CLARION DXZ676USB kondisi muluuuus n segel clarindo.(sold,thanks modcom..)
Results 1 to 10 of 19
  • Short URL:  http://modifika.si/150015
    Cool CLARION DXZ676USB kondisi muluuuus n segel clarindo.(sold,thanks modcom..)
    CLARION DXZ676USB kondisi muluuuus n segel clarindo.......sold
    Digital sound has never sounded so good. With Clarion’s Sound Restorer signal processing and a unit 24-bit DAC - the result is music so pure, so detailed, it will be like it’s the first time you’ve heard it.
    Experience your music like never before
    * CD-R/RW ready
    * MP3, WMA and iTunes® AAC compatible with ID3-TAG display
    * Rear USB connector
    * Maximum track capacity: 65,025 (255 tracks in 255 folders)
    * 18 FM, 6 AM station presets
    * iPod® control capability via optional EA1276
    * Subwoofer volume control
    * 24-bit D/A converter
    * Sound Restorer
    * Digital ZEnhancer sound customisation
    * 2-band parametric equaliser
    * MAGNA BASS EX dynamic bass enhancement
    * Built-in High-pass filter & Low-pass filter
    * 4-channel × 53 watts of MOS-FET amplification
    * Motorised sloping console
    * Full dot display with Screensavers
    * "SLIDETRAK" for dynamic operation
    * Cellurer input and phone mute
    * Auxiliary Input with level control
    * 6-volt/6-channel audio pre-out
    * CeNET Control of: DVD changer, TV tuner, 6-disc CD changer, and iPod
    * AUX Bluetooth transceiver BLT370 ready
    * OEM steering wheel remote wired interface capability
    * Detachable control panel
    24-Bit D/A Converter
    Conventional D/A Converters just can’t compare to Clarion’s 24-Bit DAC with Noise Shaper. The result of years of engineering, this new D/A features a 24- bit D/A Converter combined with incredible 128x over sampling to realise detailed high frequency reproduction and incredible S/N ratios. Experience your favourite music like you’ve never heard it before.
    Sound Restorer
    Hear your music the way it was meant to be heard. Clarion’s Sound Restorer recreates the high frequency information that is lost during compression. The result is clear and detailed sound - the way it was meant to be heard.
    Bluetooth® Ready
    Talk on your cellular phone or enjoy your favourite album - wirelessly. Simply connect the BLT370 Bluetooth interface to your DXZ676USB for high quality, wireless audio.
    MP3/WMA/iTunes® AAC Compatible with ID3-TAG Display
    Formats like MP3 and WMA, said to be the de facto standard for compression, as well as AAC with higher compression ratio are supported. This facilitates you with easy enjoyment in the car of music data downloaded from music stores on the internet. ID3-TAG Display offers more ease of use of each of the formats flexibly.
    Full-dot LCD Display
    The HMI display in the DXZ676USB features a full-dot LCD design to provide information that is easy-to-read and incredibly detailed.
    Digital Z-Enhancer
    Clarion’s Digital Z-Enhancer controls P-EQ, HPF, and LPF through the DSP, allowing you to select from three equalising patterns that emphasise the range of tones in the upper/base regions respectively while maintaining perfect acoustic balance. Furthermore, by adding gain adjustment (HI, MID, LOW) to the 3 equalising patterns, it is now possible to choose from 9 different equalising patterns to customise the sound quality pattern so that it matches your speaker system or music source perfectly.
    4 × 53W MOS-FET Power Amplifier
    MOS-FETs, known to have superior performance as power amplifier audio components, are employed in 4 × 53W high power amplifier, which Clarion boasts its quality and performance. MOS-FETs’ linear and lowdistortion performance drastically improves S/N ratio at higher frequency range, which is more susceptible to noise, making the listeners enjoy sound reproduction ever closer to the original sound.
