Home audio stuff
  • Short URL:  http://modifika.si/148809
    jakarta selatan
    3 Days 2 Hrs 6 Mins 55 Secs
    Home audio stuff
    Integrated Amplifier - Cambridge Audio 550A
    Spoiler for CA 550A: Show
    Brand New,
    Garansi 1 thn
    Features & Specification
    Max power output per channel (Into 8O) 60W
    6 inputs, 2 outputs and tape In
    Oversize toroidal transformer and custom heatsink
    Revised output stage using new high current Sanken output transistors
    New Alps film type ‘black box’ volume pot for excellent channel balance
    Fully updated and re-tuned CAP5 technology for optimal protection and performance
    Control Bus and IR Emitter In connections for simple multi-room integration
    Pre-out for connection to external power amp / active sub
    EnergyStar certified ultra low power (<1W) standby circuit
    New ultra-rigid wrap-around casework design with thick brushed aluminium front panel
    Front-mounted iPod/MP3 socket
    Supplied with new Navigator remote – also controls Azur CD players and docked iPods
    Gold plated low-loss 3-way speaker terminals
    LED indicator shows which speaker terminals (A/B) are selected
    Spoiler for Harga: Show
    Net = Rp 2.600.000,-
    Integrated Amplifier - Cambridge Audio 650A
    Spoiler for CA 650A: Show
    Brand New,
    Garansi 1 thn
    - Max power output per channel (Into 8O) 75W
    - 6 inputs, 2 outputs and tape In
    - Twin rectifiers and separate power supplies
    - Oversize toroidal transformer and custom heatsink
    - Revised output stage using new high current Sanken output transistors
    - New Alps film type ‘black box’ volume pot for excellent channel balance
    - Fully updated and re-tuned CAP5 technology for optimal protection and performance
    - Control Bus and IR Emitter In connections for simple multi-room integration
    - Pre-out for connection to external power amp / active sub
    - EnergyStar certified ultra low power (<1W) standby circuit
    - New ultra-rigid wrap-around casework design with thick brushed aluminium front panel
    - Front-mounted iPod/MP3 socket
    - Supplied with new Navigator remote – also controls Azur CD players and docked iPods
    - Gold plated low-loss 3-way speaker terminals
    - LED indicator shows which speaker terminals (A/B) are selected
    Net = Rp 3.500.000,-
    Integrated Amplifier - NAD C326
    Spoiler for NAD C326: Show
    NAD C326
    Brand New,
    Garansi 1 thn
    * 50W x 2 Continuous Power into 8 ohms
    * PowerDrive™ circuit
    * NAD SR 8 Full System Remote control
    * Headphone socket
    * Front panel Media Player (MP) input for attaching portable MP3 Player
    * Relay Input Switching
    * Holmgren Toroidal Power transformer
    * 7 Line inputs, including one tape in/out
    * All discrete circuitry Short signal path from input to output
    * All sockets Gold plated
    * Tone controls defeat switch
    * Main-amp input & pre-amp outputs
    * Subwoofer (mono) Out
    * Soft Clipping™
    * IR Input/Output
    * 12 volt trigger out
    * Detachable IEC Power Cable
    * <1W Standby Power Consumption
    * Free of lead and other environmentally dangerous substances
    Net = Rp 3.600.000,-
    Subwoofer - Wharfedale SW150
    [SPOILER=Wharfedale SW150]
    Wharfedale SW150
    Brand New,
    Garansi 1 thn
    Driver : 10"
    Amplifier Power : 150 Watts RMS
    Advanced “Tri-Lam” cone:
    The new “Tri-Lam” cones introduced on all the SW-models are marvels of materials technology and application.
    Although huge, they remain completely controlled at all times.
    Damping and extended voice-coil:
    Completely controlled even under extreme dynamics, the advanced voice coils allow the cone to travel to the full 24mm maximum excursion with a linear pistonic motion.
    High power amplifiers:
    A new Class AB amplifier has been specifically designed for the models.
    Very low distortion, exceptional headroom, and a high internal electrical damping factor provide accurate control of the speaker, for performance well above the specification.
    Advanced subwoofer processing/filter system:
    All subs use an advanced microprocessor controlled analogue low-pass filter section for sonic performance with a low noise floor.
    It is possible to switch all filters off if used in a high quality AV system.
    Harga
    Net = Rp 3.200.000,-
    [CENTER]Berminat ??
    Langsung Call/SMS
    Michael
    0817-917-3357
    jakarta selatan
    uppppppppppppppppppppppppppppp
    16 Hrs 28 Mins 8 Secs
    up.........
GT Radial Venom 300x250
  1. Replies: 7
    Last Post: 13th June 2010, 11:47
  2. Home Theater and Home Audio ( update foto )
    By vian11 in forum Speaker - SubWoofer
    Last Post: 22nd May 2010, 23:51
  3. Home Theater and Home Audio ( update foto )
    By vian11 in forum Bursa Audio Lainnya
    Last Post: 22nd May 2010, 23:27
  4. Home Theater and Home Audio ( update foto )
    By vian11 in forum Head Unit & Processor
    Last Post: 22nd May 2010, 23:25
