PIONEER ODR line TS-W01RS subwoofer (sold,thanks modcom...)
Results 1 to 10 of 82
  • Short URL:  http://modifika.si/146861
    Cool PIONEER ODR line TS-W01RS subwoofer (sold,thanks modcom...)
    PIONEER ODR line TS-W01RS subwoofer kondisi muluuuuuuus,lengkap dus n buku......sold
    The benchmark for high-quality audio
    In the pursuit of the ideal sound — natural and accurate reproduction of the input sound signal —, Pioneer went back to the very basics of speaker design. For four years,
    Pioneer’s top engineers analysed hundreds of diff erent materials and structures and considered every detail. Their aim was to enhance transient response, produce
    wide-ranging and linear sound over a broad spectrum and eliminate all unnecessary vibration. The result was well worth waiting for. Every speaker is crafted by skilled
    hands to an accuracy of 1/100 mm, far exceeding the standards of conventional speakers. These luxurious units produce ‘genuine’ high-quality sound. Reproduction of
    music is so precise that you can hear not only the emotions of the music, but that of the musicians too.
    PIONEER ODR :
    TS-W01RS 10” (25 cm) SUBWOOFER
    300 watt max
    Centre cap integrated pulp-based composite cone
    Opening at the back side
    Shallow design aluminium die-cast frame / Ř140 mm large-sized heat-resistant voice coil
    Enjoy the clean reproduction of sounds even at the very low frequencies with this high-grade
    subwoofer. Its cone, made of a lightweight, high-rigid pulp composite with carefully selected
    materials, combines with the centre cap to offer unprecedented high-quality reproduction of sounds
    as low as 50 Hz and even lower. The specially designed butyl rubber edge guarantees superb and
    accurate vibration response; a large voice coil provides highly efficient vibration of the whole cone
    without flexure; and the 12 large-sized ultra-strong neodymium magnets in the magnetic circuit
    create powerful and precise motion. By maximising the opening at the
    back, back pressure balance is easily controlled so that even the
    heaviest of basses can be reproduced exactly. Its high-rigid aluminium
    die-cast frame offers high damping properties. All this comes in an
    attractive, ultra-thin package that is extremely easy to install.
    ODR price list converted from the Switzerland site
    RS-D7R CD/RDS-Tuner - $2208.05
    85020 , CD-R/-RW playback, High-quality CD mechanism with copper-plated chassis, Hi-bit conversion, Full audio control of RS-A9 digita integrated amplifier, OEL white-colour display illumination, IP-Bus input/output, Optical input/output
    RS-A7 Digital power amplifier - $5725.30
    85021 , 4x100 W (2x300 W) max., 24-bit multi-bit D/A converter, Class AB
    RS-A9 Digital integrated amplifier - $6543.31
    85022 , 4x100 W (2x300 W) max., 31-band equaliser, 4-way crossover network, Optical input, 3 optical outputs
    TS-T01RS 3.5 cm super wide-range tweeter - $1226.10
    85023 , 50 W nom. / 120 W max., 1.200-48.000 Hz, 95 dB/W/m, 6 Ω, gold-plated binding post-screw terminal
    TS-S01RS - 7.7 cm midrange - $1226.10
    85024 , 15 W nom. / 50 W(unit alone) - 60 W(with back chamber)max., 70-24.000 Hz(unit alone) - 160-24.000 Hz(with back chamber), 86 dB/W/m, 4 Ω, gold-plated binding post-screw terminals
    TS-M01RS 17 cm mid-bass driver - $1223.10
    85025 , 50 W nom. / 120 W max., 35-11.000 Hz, 89 dB/W/m, 4 Ω, gold-plated binding post-screw terminals
    TS-W01RS 25 cm subwoofer - $1308.22
    85026 , 150 W nom. / 300 W max., 20-3.000 Hz, 86 dB/W/m, 4 Ω, gold-plated binding post-screw terminals
    call
    081388575788
    up................
    city of heroes
    2 Hrs 59 Mins 7 Secs
    emang barunya brpan bro?
    JAKARTA
    3 Hrs 48 Mins 54 Secs
    pernah punya nih tp yg 12" nya . sub mantep !
    Quote Originally Posted by hohohihe View Post
    up................
    city of heroes
    box butuh brp liter bro? sealed ato ported yah?
    nyampe sby net brp bro?
    minat nih
    pm sent bos....
    thanks....
    up........
    PangkaL Paha
    2 Wks 5 Days 2 Hrs 7 Mins 58 Secs
    hadeehh ga kuat ngeliadnya
Mega Glodok Kemayoran MBtech
  1. Wts: Hu pioneer top of the line Deh 9650 c(sold, thx modcom)
    By sulistio in forum Head Unit & Processor
    Last Post: 24th April 2010, 15:18
  2. Replies: 66
    Last Post: 7th January 2010, 06:14
  3. Replies: 13
    Last Post: 23rd December 2009, 04:05
  4. Replies: 9
    Last Post: 18th July 2009, 01:53
