PIONEER ODR line 3 way kondisi muluuuuuus,lengkap dus n buku...(sold,thanks modcom..)
Results 1 to 10 of 67
  • Short URL:  http://modifika.si/146863
    Cool PIONEER ODR line 3 way kondisi muluuuuuus,lengkap dus n buku...(sold,thanks modcom..)
    PIONEER ODR line 3 way kondisi muluuuuuus,lengkap dus n buku.....sold
    The benchmark for high-quality audio
    In the pursuit of the ideal sound — natural and accurate reproduction of the input sound signal —, Pioneer went back to the very basics of speaker design. For four years,
    Pioneer’s top engineers analysed hundreds of diff erent materials and structures and considered every detail. Their aim was to enhance transient response, produce
    wide-ranging and linear sound over a broad spectrum and eliminate all unnecessary vibration. The result was well worth waiting for. Every speaker is crafted by skilled
    hands to an accuracy of 1/100 mm, far exceeding the standards of conventional speakers. These luxurious units produce ‘genuine’ high-quality sound. Reproduction of
    music is so precise that you can hear not only the emotions of the music, but that of the musicians too.
    PIONEER ODR :
    TS-T01RS 1-3/8” (3.5 cm) SUPER WIDE-RANGE TWEETER
    120 W Max
    Ion-plated titanium dual arc-ring diaphragm
    Brass equaliser
    Spherical zinc die-cast frame
    This super wide-range tweeter is ready for next-generation audio, such as DVD-Audio. Offering an extended wide range, it ensures the true reproduction of high frequencies, as well as
    replicating the exact harmonic elements of instruments. It not only guarantees accurate high-quality audio but imbues every sound with a rich texture too. This has been achieved by the
    design of a new, patent-pending asymmetric dual arc-ring diaphragm, 35 mm in diameter. Made of lightweight and high-rigid titanium formed into a 20 μm thin foil, this diaphragm is
    responsible for the crystal-clear reproduction of the audible spectrum — up to 48 kHz! The diaphragm’s surface is coated with processed ion plating to eliminate distortion.
    The innovative brass equaliser with mirror-finish surface has been developed and precisely machined to provide a virtually distortion-free sound reproduction. Every component of this
    outstanding tweeter is made from low-resonance materials: the highly rigid zinc die-cast frame, brass screws and a newly developed, patent-pending resonance-resistant tungsten holder.
    TS-S01RS 3” (7.7 cm) MIDRANGE
    60 W Max.
    DLC (Diamond Like Carbon) coated titanium centre cap
    Zinc die-cast back chamber
    Gold-plated binding post-screw terminals
    This midrange speaker is part of a perfect multi-system. After thorough analysis,
    superior technology was developed specifically for this speaker to achieve the most
    natural and accurate sound reproduction. The pulp-based composite cone with
    reinforcing ribs is complemented by a titanium centre cap. Coated with DLC (Diamond
    Like Carbon), the cap surface is harder, which improves high-range frequency
    reproduction. A corrugated edge was also specially created to support the cone and
    absorb vibration more efficiently. With its rigid zinc die-cast back chamber, tweeters
    and mid-bass speakers can be connected more smoothly, no matter what the
    installation conditions, and solid midrange sounds are reproduced. When the chamber
    is not used, wide-range sound comparable to a mid-bass speaker can be achieved. This
    speaker features an ultra-strong neodymium magnet; a heavy zinc full-basket frame
    supports the magnetic circuit for
    receiving maximum power from the
    source. Its unique structure and material
    enable high rigidity, low resonance and
    no influence on cone movement. The
    tungsten holder is jointed to the frame at
    5 points to eliminate any resonance.
