[SOLD !!] BRAX 2000.2 Graphic Edition - SOLD!!!
Results 1 to 10 of 53
  • Short URL:  http://modifika.si/145949
    Medan
    9 Hrs 57 Mins 52 Secs
    The uncompromising classical BRAX design has got the latest high end technologies. A complete new conceived circuit
    board and finest careful selected components are the features of the new models X 2000.2, X 2400.2 as well
    as both graphic editions. That guarantees their audiophile sound quality.
    The new generation has variable active crossovers per channel to guarantee the optimum operation of the loudspeakers.
    They can be used as highpass, lowpass or bandpass and they are switchable from 12 dB to 24 dB. The
    frequency range is from 15 Hz up to 4,5 kHz.
    The Graphic Edition is the optimized series of the legendary 2- and 4 channel Brax High End amplifiers in terms of audiophile sound quality and power. The transistors of the Graphic Edition are selected in more than 300 categories with a special developed measuring device.The most important lines on the circuit board are reinforced with silver wires, to avoid even the smallest lost of power that can affect the dynamic. Special made Burr-Brown OPs are used for the signal line to achieve an unsurpassable precise and natural sound reproduction. The extended heatsink is available in high-grade platinum color or chrome design.
    Special Features:
    - Fitted with High-End Burr Brown ICs for the best sound performance
    - Solid stainless steel name plate with individual lasered serial number
    - Exclusive heatsink design with platinum color or chrome finish
    - Transistor selektion in 300 categories, therefore very low tolerances
    - The perfect amplifier for the Brax High-End speaker systems
    - Packed in an exclusive wooden box
    Technical data X 2000.2 GE:
    Cont. power rating RMS at 4 Ohms : 2 x 265 Watts
    Cont power rating RMS at 2 Ohms : 2 x 440 Watts
    Cont power rating RMS bridged at 4 Ohms : 1 x 880 Watts
    Frequency range : 20 Hz - 20 kHz
    THD : < 0,001%
    TIM distortion : < 0,009%
    Signal to noise ratio : > 110 dB
    Input impedance : 10 kOhms
    Input sensitivity : 300 mV - 7,5 V
    Damping factor at 4 Ohms : > 600
    External fuse : 100 A
    Dimensions (H x W x D) in mm : 53 x 473 x 238
    Weight net : 8,2 kgs
    - Download Manualnya Disini -
    ada 3 Unit.
    Lengkap BOX, Manual dan Kelengkapan standardnya seperti FUSE.
    100% Segel alias NO SERVICE.
    Like New 99%
    bagi yang lokasi di Medan, bisa test dengar langsung.
    Bagi yang Borong 3 Unit (bisa untuk drive 3 Way), dikasih harga bagus..
    Harga Barunya 29 Juta / unit.
    SOLD !!!
    Call / SMS @ 08126446888
    2 Hrs 16 Secs
    kerennnnnn....
    malang
    11 Hrs 20 Mins 38 Secs
    Quote Originally Posted by jeam View Post
    kerennnnnn....
    bantu up boss
    barang mangsstabbss
    bandunk
    20 Hrs 16 Mins 30 Secs
    wuihhhhhhhhhhhhhhhh mantap
    klaten
    Wadaooo...wuihhh...mantapzz...bikin iler menetes tak henti2nya nih...
    2 Days 13 Hrs 1 Min 59 Secs
    mana kane blm nongol ,jgn2 dia pake ilmu ninja lg nih. tau2 brg lenyap aja
    Surabaya City
    1 Day 4 Hrs 32 Mins 23 Secs
    Mantabz Barang Nya Bro bantu Uppp Aja Dah.....:smt113
    klaten
    Quote Originally Posted by alpine View Post
    Hahahaa...bener banget boss...bang kane pasti uda "main belakang"
    wih...mantab banget nih ampli...:o
    kalo di beli semua trus pake...mobil bisa loncat2 kayak kena gempa kali yah....
    bantu up............ken buruan sikat.
  1. WTB : BRAX 2400.2 GRAPHIC EDITION
    By weha04 in forum Power Amplifier
    Last Post: 14th April 2012, 22:10
  2. WTS : BraX Graphic Edition 4&2 Channel + BraX X.2000 silver
    By prince jollibee in forum Power Amplifier
    Last Post: 1st February 2012, 15:02
  3. WTB: BRAX X2400.2 GRAPHIC EDITION
    By illusive562 in forum Power Amplifier
    Last Post: 25th July 2011, 19:30
  4. FS: BRAX Graphic Edition
    By godfather in forum Power Amplifier
    Last Post: 27th November 2009, 09:40
  5. brax 2.400 graphic edition
    By huhuy in forum Diskusi Power Amplifier
    Last Post: 13th April 2007, 00:13
