bantu up buat bosss chrisssssssssssssssss.....
    thanks ya bos harold....
    btw kalau sempat contact2 aja ya bos......
    iya nich bang,dateng lagi nich yang baru,he..he..he...
    thanks ya bos rin........
    thanks juga ya bos harold...
    5 Days 8 Hrs 47 Mins 5 Secs
    banyak amat barang seremnya bos ini...
    ngga koq bos,cuma kebetulan aja dapetnya ....................
Mitsubishi Venom 300x250
  1. WTS: Seas Excel & Sub Crescendo
    By n0k14 in forum Speaker - SubWoofer
    Last Post: 15th November 2012, 10:51
  2. Replies: 24
    Last Post: 23rd May 2010, 03:21
  3. Replies: 8
    Last Post: 27th October 2009, 05:18
  4. seas excel millenium midbass w18ex-001 (sold,thanks modcom....)
    Last Post: 19th October 2009, 04:07
