upgraded tube amplifier BK BUTLER TDB 2150 kondisi muluuus...(sold,thanks modcom..)
Results 1 to 10 of 79
  • Short URL:  http://modifika.si/148330
    Cool upgraded tube amplifier BK BUTLER TDB 2150 kondisi muluuus...(sold,thanks modcom..)
    upgraded tube amplifier BK BUTLER TDB 2150 kondisi muluuus..............sold
    sold 2 pcs,sisa 1 pc yang sudah upgraded...
    TDB 2150
    T H E R M I O N I C
    Vacuum Tube Driven Mobile Power Amplifier
    DESIGN
    With authentic Vacuum Tube response and an open-ended design, (ZERO global negative feedback), Tube Driver BLUE overcomes one of the most universally agreed upon sonic problems plaguing virtually all current amplifier designs; harsh degenerative feedback causes a plethora of undesirable sonic products. Tube Driver BLUE eliminates global negative feedback entirely! Coupled with a totally unique output load mirroring circuit, the hand selected 6SL7GT twin triode tubes operate in a safe, near plate-saturated mode continuously. The design creates the ideal electrical environment for classic vacuum tube thermionic characteristics.
    PERFORMANCE
    Tube Driver BLUE amplifiers utilize natural vacuum tube thermionic emissions to automatically enhance biasing of the audiophile-quality Sanken bi-polar devices used in every model. This unique USA patented design reduces both Crossover and Total Harmonic Distortion (THD) figures to LESS than 0.15%. This achievement is almost unheard of in an open-ended, ZERO negative feedback high fidelity amplifier. Conventional open-ended/low feedback vacuum tube amplifiers often exhibit real world THD of 2% or greater and are generally limited to quite low output power. Tube Driver BLUE succeeds in operating at 10 times less THD while maintaining real power vacuum tube tonality! Now you can hear the original pure essence of vacuum tube audio with Tube Driver BLUE.
    PROTECTION
    All this performance must be effectively controlled. The exceptional electrical design of the Tube Driver BLUE, coupled with a MASSIVE aluminum heat exchanger and heat sink, provides protection and cooling capacity far in excess of any contemplated needs. A long life, temperature-controlled cooling fan is activated if the surface temperature exceeds 50 C, keeping heat stress well within safety levels. Additionally, DC fault protection with soft start (10-15 sec) and a fully regulated DC tube-heater supply circuit protect your Tube Driver BLUE amplifiers in every conceivable way.
    General features:
    ZERO negative feedback. No global negative
    degenerative feedback loop
    Open Ended Audiophile Circuitry
    Musical, warm and dynamic, rivalling "all-tube" single-ended home audiophile amplifiers
    Hand selected/matched 6SL7GT Twin Triode tubes
    (One per channel)
    Fully regulated Tube Heaters with Delayed Soft Start
    (10-15 second turn-on delay)
    Load Adaptive Vacuum Tube Driven output circuitry
    Massive (400% oversize) internal/external Heat Exchanger with Temperature-controlled Fan Cooling
    Tightly regulated MosFET Power Supply
    DC fault / Short Circuit Protection Circuitry
    Dual Color Diagnostic LED: Green=Normal / Red=Fault
    Gold Plated RCA, Power and Speaker Connectors
    Frosted Platinum finish
    Tube Illumination: Internal BLUE LEDs
    Patented Design
    Concept & Design: BK Butler / USA
    Specifications:
    Rated Power (all channels driven):
    2 x 150 Watts RMS per channel @ 4 ohms
    1 x 500 Watts RMS Bridged (Mono) @ 4 ohms
    2-Ohm Stereo, 4-Ohm Mono Stable
    Freq response: 5Hz to 100kHz (+/- 1dB)
    THD: <0.15% (30kHz bandwidth)
    S/N Ratio: >110dB (A-Weighted)
    Idling Current: 2.4 Amps
    Input Sensitivity: .450v - 12v RMS
    Fuses: 2x25A ATC
    Dimensions: 10.25"W x 17.3"L x 2.4"T
    Weight: 12 Lbs.
    call
    081388575788
    17 Hrs 26 Mins 3 Secs
    up...........
    thanks ya bos rin...........
    up.................
    up...................
    up.....aries motor bandung jago upgradenya!! spesial tanganin ini power
    Jakarta - Utara
    1 Mth 1 Wk 6 Days 37 Mins 1 Sec
    up................................................
    VISIT OUR FORUM: JDM PARTS n AIRBBOM:
    http://www.modifikasi.com/forumdisplay.php?f=112
    NANO TECHNOLOGY with AIRBOOM!!! SAVE your FUEL + IMPROVE your HORSE POWER engine.....
    email: lionel_maulana@yahoo.com
    CP: 08177 44 542 lionel, WA Only 0819 1672 5767
    WEBSITE : www.otopartid.com
    INSTAGRAM: @otopartid @otoclothid @motopartid
    FACEBOOK : otopart id
    wah,thanks ya infonya bos rin...
    thanks for the bump yach bos lionel.......
    up...............
GT Radial MBtech
  1. AMPLIFIER : BUTLER TUBE DRIVER BLUE TIPE TDB 2150 (Bekas)
    By SpeakerStore in forum Power Amplifier
    Last Post: 7th October 2011, 16:56
  2. Replies: 22
    Last Post: 6th January 2010, 07:34
  3. Butler Blue Tube Driver TDB 2150
    By Pioneer22 in forum Power Amplifier
    Last Post: 5th November 2009, 21:04
  4. Replies: 1
    Last Post: 10th June 2009, 22:15
