Paket Speaker DLS
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/146961
    www.cliport-audio.com
    1 Wk 4 Days 1 Hr 13 Mins 22 Secs
    Paket Speaker DLS
    Paket 3-ways system
    - DLS Reference 6.3
    - Power Amplifier ARC Audio 4050 XXK V2
    - Peredam Automat 2 lembar
    - Free Installation Placement in Pilar A
    - Standard wire connection include (RCA, Kabel Speaker, Kabel Stroom 4AWG)
    Price : Rp. 5.750.000
    Pict for unit:
    Reference 6.3 is a new 3-way system with 16,5 cm (6,5") bass, 6,3 cm (2,5") midrange and 20 mm (0,8") tweeter T20. Filter boxesmed with selectable tweeter level in three steps and midrange level in two steps. Grilles are included.
    Woofer size :16,5 cm (6,5")
    Tweete : T20, 20 mm (0,8") silk dome tweeter
    Midrange size : 6,3 cm (2,5") UP 2.5
    Power handling capacity : 60 W RMS / 90 W max
    Impedance : 4 ohm
    Frequency range : 60 - 20 000 Hz
    Sensitivity : 93 dB (1W/1m)
    Crossover : Filter box with 12/6/12 db slope
    Crossover point (Hz) : 550 Hz / 4000 Hz
    Size of filter box : 145 x 85 x 45 mm ( 5,71 x 3,35 x 1,77")
    Outer diameter of woofer : Woofer: 165 mm (6,5"). Mid: 100 mm (3,94")
    Magnet size Woofer: 80 mm (3,15"). Mid: 65 mm (2,56")
    Mounting depth : Woofer: 63 mm ( 2,48"). Mid: 25 mm (1")
    Mounting hole : Woofer: 146 mm (5,75"). Mid: 82 mm (3,23")
    ARC 4050-XXK V2
    4 X 55W Channels Amplifier
    Specifications
    4 Channels Power XXK Series ▪ Microprocessor controlled ▪ Remote digital bass boost gain w/led status display ▪ Set and forget crossover switches on bottom plate ▪ Seperate front and rear high/low/full range select switch ▪ Seperate front and rear mono/stereo/full range select feature ▪ Heavy duty construction ▪ Thermal, DC, offset, reverse voltage, over voltage, short circuit protection ▪ Output power : 80x4@4 ohms, 160x4@2 ohms, and 320x24 ohms bridged ▪ Transient distortion : < 0.005% @4 ohms ▪ Frequency response: 20Hz-20Khz ▪ S/N ratio(A wtg) : > 105dB ▪ Bass boost : + 18dB @45Hz ▪ Input sensitivity : 250mV - 2.5V ▪ Crossover : 12dB stereo, 24dB mono 55Hz-5.5KHz ▪ Fuse : 30A x3 ▪ Dimensions : 16.5" x 8" x 2.35"
    Cliport Car Audio Division
    Adress : Jl. Sumbawa No 60 (BANDUNG)
    Office Number : (022) 73404522
    Rikky : 081221420030
    Hayu : 085692481255
    Atau PM saya
    YM : rikky_identity
    *NB : Bagi yang berada di wilayah Bandung, dapat melakukan Transaksi dengan sistem pembayaran COD (Cash On Delivery) atau langsung datang ke workshop kami.Alamat lengkap tertera diatas. Di luar wilayah bandung transaksi melakukan jasa pengiriman TIKI, No Resi akan kami kirim Via SMS
    Transfer Via Rek BCA :8380041724 A/N Rikky
    up.........................................
    klaten,jogja,solo
    4 Hrs 35 Mins 52 Secs
    bos arc 4050xxknya aja blh g?
    Quote Originally Posted by jockgger View Post
    Boleh bos, mau??? langsung cek PM yah
    1 Hr 43 Mins 34 Secs
    bos..... nuhun............ kapan maried............. murah kali paketannya.............
    Quote Originally Posted by fabri hadi View Post
    Iya bos secepatnya, minta doanya aja sama orderannya di perbanyak. hehehehehehehe.... 4050 nya udah nempel bos?? di drive pake speaker apa?
GT Radial NGK Busi
  1. Jual Paket Speaker 3Way By Viva
    By otot_amerika in forum Speaker - SubWoofer
    Last Post: 1st October 2012, 15:22
  2. nanya paket speaker
    By the_speeder in forum Diskusi Speaker
    Last Post: 24th June 2008, 01:45