    TS-M01RS 6-3/4” (17 cm) MID-BASS DRIVER
    120 W Max
    Pulp-based composite cone with reinforced ribs
    Full-basket structure 5-spoke zinc die-cast frame
    Resonance-resistant structure tungsten damper holder with 5 points support
    This mid-bass driver has been skilfully crafted to extend the wide-range comparable to that of full-range
    speakers, yet with faithful reproduction of the overall sound spectrum. Numerous trials and meticulous
    selection of materials went into creating the pulp-based composite cone, and the resulting sound quality is
    ideal. Reinforced with ribs, the cone enhances the highest resonant frequency and eliminates all distortion.
    The centre cap is constructed from another specially developed pulp material, improving sound properties
    at the upper range and suppressing resonance from the magnetic circuit. The
    magnetic circuit itself uses an ultra-strong neodymium magnet and is
    supported by a heavy zinc full-basket frame, which reduces unnecessary
    reaction and resonance. Finally, a patent-pending resonance-resistant
    tungsten holder eliminates resonance between the damper and the frame.
    ODR price list converted from the Switzerland site / japan site
    RS-D7R CD/RDS-Tuner - $2208.05
    85020 , CD-R/-RW playback, High-quality CD mechanism with copper-plated chassis, Hi-bit conversion, Full audio control of RS-A9 digita integrated amplifier, OEL white-colour display illumination, IP-Bus input/output, Optical input/output
    RS-A7 Digital power amplifier - $5725.30
    85021 , 4x100 W (2x300 W) max., 24-bit multi-bit D/A converter, Class AB
    RS-A9 Digital integrated amplifier - $6543.31
    85022 , 4x100 W (2x300 W) max., 31-band equaliser, 4-way crossover network, Optical input, 3 optical outputs
    TS-T01RS 3.5 cm super wide-range tweeter - $1226.10
    85023 , 50 W nom. / 120 W max., 1.200-48.000 Hz, 95 dB/W/m, 6 Ω, gold-plated binding post-screw terminal
    TS-S01RS - 7.7 cm midrange - $1226.10
    85024 , 15 W nom. / 50 W(unit alone) - 60 W(with back chamber)max., 70-24.000 Hz(unit alone) - 160-24.000 Hz(with back chamber), 86 dB/W/m, 4 Ω, gold-plated binding post-screw terminals
    TS-M01RS 17 cm mid-bass driver - $1223.10
    85025 , 50 W nom. / 120 W max., 35-11.000 Hz, 89 dB/W/m, 4 Ω, gold-plated binding post-screw terminals
    TS-W01RS 25 cm subwoofer - $1308.22
    85026 , 150 W nom. / 300 W max., 20-3.000 Hz, 86 dB/W/m, 4 Ω, gold-plated binding post-screw terminals
    call
    081388575788
    klaten
    Pertamaxxx.. Mantab abis boss
    1 Wk 2 Days 3 Hrs 17 Mins 28 Secs
    Wow, barang muanstab berkeliaran...
    Bantu up bro...
    thanks ya bos danny n bos amir.........
    up...............
    Uuueeeddaaaannnn..
    Muuanntaaappp..
    city of heroes
    2 Hrs 59 Mins 7 Secs
    midrange aja boleh bro?
    pls pm yah netnya
    JAKARTA
    3 Hrs 48 Mins 54 Secs
    gile ! ada 3way nya jg . bis ngegondol mbl demo ODR yah ? hehe....
    sorry bro hohohihe,3 way nya ga dijual terpisah bro...
    thanks bro rinal.......
    bro afung koq tau aja semalem g ngebobol mobil demonya odr?mo ikutan ga nich di rencana berikut?he..he..he......
    up...............
  1. Replies: 112
    Last Post: 15th December 2009, 04:19
  2. Replies: 1
    Last Post: 8th December 2009, 07:50
  3. Replies: 26
    Last Post: 11th November 2009, 03:44
  4. pioneer cd-ib100II muluuuuuus dan lengkap...(sold,thanks modcom...)
    By MR.GASOLINE in forum Bursa Audio Lainnya
    Last Post: 10th June 2009, 03:30
