PIVOT Performance Products
Page 1 of 31 12345 ... LastLast
Results 1 to 10 of 301
  • Short URL:  http://modifika.si/144998
    PIVOT PERFORMANCE PRODUCTS
    3-drive Throttle Controller
    New Version Flat :
    # Mode Memory
    The "Same as Last" mode allows you to re-start your engine in the same mode as last time.
    If you wish to start the engine in "Normal" mode, wiring can be done to IGN.
    # 3 Modes
    Possible to change between three modes: SPORTS mode for higher acceleration response, ECO-mode for lower response and NORMAL mode for standard response.
    # 12 steps
    In the SPORTS mode, seven step ECO mode is a detailed adjustment of 12 all steps of five steps.
    # Acceleration Monitor
    Open times of the accelerator (amount of depressing) are displayed and it is convenient for the eco-driving etc.
    # Easy Installation
    Easy installation using car model specific coupling harness.
    # Initial Settings
    Initial settings can be made for each type of car making it compatible with a wide range of models.
    # Digital Circuitry
    The high-speed circuitry signal output is not affected by temperature or noise and hence guards against troubles and failures.
    # Normal Control when in Reverse
    When the vehicle is put into reverse it will automatically return to normal acceleration (wiring where necessary). However, usually when using reverse the degree of acceleration is at most about 10%; in this range there is hardly any change so it is not necessary to wire for using reverse.
    # Safety System
    The acceleration mode will automatically be returned to "Normal" if the product should break or fail, or if the two signals should separate.
    # Graphs
    # Singkat nya dalam bahasa saya:
    Fungsi nya memanipulasi besar nya bukaan skep throttle body untuk meningkatkan respon mesin (pada saat di setting di posisi SP = Sports Mode 1-7) dan untuk mengurangi respon mesin (pada saat di setting di posisi EC = Economic Mode 1-5).
    Contoh : Pada saat di setting pada posisi SP5, maka respon kedaraan pada saat pedal gas di injak akan lebih responsif dibandingkan dengan pada saat SP3 atau pada kondisi Normal tidak menggunakan Pivot 3 Drive Throttle Controller. Peningkatan kenaikan RPM akan lebih cepat tercapai.
    Sebalik nya pada saat di setting pada posisi EC5, maka respon kendaraan pada saat pedal gas di injak akan tidak seresponsif dibandingkan dengan pada saat posisi EC3 maupun Normal yang tidak menggunakan Pivot 3 Drive Throttle Controller.
    ----- end of 3-drive throttle controller -----
    Racing Monitor
    Blue Display
    Red Display
    # For all styles of driving: from Racing to Eco.
    A display comes from easy install and selected for driving. RM-7 displays 5 categories information for racing. You can concentrate on driving, because RM-7 does not display useless information. The model which many drivers used habitually added a method of wiring to easy install. From full-scale race like a circuit and a rally to an eco-driving, you can use this device at many fields.
    # Installation
    Just connect to the diagnostic monitoring connector (OBD Socket)
    # Features
    - Speed Meter
    - RPM Meter
    - Water Temperature
    - Sequential Shift Lamp 3 LED
    - Gear Position (In some car models, there is no output of the gear position and hence it can not be displayed. Please check the list of compatible car models before purchasing this unit)
    Fungsi nya sebagai monitor yang secara digital menunjukkan kecepatan kendaraan, besar nya RPM, suhu atau temperatur air radiator, indikator perpindahan gigi dan posisi gigi transmisi (khusu model tertentu)
    ----- end of racing monitor -----
    Speed Meter
    # Features
    - Highly accurate digital speed meter
    - Speed limiter remover function
    - G-Force meter
    - Measurement 0-100 meter, 0-200 meter, 0-300 meter & 0-400 meter
    ----- end of speed meter -----
    Rev Lamp X-Type & Z-Type
    Combination Shift Lamp and ECO Lamp!
    The Rev Lamp (highly luminous LED) will come on as a warning whenever the set engine RPM has been exceeded means optimal driving without having to pay attention to the tachometer. Moreover, being able to make RPM settings for both “Sports Driving Mode” and “ECO Driving Mode” gives you one-touch freedom to choose either improved acceleration response or better fuel efficiency.
    Perfect for Cars “with” or “without” a Built-in Tachometer
    The controller includes and built-in tachometer and allows one-touch RPM settings. This makes it perfect for all types of cars, whether equipped with a tachometer or not!
    ----- end of Rev Lamp -----
    Mega Raizin
    # Note
    By increasing the capacity of the condenser three-fold (compared to Blue RAIZIN), and decreasing both circuitry noise and high frequency impedance the results have been a more stable supply of voltage to all electronic devices, better gas mileage, and improved torque and audio quality.
    # Package
    Sold in a package of Mega Raizin unit module with Grounding Wire..!
    Fungsi nya sebagai penyeimbang voltase kendaraan yang pada umum nya tidak stabil terutama pada malam hari dimana kendaraan mempergunakan banyak tegangan untuk menghidupkan lampu, AC, sistim audio, dll.
