Dijual subwoofer HIGH END 23w. < SOLD SOLD SOLD!!!
kelengkapan Unit aja. kondisi normal. dijual karna lagi BU.
Specs :
Electrical Data
Nominal Impedance Zn 4 ohm
DC Resistance Re 3.45 ohm
Voice Coil Inductance Le 0.45 mH
TS Parameters
Resonance Frequency fs 20.5 Hz
Mechanical Q factor QMS 4.8
Electrical Q factor QES 0.52
Total Q factor Qts 0.47
Force Factor Bl 9.3 Tm
Mechanical Resistance Rms 2.7 Kg/s
Moving Mass Mms 101 g
Effective Piston Area sd 232 cm^2
Equivalent Volume Vas 45.6 ltrs
Sensitivity 2.83V/1m 82 dB
Power Handling
100h RMS noise test IEC 225 W
Voice Coil and Magnet Parameters
Voice Coil Diameter 50 mm
Linear Excursion +/- 13 mm
Max mech. excursion +/- 20 mm
Pics :
PRICE : SOLD TO MR AZIS
THNX MODCOM.
Call or sms or pm : 0817-6314036
