(Pelumas) Jual Oli Mobil Berkualitas Tinggi & 100% Imported From USA : Coastal
  • Short URL:  http://modifika.si/145023
    Halo Mod Comers...
    Saya Dari Autorize Dealer Coastal Jakarta Mau Jual Oli Untuk Mobil Anda
    Berikut Jenis-jenis Oli nya:
    Motor Oil
    1.Full Synthetic 5W-30
    Grade:Full Synthetic
    SAE:5W-30
    API SERVICE:SM
    2.Full Synthetic 10W-30
    SAE:10W-30
    API SERVICE:SM
    Spoiler for Penjelasan Full Synthetic: Show
    Coastal Full Synthetic Motor Oils are superior-quality, high detergent automotive engine oils specially formulated to meet the stringent lubrication requirements of today's engines.
    Synthetic base oils combine with a carefully selected additive package to provide maximum protection against wear, rust, corrosion, oxidative thickening, acid formation, sludge and varnish deposits. Meets the Energy Conserving category and is ILSAC GF-4, API SM approved.
    3.Synthetic Blend 10W-40
    Grade:Synthetic Blend
    SAE:10W-40
    API SERVICE:SL
    4.Premium Motor Oil 5W-20
    Jenis:Mineral
    SAE:5W-20
    API SERVICE:SM
    5.Premium Motor Oil 5W-30
    Jenis:Mineral
    SAE:5W-30
    API SERVICE:SM
    6.Premium Motor Oil 10W-30
    Jenis:Mineral
    SAE:10W-30
    API SERVICE:SM
    Spoiler for Penjelasan Premium Oil SM: Show
    Coastal Premium Energy Conserving Motor Oils are superior-quality, high detergent automotive engine oils specially formulated to meet the stringent lubrication requirements of today's engines. High-viscosity-index base oils combine with a carefully selected additive package to provide maximum protection against wear, rust, corrosion, oxidative thickening, acid formation, sludge, and varnish deposits.
    Coastal Premium Energy Conserving Motor Oils meet or exceed the requirements of ILSAC GF-4 Energy Conserving, API Service SM, MIL-L-46152E, Ford M2C153E, GM-6048M, and 6049M.
    Coastal Premium EC Motor Oils also give excellent performance in engines operating on LPG fuel.
    7.Premium Motor Oil 10W-40
    Jenis:Mineral
    SAE:10W-40
    API SERVICE:SL
    Kemasan:1 Quart(0,946 Liter) & 1 US galon (3,785 Liter)
    8.High Perfomance Motor Oil 20W-50
    Jenis Mineral
    SAE:20W-50
    API SERVICE:SL (Untuk Ukuran Liter)
    API SERVICE:CI-4/SL (Untuk Ukuran Galon)
    Diesel Oil
    9.Fleet HD 15W-40
    SAE:15W-40
    API SERVICE:CI-4/SL
    Kemasan:1 Quart(0,946 liter) & 1 US. Galon (3,785 Liter)
    Spoiler for Penjelasan Premium Oil Fleet: Show
    Coastal HD Fleet Motor Oils are premium quality engine oils meeting the requirements of diesel and gasoline engines requiring an API CI-4 (15W-40), CF-4 (15W-40), CH-4 (15W-40) and CG-4 (15W-40), CF-2, CF, SL, (15W-40, 30, 40, 50). They are designed for use in both turbocharged and naturally aspirated diesel engines and meet the requirements of all diesel engines used in heavy duty trucking, construction, mining, and farm equipment.
    Gear Oil
    10.Synthetic Blend Gear Oil 75W-90
    GRADE:Synthetic Blend
    SAE:75W-90
    API SERVICE:GL-5
    11.Premium Gear Oil 75W-90
    GRADE:Mineral
    SAE:75W-90
    API SERVICE:GL-5
    12. Premium Gear Oil 80W-90
    GRADE:Mineral
    SAE:80W-90
    API SERVICE:GL-5
    13.Premium Gear Oil 85W-140
    Grade:Mineral
    SAE:85W-140
    API SERVICE:GL-5
    Spoiler for Penjelasan GL-5: Show
    Coastal GL-5 Gear Oils are multi-purpose sulfur/phosphorous type gear lubricants designed for API Service Classification “GL-5. Coastal GL-5 Gear Oils are compounded with highly refined base stocks and additives to ensure extreme pressure characteristics, antiwear, corrosion inhibition, rust preventions, low pour point, and antifoaming tendencies. Limited Slip applications for top-off only. Coastal GL-5 Gear Oils are recommended for use in passenger cars, light duty trucks and sport utility vehicles. Always check owner’s manual for proper recommendation.
    Benefits
    • Excellent wear protection
    • Shear resistant
    • Oxidation and thermal stability for long life
    • Excellent rust and corrosion protection
    Coastal Synthetic Blend SAE 75W-90 Gear Lubricant is manufactured with a unique blend of synthetic fluids, high quality mineral base oils and additives to provide excellent load carrying ability, extreme pressure (EP) properties, wear resistance, oxidation stability, and protection against rust and corrosion. It is recommended for make-up and complete refill of all passenger car and light truck conventional differentials, transmissions and steering gears, top-off only for limited differentials, and gives performance© beyond that of conventional gear oils.