    Supply tegangan voltase kendaraan tidak pernah stabil di 12 Volts, sehingga dengan voltase yang stabil seluruh komponen elektrik mulai dari ECU (otak mesin), Lampu, Audio, dll akan bekerja dengan maksimal dan keawetan komponen2 elektrik tersebut juga akan terjaga.
    Perbedaan Pivot Mega Raizin Ungu dengan Pivot Raizin Biru (Versi Terdahulu) adalah pada Pivot Mega Raizin kapasitor yg dipergunakan lebih banyak dan lebih besar, sehingga keseimbangan voltase akan menjadi lebih baik dibanding dengan Pivot Raizin Biru.
    Juga pada Pivot Mega Raizin terdapat indikator digital yg menunjukkan angka besar nya voltase kelistrikan mobil anda.
    ----- end of mega raizin -----
    Raizin Ignition Spark Type-S
    [b]Brings out 100% of your ignition's coil performance..![b]
    # Note
    Until now, due to various types of load resistance and interference at the contact terminals, fuses, contact points and cords in the electric circuitry on the way to the ignition coil, major loss occurred and optimum combustion did not take place. To help solve this the Raizin Spark utilizes a new approach in voltage stabilizer devices for ignition coils that brings out 100% of your ignition's performance by providing point blank power to the ignition coil via connection to our specially designed circuitry. This in turn gives you dramatic improvement in engine performance from optimum ignition to ideal combustion.
    Type S can be easily wired by a one-touch connection to the interior fuse box (ignition). It is also possible to switch the power between +B (normal power) and IG+ to match your car model setup. Moreover, peace of mind comes in knowing that the unit is equipped with a delay circuit to avoid trouble caused by power bursts during battery recharging when using IG+ ON.
    # Illustration
    Spark Performance (WITHOUT Raizin Ignition)
    Spark Perfromance WITH Raizin Ignition
    Fungsi nya untuk menjaga dan memperbaiki kualitas api pada coil sehingga tidak terjadi missed fire/kesalahan percikan terutama pada saat RPM tinggi dimana mesin menuntut kesempuraan pengapian, supply bahan bakar dan jumlah udara yang mumpuni.
    Dengan menghasilkan pembakaran yang baik, kinerja mesin akan menjadi lebih baik dengan sendiri nya.
    ----- end of raizin spark -----
    Spark Earth
    earth system with built in stabilizer CHANGE NOISE INTO POWER..!
    # Note
    Engine performance is greatly improved due to a more stable ignition which is brought about by the double effect of a strengthened earthing system and the noise filter circuitry that quickly suppresses noise when the ignition coil fires.
    # LED Monitor
    The specially low energy consumption designed LED allows you to check operation status without putting a strain on your battery.
    # Waterproof
    The circuit board has a waterproof coating and an internal fuse to give you extra assurance against wet conditions.
    # Features
    - Improving Engine Torque
    - Improving Response
    - Improving Engine Kick Over
    - Gas Milage Efficiency
    # Graph
    Untuk memperkuat tahanan voltase pada saat coil bekerja, sehingga pengapian mesin lebih stabil yang dapat meningkatkan performa mesin.
    ----- end of spark earth -----
    Ignition Earth
    Advantage of this composite earth cable is to Improve Combustion.
    # Features
    - Improve Engine Power
    - Improve Engine Kick Over
    - Good Stabilized Idling
    By increasing the speed of ignition from the start, combustion is improved
    The high frequency waves that occur upon ignition are the primary element in the delay of initial voltage in the ignition coil which secondarily causes the slowdown of initial firing speed resulting in the poor combustion. Due to this one effective method was to add earth between the ignition coil ground and the battery minus. But because the higher frequency waves run through the only the narrow space on the outside wall of the wire conductor, the results were minimal at best. But because the IGNITION EARTH cable has been designed with as a composite type cable with a wire for high frequencies built-in and an outer wall circumference 2.5 times normal, the results are increased conductivity for high frequency waves, faster initial speed upon ignition, and the facilitation of ionization during combustion, which in turn improves gas mileage and engine torque.
    # Comparison
    The additional earth wire on our Composite Earth Cable has a conductor circumference 2.5 times the normal wire. This improves the firing speed by reducing voltage loss and increasing conductivity of high frequency waves released by the ignition coil. Moreover, by facilitating ionization during combustion, it improves gas mileage and engine torque. (Patent pending)
    ---> Normal Wire Earth
    ---> Pivot Ignition Earth
    Untuk meningkatak kecepatan percikan pada coil, sehingga kinerja pembakaran menjadi lebih baik yang dapat meningkatkan performa mesin.
    ----- end of ignition earth -----
    Radiator Cap
    Fortified main pressure valve spring and silicon packing are used to raise the pressure inside the radiator for a higher boiling point. The coolant will not boil easily, prevents air bubbles in the block and radiator core with improved heat transfer.
    PIVOT's high pressure radiator caps works at 1.3kg/cm2 at zero atmospheric pressure. In practice though, the atmospheric pressure of the road surface (approximately 1.0kg/cm2) is added and the pressure is 2.3kg/cm2.
