[WTS] POWER 5 CHANNEL SOUNDSTREAM EGA1000.5X
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/145763
    5 Days 2 Hrs 9 Mins 30 Secs
    1 unit power SoundStream EGA1000.5X
    kondisi sangat mulus dan belum pernah diservice
    harga silahkan tawar aja barangkali cocok langsung angkut
    Amplifier Specifications
    Number of Channels 5
    RMS Power (4 ohms) 50 watts x 4 chan, + 150 watts x 1 chan
    RMS Power (2 ohms) 100 watts x 4 chan, + 300 watts x 1 chan
    RMS Power (1 ohm) Not Stable
    Bridged RMS Power 200 watts x 2 chan, + 300 watts x 1chan
    Peak Power Output 1400 watts approx.
    Minimum Impedance Unbridged 2 ohms
    Minimum Impedance Bridged 4 Ohms
    THD at Rated RMS Power 0.02%
    Speaker Level Inputs No
    Preamp Outputs No
    Built-in Crossover N/A
    Signal-to-Noise Ratio >97 dB
    Bass Boost 0 - 18 dB
    Fan Cooled No
    Fuse Rating 30A x 3
    5-channel power amplifier
    fully regulated MOSFET power supply
    PWM circuitry
    tri-guard amplifier protection
    IDI (Intelligent Distress Indicator) gives a visual indication of the amplifier's protection status
    platinum RCA inputs and outputs
    bi-linear selectable crossovers for inputs and outputs (hi/ full/ low)
    continuously variable high and low-pass crossovers
    subwoofer equalizer control switch
    variable phase shift control (0 - 180)
    input select switch
    OEM floating ground input
    platinum 4-gauge power connectors
    tri-mode operation
    optional remote bass boost control (EGA - RM)
    dimensions (DxHxW): 22" x 2.4" x 11"
    hub 08128121112
    2 Mths 2 Wks 2 Hrs 10 Mins 54 Secs
    Quote Originally Posted by mj125 View Post
    hub 08128121112
    Pict nya dong bos.....
    Patokan harga brp ????
    pict menyusul
    patokan harganya 2jt nego dikit katanya
    pict menyusul
    kok katanya....?
    kata siapa tuh,...katanya ga gitu kali....
    he he he kata saya gitu
    sekalian update pict
    naikin dulu ah mumpung masih pagi
MBtech Venom 300x250
  1. Power Amp Soundstream Picasso 5.700 - 5 channel
    By hung tjoen in forum Power Amplifier
    Last Post: 8th September 2012, 20:55
  2. Jual Power Soundstream EGA1000.5X
    By carlo in forum Power Amplifier
    Last Post: 23rd July 2012, 17:02
  3. POWER SOUNDSTREAM 5 CHANNEL 830.5 MURAH SAJA....
    By tandy suhendra in forum Power Amplifier
    Last Post: 20th November 2010, 10:04
  4. Replies: 5
    Last Post: 6th September 2010, 22:51
  5. WTS: POWER SOUNDSTREAM MC 300 4 CHANNEL 300 WATT
    Last Post: 15th October 2009, 10:53