    TUNER SECTION
    Frequency bands
    FM: (MHz) 0.05MHz steps 87.5 to 108
    MW: (kHz) 9 kHz steps 531 to 1,602
    LW: (kHz) 3 kHz steps 153 to 279
    FM usable sensitivity (dBf) 9
    FM 50 dB quieting sensitivity (dBf) 17
    FM alternate channel selectivity (dBf) 75
    FM stereo separation @1 kHz (dB) 25
    FM stereo freq. resp. @ ±3 dB (Hz) 30 to 15,000
    CD SECTION
    Wow/Flutter (WRMS) Below measurable lmits
    S/N ratio (dB) 100
    Frequency response (Hz) 5 to 20,000
    Dynamic range (dB) 95
    Harmonic distortion (%) 0.01
    AUDIO SECTION
    Power output (DIN45324, +B = 14.4 V) 4 × 25 W
    GENERAL
    Dimensions (W × H × D), mm 178 × 50 × 158
    Remote control (W × H × D), mm 44 × 113 × 11
    Weight (kg) 1.6
    Power consumption: less than 15 A
    Speaker impedance 4Ω (4Ω to 8Ω allowable)
    call
    081388575788
    up........................
    sub urban djakarta city
    2 Days 13 Hrs 9 Mins 33 Secs
    bedanya ama yg 786 apa boss??
    786 punya?? nett pm yah
    batavia
    up biar cpt laku
    ini spec keduanya bos gopar :
    clarion dxz786usb
    * Siap untuk CD-R/RW
    * Kompatibel dengan MP3, WMA dan iTunes® AAC
    * Rear USB connector with maximum track capacity: 130,560 (255 tracks in 512 folders)
    * Pemutaran WMDRM 10 untuk Streaming Media Digital
    * 18 stasiun FM, 6 stasiun AM prasetel
    * Kontrol langsung iPod® melalui USB
    * 6V / Preout audio 6 kanal
    * Kontrol tingkatan subwoofer
    * Konverter D/A 24 bit
    * Pemulih SUara
    * Z-Enhancer Digital
    * Penyelarasan waktu digital
    * Crossover aktif 3 arah
    * Equaliser parametric 3 band
    * Filter high pass & low pass terpasang
    * Pengatur pembatalan amplifier terpasang
    * Amplifier MOS-FET 4 kanal × 53 watt
    * Konsol kemiringan berpenggerak motor
    * Tampiran 728 variable warna dan tombol bercahaya
    * “SLIDETRAK” untuk pengoperasian dinamis
    * Masukan Selular dan mode bisu telepon
    * Masukan auxilliary dengan kontrol tingkatan CeNET atas Pengubah CD 6 cakram
    * Penerima AUX Bluetooth yang siap untuk BLT370
    * Kemampuan interface sambungan roda putar jarak jauh OEM
    calrion dxz676usb :
    * MP3, WMA dan iTunes® kompatibel dengan AAC serta tampilan ID3-TAG
    * Konektor USB belakang
    * Kapasitas trek maksimum: 65,025 (255 trek dalam 255 folder)
    * 18 buah preset stasiun FM, 6 buah preset stasiun AM
    * Kemampuan kontrol iPod® menggunakan model EA1276 opsional
    * Kontrol volume subwoofer
    * Konverter 24-bit D/A
    * Pemulih Suara (Sound Restorer)
    * Pengatur suara Digital Z-Enhancer
    * Equaliser parametrik 2-band
    * Penguatan bas dinamis MAGNA BASS EX
    * Filter high-pass & Low-pass terpasang
    * Amplifier MOS-FET 4-kanal × 53 watt
    * Konsol miring bermotor
    * Tampilan dot dengan Screensavers
    * SLIDETRAK” untuk pengoperasian yang dinamis
    * Input Seluler dan Mode Bisu Telepon
    * Input Auxilliary dengan kontrol level
    * Audio pre-out 6-volt / 6-kanal
    * Kontrol CeNET untuk: DVD changer, TV tuner, CD changer 6-cakram dan iPod®
    * Transiever AUX Bluetooth siap digunakan untuk tipe BLT370
    * Kemampuan antarmuka roda putar kabel jarak jauh OEM
    * Kontrol panel yang dapat dilepas
    pm sent bos gopar........
    thanks ya bos drill1111...........
    clarion dxz786usb
    * Pemulih SUara
    calrion dxz676usb :
    up.................
    up.................
MBtech GT Radial
  1. ALPINE CDA-9853 kondisi muluuuus n segel.......(sold,thanks modcom..)
    Last Post: 27th January 2010, 07:41
  2. CLARION HX-D2 kondisi muluuuus n segel....(sold,thanks modcom....)
    Last Post: 22nd January 2010, 20:05
  3. Replies: 36
    Last Post: 9th January 2010, 08:37
  4. ALPINE CDA-9853 kondisi muluuuus n segel...(sold,thanks modcom....)
    Last Post: 21st November 2009, 05:24
  5. Replies: 64
    Last Post: 7th July 2009, 05:01
