Cancelled
Results 1 to 10 of 14
Thread: Cancelled
  • Short URL:  http://modifika.si/145882
    2 Wks 6 Days 22 Hrs 55 Mins 37 Secs
    Cancelled
    2 unit ARC audio 2075 SE in perfect working condition and muluss kayak baru (no scratch or marks) Pemakaian 2 bulan beli dari baru masih ada garansi n segel lengkap box certificate dll.
    Bisa ditest denger suara saktinya mumpung blom dicopot..
    Maaf, cancel jualannya
    Spec:
    Audiophile sound quality based design
    Designed by Robert Zeff
    Class A/B switching design
    Microprocessor controlled design
    Microprocessor controlled Code based flashing diagnostics
    Concealed adjustment controls
    Open architecture adjustable crossovers on all channels HP/BP/LP/FP
    12/24Db per octave selectable crossover slopes on all channels
    Internal chassis force cooled speed controlled fan for optimum cooling
    Hi/Low level balanced switchblade RCA inputs for maximum system integration
    RJ45 Ethernet input connections for true balanced input connections
    Block type terminal connections
    256 color user selectable illumination circuit
    Combined Bias circuit and temperature regulation circuit to regulate bias and lower THD at any point in total thermal cycle
    Microprocessor high voltage power supply allows the amplifier to optimize power output at different ohm loads without the loss of efficiency or sound quality
    Vdrive based preamp stage improves efficiency lower internal signal loss
    Hand picked output devices used on all SE amplifiers.
    2 Channels @ 40hms 100 Watts 24A
    2 Channels @ 20hms 175 Watts 46A
    2 Channels @ 10hms 150 Watts 50A
    1 Channels @ 80hms 200 Watts 24A
    1 Channels @ 40hms 350 Watts 47A
    1 Channels @ 20hms 300 Watts 50A
    Frequency Response 4 Hz > 50kHz
    Crossover Range 30Hz - 550Hz (x10 300HZ - 5500Hz)
    Bass Boost 0 - 15dB @ 20Hz - 80 Hz
    S/N Ratio (a wtg) ref 1Wall 40hm >88 dB
    Separation @ 1kHz >70 dB
    Dampeninig (25W 2x40hm 100Hz) >2500
    Low Level Imput Sensitivity .3v - 4v
    Balanced Input Sensitivity .6v - 8v
    High Level Input NA
    Max Peak Current 20hm Mono 70A @ 571Watts 20% THD+ N
    Efficiency at rated 2ohm Stereo 52%
    Idle Current 1.14A
    Dimensions 13 "(L) X 8"(W) X 21/2 "(H)
  2. clickbet88.com
    klaten
    PERTAMAXXXX............
    barang mantabbb....numpang ngiler bosss.......
    14 Mins 59 Secs
    waduh bantu up barnag incaran . sayang dana lagi lom ada nih . tapi pm donk harga net ? pingin tau aja kira kira brp gitu
    klaten
    Quote Originally Posted by kurakuramabuk View Post
    HAJAAAARRR....SIKAAATTTT...........BUNGKUSSSS..... ..
    thx bos.. iya ni suaranya lebih mahal dari harganya
    dibayarin atuh bos masa diilerin doank... haha jk
    14 Mins 59 Secs
    Pm net donk ? garansi gak brg ?
    udah di PM bos kurakura
    10 Hrs 15 Secs
    bantu up boz buat ampli bagus
    1 Wk 2 Days 3 Hrs 17 Mins 28 Secs
    Up dulu buat power ok punya...
    thanks bos Harold & bos amirbotcek udah mampir
    ARC SE harga miring ayu dibeli...
  1. CANCELLED...
    By Doodee in forum Bursa Eksterior Lainnya
    Last Post: 27th April 2010, 00:35
  2. CANCELLED
    By Rihanna in forum Bursa Kaki Lainnya
    Last Post: 8th March 2008, 08:39
  3. cancelled
    By art_shit in forum Bursa Kaki Lainnya
    Last Post: 19th February 2008, 21:16
  4. CANCELLED
    By connection in forum Bursa Kaki Lainnya
    Last Post: 3rd February 2008, 02:38
