KICKER SOLO X S12X kondisi 98%,lengkap dus,buku n garansi....(sold,thanks modcom...)
Results 1 to 10 of 23
  • Short URL:  http://modifika.si/148805
    Cool KICKER SOLO X S12X kondisi 98%,lengkap dus,buku n garansi....(sold,thanks modcom...)
    KICKER SOLO X S12X kondisi 98%,lengkap dus,buku n garansi.....sold
    KICKER acoustic engineers spent two years tweaking and fine-tuning the most serious statement ever from the first name in bass, and the results are ridiculously scary. New for this year, presenting three select versions of the original sub monster… KICKER SoloX™ Subwoofer.
    How do you improve on a patented mechanical brute? Since the 18-inch S18X debuted in 2003, KICKER engineers have been working to make SoloX more advanced. This year they went all the way, creating the world’s ultimate bass machine.
    Patented square subwoofer technology designed with the serious autosound competitor in mind, SoloX Subwoofers go where no others can. The 10-inch S10X, the 12-inch S12X, and the absurd S18X… it’s KICKER ingenuity to the umpteenth power. The SoloX earmark is the SPAIR (Simple Pull Apart Insertable Replacement)™, the patented cone/coil assembly that differs from other field-replaceable cones because the woofer’s cast-aluminum basket and massive motor assembly (BAM) remains intact in the enclosure during reload. In 2008 the SPAIR, just as the SoloX itself, withstands unnatural amounts of abuse while retaining the infrastructure for thunderous bass that earned it both competitive SPL (sound pressure level) and sound-quality world championships within weeks of its original release. Additionally, the newest SPAIR retro-fits into the previous generation of SoloX BAM if needed, with no modification.
    More KICKER firsts provide protection against ruthless heat and other potential hazards. The distinctive UniPlate V.2™ hyper-extended, pole/backplate assembly stays cooler with X-Vent™ technology (pat.pend.), yielding enhanced heat transfer for maximum power handling as well. This breakthrough in subwoofer motor construction increases linear magnetic fields around the coil gap for superior cone-motion control, all while releasing pressure under the cone for freer suspension and enhanced low bass. OK, it slams.
    Further heat dissipation comes from the vented pole’s ARCTIC (Aluminum Rapid Cooling Thermal Induction Centering) Cap™, creating a Venturi-effect and forcing greater amounts of cooling air through the X-Vent, all while its high mass acts as a heat sink. SoloX’s dual voice coils and copper-clad-aluminum, edge-wound coil wire are oversized to withstand extreme heat too. No KICKER woofer possesses this many features to remain so reliable.
    Additional cooling comes from KICKER’s perimeter venting™, pumping out heated air trapped beneath the S10X and S12X’s S3 Triple Spider Array™ and replacing it with cooling outside air (Quad Spider Array on the S18X). The one-piece, injection-molded cone’s new spoke design supplies structural bracing and contains a rolled outer edge to increase rigidity and decrease flex under high excursion. Stitched surround helps to prevent cone/surround separation. SoloX subs also utilize removable spring-loaded binding posts, making connection to any type or size of wire quick and easy.
    For complete system flexibility, SoloX comes available with dual 2-Ohm or dual 4-Ohm voice coils, as do respective SPAIR models.
    Model S12X
    Size (IN.,CM) 12, 30.5
    Weight (lbs.,kg) 47, 21.3
    Max Rec Amplifier Power (WATTS PEAK/RMS)* 5000/2500
    Sensitivity (dB 1w/1m) 87.7
    Frequency Response (Hz) 20-100
    Mounting Depth (IN.,CM) 8-9/16, 21.7
    Mounting Cutout, Square (IN.,CM) 11-1/4, 28.6
    Model S10X
    Size (IN.,CM) 10, 25.4
    Weight (lbs.,kg) 46, 20.9
    Sensitivity (dB 1w/1m) 85.7
    Frequency Response (Hz) 24-100
    Mounting Depth (IN.,CM) 8-3/8, 21.2
    Mounting Cutout, Square (IN.,CM) 9-3/4, 24.7
    Recommended Box Volumes:
    The SoloX is engineered for Highly specialized installations/applications. See the Tech Manual or conslult the KICKER Technical Support Team for enclosure specifications based on your individual requirements.
