VSS Flux Cap 100 Amp (sold,thanks modcom....)
Results 1 to 10 of 27
  • Short URL:  http://modifika.si/147837
    Cool VSS Flux Cap 100 Amp (sold,thanks modcom....)
    VSS HARRISON LABORATORY Flux Cap 100 Amp Battery Isolator & Power Supply Electronic Cap kondisi muluus.........sold
    FLUX CAP,50 AMP $ 279.00
    FLUX CAP,100AMP,ALUM $ 575.00
    FLUX CAP,200AMP,ALUM $ 975.00
    COMPETITION POWER SUPPLIES combined with BATTERY ISOLATORS and ELECTRONIC CAPS
    FluxCaps tm are similar to the Jacobs Accuvolt tm but are more robust, efficient, and are dual phase requiring less filtering. For very high power, use a small FluxCap between the alternator and an audio battery bank. This way a 50 amp alternator can charge a 1000 amp battery bank. (limited duty cycle)
    Flux Cap 100 Amp
    Battery Isolator
    Power Supply
    Electronic Cap
    Model: 903147
    Size: 3" Wide, 5.5 High, 8.5 Long
    Weight: 3.5 Pounds
    Current limiting, Voltage Regulated
    Efficiency: 98.4% @ 14.5V
    (11.5V input) 1%
    Amp Draw: Depends on I/O voltage
    Input Voltage: 11 V minimum
    Output Voltage: 14.7 V standard
    (Other voltages available upon request)
    call
    081388575788
    3 Days 16 Hrs 37 Mins 10 Secs
    Om, ini fungsinya buat naikin tegangan gitu ya, biar stabil di 14.7 V?
    Ini second kan ya?
    iya bos,betul banget.......
    up....................
    1 Hr 56 Mins 43 Secs
    Ini cara pasangnya gimana ya bro? Terus kalo gua udah pake 90A battery, 2F capbank, sama 400A Batcap, perlu ga pasang ini biar bisa lebih stabil di 14.7V? thx...
    kalau capbank dan batcp fungsinya beda bro,kalau mau tetap stabil di 14,7volts memang harus pakai vss,us amps optimizer atau jacobs accuvolts bro....
    Berapaan yah harganya?2.5 jt dpt?
    Ya ampun chris barang lo.. Up up d buat yg gua kaga ngarti, haha..
    sorry bos shine,belum bisa...
    thank ya bro rinal.....
Datsun 300x250 GT Radial
  1. WTS SPK FLUX (sold thx modcom...)
    By KEKEPOPPY in forum Speaker - SubWoofer
    Last Post: 6th April 2010, 19:21
  2. Replies: 37
    Last Post: 12th March 2010, 20:53
  3. Replies: 2
    Last Post: 26th October 2009, 06:26
  4. flux power caps 68.000uf.............(sold,thanks modcom...)
    By MR.GASOLINE in forum Bursa Audio Lainnya
    Last Post: 27th September 2009, 07:24
  5. Replies: 39
    Last Post: 5th July 2009, 11:29