    Coastal Synthetic Blend Gear Lubricant contains sulfur and phosphorus additive metals, but no zinc, in compliance with Eaton, General Motors, Mack GO-J, and International Harvester requirements for truck driving axles. It meets the specifications of MIL-L-2105D and is recommended for use where an API GL-3 , GL-4, or GL-5 oil is required. Coastal Synthetic Blend Gear Lubricant is fully compatible with conventional gear lubricants.
    Transmisi Oil
    14. ATF +4
    Jenis:Transmisi Oil
    API SERVICE:+4
    15.Multi Vehicle Synthetic Blend ATF
    Jenis:Transmisi Oil
    Spoiler for Penjelasan Multi Vehicle Synthetic Blend ATF: Show
    Multi-Vehicle Synthetic Blend Automatic Transmission Fluid is a premium quality, semi-synthetic transmission fluid designed for use in automatic transmissions in most domestic and import passenger cars and light trucks. This fluid has been formulated to provide smooth shifting and excellent anti-shudder performance in a wide variety of vehicles. It has exceptional shear stability and oxidization resistance of long service life, providing excellent wear protection, and helps protect against sludge and varnish buildup. Approved for ZF application TE ML 03D, 04D, 14B, 16L, and 17C. Suitable for use in most Honda/Acura, Hyundai, Jeep, Mercedes-Benz, Mitsubishi (Diamond SP II or SP III), Nissan, (Matic D, J or K)/Infiniti, Saturn, Toyota (T-III & T-IV)/Lexus/Scion, VW/Audi, most European vehicles including BMW & Volvo, most Asian vehicles including Daewoo, Isuzu, Kia, Mazda and Suzuki. Multi-Vehicle Synthetic Blend Automatic Transmission Fluid is not for use in transmissions requiring Ford Type F or DEXRONVI, or in Continuously Variable Transmissions (CVT) applications.
    16. ATF D/M
    Jenis:Transmisi Oil
    API SERVICEEXRON III
    Spoiler for Penjelasan ATF D/M: Show
    Coastal Automatic Transmission Fluid D/M is a new generation automatic transmission fluid that is approved for H specification and recommended for use in automobile
    and truck automatic transmissions, power-shift transmissions, and other types of service requiring an approved and licensed GM DEXRON III (H) or Ford MERCON automatic transmission fluid (also exceeds the requirements of DEXRONIII, DEXRONIIE, IID, and II specifications).
    Coastal Automatic Transmission Fluid D/M is also approved for industrial transmission requirements such as Allison C-4, Caterpillar TO-2, and Ford specifications M2C138-CJ and M2C166-H. This fluid has excellent low temperature flow characteristics and offers outstanding resistance to oxidation, rust and corrosion, resists foaming, aeration, and excessive thinning at high operating temperatures. This fluid is dyed red for easy identification.
    Semua Produk Coastal 100% ASLI!! Barang Ini di Import Langsung Dari Amerika
    Website Coastal:http://www.warrenunilube.com/home.html
    Barang Lokasi Berada Di Jakarta Barat
    Untuk Daerah Luar Jakarta,saya akan memberikan Total Harga dan Biaya kirim. Kemudian Barang dikirim bila uang sudah masuk ke Rekening.
    Bagi Yang Berminad Silahkan PM saya segera
    atau dapat menghubungi saya di
    021-56969094 (Andres / Novena)
    Berikut ADalah Beberapa Testimonial Dari Member Mod.com
    Spoiler for Testimonial: Show
    Daftar Testimonialnya:
    Quote Originally Posted by RETROtuning View Post
    Gw jagoin deh enak makenya kerasa enteng mesinnya,gw pmake coastal premium 10w/40 sm yg full shyntetic blend 10w/40
    Bos distributor di jkt?ato dr bdg?Hi2
    Bkn promosi tp ni oli asli USA,beda dgn TO*1 yg katanya dr US gataunya lokal,hi2
    Quote Originally Posted by accord_maniac View Post
    bos, kiriman nya ud nyampe...
    barang ny maknyus nih
    Quote Originally Posted by NL View Post
    Gue uda pakai bro yg untuk diesel hasil nya suara mesin jadi lebih halus dan tarikan maknyus bro....
    Quote Originally Posted by 25voque29 View Post
    uda pake ni yang 10-30 full syn, n oli transmisi 80-90. bagus jadi enteng mobil innova saya.. hehe..
    octane booster nya juga ngefek..
    Sundul Lagi Gan...
    2 Wks 2 Days 3 Hrs 48 Mins 26 Secs
    Buat dipake harian bagus 10-40 syntetic blend atau 10-40 premium boss?? mobil ane All New City boss
    PM hargan ya boss
  1. Replies: 227
    Last Post: 11th December 2012, 21:15
  2. Jual oli pelumas mobil super 2000 PROMO
    By rizkyriz in forum Jual Beli Mesin Lainnya
    Last Post: 18th July 2012, 16:42
  3. Replies: 31
    Last Post: 2nd July 2009, 10:45
