kabel optik untuk upgrade pxa............(sold,thanks modcom...)
Results 1 to 10 of 20
  • Short URL:  http://modifika.si/144273
    Cool kabel optik untuk upgrade pxa............(sold,thanks modcom...)
    2pcs kabel optik untuk alpine
    1pc MONSTER CABLE Interlink® LightSpeed™ 100 High Performance Digital Fiber Optic Cable dan 1pc kabel optik ga tau merknya nich bos,tapi suarnya ok bos,diatas standardnya alpine......sold
    1 m. fiber optic toslink-to-toslink ILS100-1M 109512-00 $39.95 ea.
    • High velocity of propagation for less time smear.
    • Tuned spectral attenuation for optimum signal admittance and low loss.
    • Monster's precise fiber optic connection delivers higher sonic performance than standard cables.
    FEATURES
    Highest Resolution Digital Interconnect Cable with Precision Termination for Accurate Sound Reproduction.
    Ordinary Toslink Cables with Ordinary Construction Deliver Ordinary Sound
    While the variety of digital sources on the market continues to grow, the availability of high quality fiber optic cables has lagged far behind. Cables with Toslink connections abound; finding one that lives up to the level of performance required by a digital source however, is no easy task. In fact, most Toslink cables feature second - rate construction and cheap materials. The result? Inferior data transfer Ð a landline for the enthusiast in search of the better sound digital components are capable of delivering. Interlink LightSpeedª 100 Fiber Optic Cable: Precision Polishing and Rugged Design Make the Difference LightSpeedª 100 offers high performance and value in a durable design.
    A high density molded PVC connector boot with heavy - duty strain relief provides superior protection of the delicate fiber
    The fiber itself is encased in a protective, flexible Duraflex jacket that makes routing through entertainment furniture and shelving easy. A precision - polished termination and specially tuned fiber deliver incredibly accurate transfer of digital audio source signals. The resulting reduction in jitter-causing dispersion in the digital datastream means smoother, more natural sound. And because ILS100 is a purely optical means of transferring bit streams, you wont run the risk of annoying ground problems like hum and buzz.
    Monster's Precision Polished Toslink Connection Maximizes Transmission
    Traditionally, connections have proven to be the weak link in fiber optic design. Monster has overcome this obstacle by precision - polishing our connections for a perfect termination of the fiber. The result is high signal transmission, low internal reflection and minimization of jitter and time distortion for cleaner, more natural sound. Get the Best Possible Digital Audio Performance
    Whether decoding a Dolby Digital or DTS soundtrack, enjoying the pleasure of a high performance DAC, or recording your favorite music, Interlink LightSpeedª 100 delivers clean, natural sound.
    call
    081388575788
    up.............
    up.................
    up................
    up.................
    up...............
    up.................
    up....................
    up......................
    up.............
  1. Pengaruh pake kabel optik supernova untuk Pxa 701..
    By imin in forum Diskusi Audio Lainnya
    Last Post: 19th April 2014, 13:54
  2. Replies: 9
    Last Post: 1st August 2011, 20:02
  3. 5M ALPINE kabel optik....................(sold,thanks modcom...)
    By MR.GASOLINE in forum Bursa Audio Lainnya
    Last Post: 9th January 2010, 05:46
  4. 2m kabel optik flex tech untuk upgrade alpine (sold,thanks modcom...)
    Last Post: 9th August 2009, 19:58
  5. wts: kabel optik wireworld sold.........
    By leon9 in forum Bursa Audio Lainnya
    Last Post: 19th June 2009, 07:03
