Subwoofer DLS IRIDIUM 10"
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/148128
    www.cliport-audio.com
    1 Wk 4 Days 1 Hr 13 Mins 22 Secs
    IRIDIUM 10i is a new 10" subwoofer in the Ultimate Iridium series with diecast basket in a nice grey color. Strong paper cone made of unpressed paper giving a superb sound quality. Dual spiders and dual magnet system with a rubber magnet cover. Dual 4 ohm voice coils. Grille and basket in same colour as the other speakers in this series
    Specifications
    Woofer size: 10" (25 cm)
    Impedance: 2 x 4 ohm
    Power handling capacity: 500 W RMS
    Max power handling capacity: 800 W
    Peak power: 1000 W
    Frequency range: 25 - 2500 Hz
    Sensitivity: 84 dB (1W/1 m)
    Magnet size: 180 mm (8,7") 180 oz
    Outer diameter of woofer: 266 mm (10,47")
    Mounting depth: 150 mm (5,91")
    Mounting hole: 236 mm (10,47")
    X-max: +- 14 mm (0,55")
    Weight: 9,8 kg (21,6 lbs)
    T/S parameters single V/C: Fs 43,5 Hz Re 3,2 Ohm Qms 2,84
    Vas 12 liter Vas 0,42 Cuft Qes 0,87
    Qts 0,67 Sd 380 cm² BL 15,1
    T/S-Parameters (in parallel):
    Fs 42,3 Hz Re 1,8 Ohm Qms 3,44
    Vas 12 liter Vas 0,42 Cuft Qes 0,54
    Qts 0,47 Sd 380 cm² BL 14,6
    Recommended enclosures
    Sealed:
    Volume 22 litres. Fill with acoustic wool up to 70%. F3: 40 Hz.
    Use single voice coil connection
    Vented:
    Volume 25 litres. Use 3" port x 38 cm length (15"). Mount the port on the side of the enclosure. Voice coils connected in parallel.
    Technical Specifications
    Bridge mode connections and more
    Manual for Iridium 10i, 12i & 15
    Cliport Car Audio Division
    Adress : Jl. Sumbawa No 60 (BANDUNG)
    Office Number : (022) 73404522
    Rikky : 081221420030
    Hayu : 085692481255
    Atau PM saya
    YM : rikky_identity
    *NB : Bagi yang berada di wilayah Bandung, dapat melakukan Transaksi dengan sistem pembayaran COD (Cash On Delivery) atau langsung datang ke workshop kami.Alamat lengkap tertera diatas. Di luar wilayah bandung transaksi melakukan jasa pengiriman TIKI, No Resi akan kami kirim Via SMS
    Transfer Via Rek BCA :8380041724 A/N Rikky
    up up up up up up up up up up up
    4 Wks 1 Day 19 Hrs 9 Mins 16 Secs
    nett nya boz?? pm yakk...
    Quote Originally Posted by Masahide View Post
    PM sent pak
    Cipete, SoutH Of JakaRtA.
    1 Day 21 Hrs 37 Mins 39 Secs
    brp duit nih Pak?
    harganya brp bos..pm ya?
  1. busi ngk iridium sama hurricane iridium
    By Danny.Rachmad in forum Diskusi Mesin
    Last Post: 28th September 2012, 14:49
  2. Replies: 69
    Last Post: 7th September 2011, 23:18
  3. WTB busi 2nd NGK Iridium BKR6EIX atau Denso Iridium VK-20
    By olga_thehacker in forum Jual Beli Mesin Lainnya
    Last Post: 28th May 2009, 12:57
