Interconect CHORD Cobra 3
  • Short URL:  http://modifika.si/147531
    16 Hrs 46 Mins 58 Secs
    Chord Cobra - technical info
    Cobra has been part of the Chord range for almost as long as the Chrysalis and is another good example of how a cable design evolves. The original Cobra was a co-axial design; Cobra 3 uses a pseudo-balanced conductor configuration along with vibration controlling conductor spacers. The conductors are twisted along the length of the cable and insulated with low density polyethylene. The braided shield surrounds both conductors and spacers and is mechanically and electrically isolated from the signal path.
    Whilst the design of the Cobra 3 is on the face of it similar to the Crimson, the Cobra has larger diameter conductors and these, along with the vibration damping conductor spacers, produce a cable better able to accurately transmit micro-dynamic information. The high-density oxygen free copper braided shield is effective over a wide frequency range. Combined with the conductors, this produces a cable that will carry excellent levels of detail, has a surprisingly low noise floor and will help to convey the sense of space around individual instruments and voices and produce a stable stereo image.
    Multi-strand oxygen free copper conductors
    Low density polyethylene dielectric
    Matched signal and return paths
    Floating high density braided shielding
    High quality gold-plated RCA/phono plugs
    Vibration minimising conductor spacers
    Vibration damping PVC outer jacket
    Hrg 900rb. Panjang 1m x 2
    Berminat hub 08161187408
    Up.....................
    14 Mins 59 Secs
    2m nya kena brp bos ?
    Ada bos. Hrg 1,5jt. Mau?
  1. Kabel RCA Chord Cobra 3
    By rbtrzl in forum Cables & Interconnects
    Last Post: 23rd March 2012, 11:01
  2. Chord cobra vs XLO twinax
    By grooming in forum Diskusi Audio Lainnya
    Last Post: 22nd April 2011, 03:18
  3. Chord Cobra Interconect Mint Condition!!
    By jlu_mike in forum Bursa Audio Lainnya
    Last Post: 21st March 2011, 08:07