    In summary, Pivot Radiator Cap:
    - Increases pressure of radiator up to 1.3 Bar.
    - Improves radiator cooling.
    Available in 2 models:
    a) RC-1 for Honda NSX, Mazda RX-7 (FC/FD), Miata, Mitsubishi 3000GT, EVOs, Nissan all models, Subaru all models, Toyota MR2, AE86 Corolla GT-S.
    b) RC-2 for Acura Integra/RSX all models, Honda Civic all models, Toyota AE101, AE111, Supra all models.
    ----- end of radiator cap -----
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    Semarang
    2 Wks 2 Days 11 Hrs 43 Mins 27 Secs
    Mas, tuh pivot spark sama earth harganya brapa?
    Buat BMW X5 bisa ga tuh?
    Thanx...
    Quote Originally Posted by Upszzz View Post
    Thanx...
    eh si danu..
    terus terang blm pernah pasang di bmw sih.. jadi mesti cek ke installation direction di package nya dulu.
    CP : Coki Siboro
    klo bwt swift yang bagus pasang yang mana ya?
    rekomen.
    Quote Originally Posted by AJ_14 View Post
    rekomen.
    banyak sih kalo mau di rekomen..
    - mega raizin atau raizin blue (pilih salah satu)
    - ignition spark (red)
    - ignition earth
    - spark earth
    - racing monitor
    CP : Coki Siboro
    43 Mins 30 Secs
    Quote Originally Posted by coki.de auto View Post
    # Mode Memory
    # 3 Modes
    # 12 steps
    # Easy Installation
    # Initial Settings
    Inisital settings can be made for each type of car making it compatible with a wide range of models.
    # Digital Circuitry
    # Safety System
    # Graphs
    Racing Monitor
    Blue Display
    Red Display
    # Installation
    # Features
    - Speed Meter
    - RPM Meter
    - Water Temperature
    Speed Meter
    # Features
    - G-Force meter
    Sequential Shift Lamp SSL-PRO
    # Features
    - Shifting points setting
    According to the set RPM, the 1st warning lamp will go on, the 2nd will go on and at the shift point all 3 lamps will blink.
    - Red LED Lamp
    ----- end of SSL-PRO -----
    Raizin Volt Stabilizer
    # Note
    Voltage stabilizer in combination with supplementary earth bring you
    electrical efficiency. Raizin brings you not only ideal electrical efficiency and voltage supply stabilization, but with our original circuitry design and our special noise reduction condenser you can enjoy diminished noise and lessened
    high-frequency impedance.
    # Features
    Our confidence in performance means we can make a see-through case.
    - Our special condenser and our original circuitry design bring you voltage stability.
    - A blue LED helps you identify any possible wiring mistakes.
    (Even with the key off, the LED only uses 0.5mA of power, so no need to worry about a dead battery)
    - Internal Dual Fuse to help prevent electrical shorts.
    - Heat resistant (to 125░C) case will not change shape.
    - Circuitry has waterproof coating. (But do not to install in areas subject to water or spray with water)
    # Package
    Sold in a package of Raizin Volt Stabilizer unit module with Grounding Wire..!
    ----- end of raizin blue -----
    Mega Raizin
    # Note
    # Package
    # Note
    # Illustration
    Spark Earth
    # Note
    # LED Monitor
    # Waterproof
    # Features
    # Graph
    Ignition Earth
    # Features
    # Comparison
    Bos mo tanya harga Sequential Shift Lamp SSL-PRO ,,,
    Bisa pasang di Terios ??
    Thanks PM pls (kenmail_ri@yahoo.com)
    Quote Originally Posted by passeoo73 View Post
    pada prinsip nya ini part universal, tp untuk detail, mesti cek di list mobilnya dulu sih bos..
    CP : Coki Siboro
    solo - D'cellular
    2 Days 13 Hrs 4 Mins 37 Secs
    ini gunanya bwt ap bozz ????
    ap spt shift light + modul . . . .
    harga ????
    pasang nya gampang kah ????
    thxz
    solo - D'cellular
    3-drive Throttle Controller , ini jg bwt apa y bozz ?????
    dukung bwt performa kah ????
    thxz again
    Quote Originally Posted by D_ndy View Post
    harga ????
    thxz
    yup, itu shift light dan modul controller nya..
    dibilang sequential karna jumlah lampu nya ada 3 LED.
    bisa set LED pertama untuk hidup di RPM tertentu misal RPM 4500 dan yg kedua di RPM 5500 dan yg ketiga di RPM 6500 pada saat shifting.
    pada saat hidup di settingan RPM 6500 ketiga lampu akan nyala kelap-kelip, dan biasa nya itu timing yg bos set up untuk shifting.
    CP : Coki Siboro
  1. [SS Performance] New Pivot Rev lamp..
    By ss in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 15th August 2011, 16:25
  2. WTS : Products Ex Display and Used Products
    By CARTENS in forum Power Amplifier
    Last Post: 21st February 2011, 13:48
