DD FAMILY (Midbass and Full Tube amp)
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/146773
    PIN: 28C74CA7 HP:08112509829
    2 Days 22 Hrs 30 Mins 11 Secs
    Keluarga besar DD Hi End yg langka
    ZT45: Dual mono 2x45
    SOLD
    W6.5 midbass: 150/400watt
    The most power full midbass....silahken liat di videonya
    CALL/SMS: 08112509829
    1pair left
    The DDW6.5 mid-bass/mid-range driver was designed to deliver the widest possible bandwidth while providing a fast transient response with high levels of long term power handling. The cone is a composite blend of Kevlar fiber, carbon fiber and a very stiff and lightweight resin. This combination has an excellent strength to weight ratio that is light enough to react quickly to complex signals yet rigid enough not to flex when subjected to extreme power levels. The surround is a well dampened rubber half roll. The motor structure incorporates long magnetic field technology which ensures precise control over cone excursions and efficiently dissipates heat from the voice coil. The voice coil former is made from black anodized aluminum layered with arimid fiber and wound with the wire capable of enduring temperatures to 500 degrees F. The dual flat spider suspension is made from synthetic materials to give the smoothest response and long lasting durability. The lead wires are laminated into the layers and run across opposite sides to even out weight over the moving system. The leads are terminated in 10ga. copper wire for the most efficient electrical transfer. The DDW6.5 makes an excellent subwoofer in space limited systems and great for high powered midbass applications.
    We recommend to allow at least several weeks of playing time to break in DD Woofers, full break in may take many months. DO NOT play subwoofers at max amplifier power in the first couple of days, give the suspensions a chance to loosen up. As the suspension breaks in, the subs will play lower and louder.
    After you give the woofers a chance to break in (you'll know when this happens because the woofers will be playing lower and louder) you can start to look at port changes to alter the sound to your personal taste and your vehicles acoustic loading conditions.
    VIDIO W6.5
    http://www.youtube.com/watch?v=QV2eZY7NKCo
    ASikkkk PERTAMAX.... Ini midbass apa sub 6.5" yaaa.... serem amaat tampang-nya. :lol:
    midbass/midrange
    taruh dashboard keren kali yah
    klaten
    Quote Originally Posted by vian11 View Post
    midbass/midrange
    Di atas dasbor...???? boks nya segede apa yak???
    u p
    samarinda 0812 548 5788
    1 Day 7 Hrs 34 Mins 27 Secs
    manteb jek mid bass nya. pintu kudu rigit bgt tuh baru gak geter.............
    bisikin dong harga nya om hehehehehehehhe
    contact 0812 548 5788
    Quote Originally Posted by TJ_TJ View Post
    tumben gak kangen ? :o :o
    ok...bisikan dikirim
    Yogyakarta
    1 Day 11 Hrs 37 Mins 55 Secs
    midbass/midrange
    gak sekalian subwoofernya?.................
    Quote Originally Posted by rafiq sulaiman View Post
    ooomm....ada kejutan baru neh
    sekarang dah ada DD Indonesia !
    tapi barange paling gede M3 n 9512
    M3 udah kenceng lah wakakakakkakaa
Venom 300x250 Mitsubishi
  1. WTS : Midbass Usher 18W, 2 Way LM audio (Full Range + Midbass)
    By gudell97 in forum Speaker - SubWoofer
    Last Post: 5th July 2012, 14:30
  2. Replies: 0
    Last Post: 20th October 2011, 12:09
  3. WTB zelos full tube second
    By chien tjiputra in forum Power Amplifier
    Last Post: 7th March 2010, 21:54
  4. FULL TUBE AMP
    By vian11 in forum Power Amplifier
    Last Post: 3rd November 2009, 07:12
  5. DAIHATSU XENIA 2006 LI FAMILY FULL ORIGINAL
    By deni.sarifudin in forum Merk Lainnya
    Last Post: 9th February 2009, 03:37
