RE Audio (US Amps) XT-800.4v2 Xterminator (sold.thanks modcom....)
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/145724
    Cool RE Audio (US Amps) XT-800.4v2 Xterminator (sold.thanks modcom....)
    RE Audio (US Amps) XT-800.4v2 Xterminator v2 Class "AB" 4-Channel Amplifier kondisi NOS.......sold
    XTv2 | Series HIGH-POWER Amplifiers
    "RE Audio's First Series of Amplifiers"
    The NEW XTv2 series is the replacement for the most popular U.S. Amps XT (Xterminator) series. This new XTv2 series touts many new design refinements and upgrades. With its new "Elevated Efficiency Platform", you are guaranteed the same abundance of power, but with much less drain on the charging system.
    PRICE $300.00
    Description :
    * Number of Channels: 4
    * Rated Power:
    o 70W x 4 @ 4 Ohms RMS
    o 120W x 4 @ 2 Ohms RMS
    o 230W x 2 @ 4 Ohms Bridged RMS
    * Total Power: 400W
    * Bridgeable: Yes
    * Efficiency (average):
    o 71% @ 4 Ohms
    o 70% @ 2 Ohms
    * Variable Crossover Control:
    o Front/Rear High-Pass: 40-1kHz, 12dB/Octave, Butterworth
    o Front/Rear Low-Pass: 40-250Hz, 24dB/Octave, Butterworth
    * Variable Bass EQ: 30dB Boost @ 45Hz
    * Subsonic Filter: 15-40Hz, 24dB/Octave
    * Signal-In: Low level, 1 RCA Pair
    * Signal-Out: Pass
    * Power Connector: Block
    * Power Connector Gauge: 4 AWG
    * Speaker Connector: Screw Terminal Barrier Strip
    * Speaker Connector Gauge: 8 to 18 AWG
    * Heatsink Type: Aluminum
    * Cooling: Convention
    * Remote Control: Optional, Rear Channels Only
    * Indicator: Power, Protect
    * Class: Class A/B
    * Frequency Response: 5Hz-50kHz, +/-1.0dB
    * Weight (lbs / Kg): 10 / 4.5
    * Dimension (H x W x L: in / mm): 1.875 x 10 x 14.75 / 48 x 254 x 375
    call
    081388575788
  2. clickbet88.com
    PangkaL Paha
    2 Wks 5 Days 7 Hrs 45 Mins 39 Secs
    Awwww.... eikeh keduluaaan boooo....
    Powernya boss MR. GASOLINE mangstap bener niy. Hehehehehehe....
    Boss, mono Hifonics ada yg lbh gede lagi nggak? Cyclops, Thor, Goliath gitu.
    -Thanx-
    klaten
    bantu up aja boss Chris.....
    barang nya ampunnn.....kaga ada matinye.....
    he..he..he..,hifonics yang gede lg ga ada bos.....
    thanks ya bang kane,bos pemula n bos danny.........
    up.............
    up............
    up..........................
  1. WTS : US Amps 2000X (SOLD THANKS TO MODCOM)
    By Chanexis in forum Power Amplifier
    Last Post: 27th October 2009, 21:20
  2. Replies: 65
    Last Post: 9th August 2009, 19:03
  3. Replies: 23
    Last Post: 20th June 2009, 06:29
  4. Replies: 31
    Last Post: 18th June 2009, 19:28