    *Assumes typical music program with minimal amplifier clipping; varies with enclosure size. See your KICKER dealer for details.
    **Port Volume Excluded.
    Due to continual development, product, and specifications are subject to change without notice. Stillwater Designs and it's agents are not responsible for typographical errors.
    SLAM (SPAIR Lockdown Attachment Mechanism)™
    Aluminum frame which locks down the removable assembly.
    SPAIR (Simple Pull Apart Insertable Replacement)™ (pat.pend.)
    Stamped steel basket holding the removable cone/voicecoil assembly.
    * Vacuum-formed, injection-molded SoloKon with rolled outer edge
    * S4 Quad Spider Array™
    * Dual Ultra-Length 3.5-inch Voice Coil
    * B3-Link 3-Way Connection System™ allows binding post, terminal block, or barrier strip connection
    * Strain relief boots on tinsel lead wires
    BAM (Basket and Motor assembly)™
    The heavy part.
    * Cast Aluminum Basket
    * UniPlate V.2™ extended pole/backplate assembly
    * X-Vent™ Extended Pole (pat.pend.) for cool operation
    * ARCTIC (Aluminum Rapid Cooling Thermal Induction Centering) Cap™ centers SPAIR and aids cooling by adding mass and channeling air into X-Vent
    * Triple Stack Custom Tooled Magnet
    * Chrome Plated Backplate
    * Thick Rubber Magnet Boot protects against damage during installation
    Also included is the SPLAT (Speaker Precise Location Alignment Tool) to locate and anchor the BAM to the baffle of your box.
    call
    081388575788
    up......................
    The SPL Enclosure is intended for SPL ONLY!
    It is designed to be used with test tones above 45Hz!
    Playing music with frequencies below 45Hz will result in very, very bad things happening!!
    Wihh.... ngeri nih... Kira kira what very bad things will happen? sub-nya jebol gitu yach boss? :p :p
    ..mEdan city..
    3 Hrs 57 Mins 22 Secs
    sub impian..
    :smt010:smt010:smt010
    wah,kurang tau pastinya sich bos pemula audio,soalnya buat dengerin ga sampai limit warningnya aja udah ga kuat dengernya bos,bisa jebol nich kuping n jantung,ampuuuuun,he..he...he.....
    thanks ya bro anak medan....
    klaten
    Bantu up buat sub Super Gaharr........
    thanks bos danny.....
    BUJUG... Gila chris, ada aja yg bikin takjub.. Apa bedanya ama yg gua beli dulu chris? Jauh lebih gahar yah? Harus punya alat pemacu jantung di mobil yah? Wakwakwak..
    he..he..he..,iya nal,ini bapaknya solobaric l7 nal..
    Jakarta Pusat
    1 Wk 1 Day 23 Hrs 37 Mins 1 Sec
    ais!!!!! ini baru sub spl! dewannya mungkin ampe saat ini ^^ bantuin up yah bos. power ape neh yah yang sanggup ngangkat?
    upupupupupupupup
  1. Replies: 4
    Last Post: 23rd January 2010, 17:15
  2. Replies: 66
    Last Post: 7th January 2010, 07:14
  3. WTS : KICKER S12X SOLO X + VISONIK 4000 !!!!
    By NeuSounds in forum Speaker - SubWoofer
    Last Post: 23rd December 2009, 02:06
  4. Replies: 1
    Last Post: 8th December 2009, 07:50
  5. WTS : VISONIK 4000 + KICKER S12X SOLO X !!!!
    By NeuSounds in forum Power Amplifier
    Last Post: 13th June 2009, 02:26
