[RARE COLLECTION] Andy Lau format LPCD45 (CD se-Analog Piringan Hitam) DLL
Results 1 to 10 of 95
  • Short URL:  http://modifika.si/143685
    Medan
    9 Hrs 57 Mins 52 Secs
    RARE Collection Mantap bagi Penggemar AUDIOPHILE !!
    - Copy Langsung dari MASTER, tidak dicopy secara berantai.
    - CD Blank Verbatim Gold
    - Lowest Speed waktu Recording
    - Tidak di Label supaya CD tidak menjadi terlalu tebal
    Paket 4 cd apa saja : hanya Rp. 100.000 (normal 112rb blum ongkir)
    Kalau Ambil semua (6 cd + 1 dvd Master) Total rp. 200.000 (Normal 218.000 belum ongkir)
    ambil Paket FREE Ongkos Kirim seluruh Indo.
    SMS Orderan langsung ke 08126446888
    1. Buat Penggemar Andy Lau yg ingin mendengarkan suara andy lau dalam CD Album dalam Format LPCD45.
    harga 28.000
    LPCD45 di klaim memiliki suara se analog Piringan Hitam karena melalui proses rekaman yg di produksi dari HUGO Production. (silahkan lihat dibawah sekilas tentang LPCD) ..
    Sekilas Tentang LPCD bagi yg baru tau :
    LPCD: Artistic Sense + Advanced Technology
    LPCD is the latest and most advanced technology researched and developed by Mr Aik Yew-Goh, the founder of Hugo Productions.
    Mr Aik is a renowned recording producer and musician who spends 35 years in musical experimentations and 20 years in professional music production. LPCD is developed based on a unique set of digital processing technology which enables listeners to experience the analogue sound of the vinyl LP record from an ordinary CD player.
    Mr Aik has been researching this technique for a long time. He has produced over 300 music records in the last 20 years. Every time when he compared these recordings with the master tapes, he would find that there was a difference in the audio quality, but he was unable to work out a solution due to his busy schedule in music productions. Until 2003, after producing two LPs, Mr Aik revisited this subject and did a detailed analysis on the sonic differences between CD, XRCD, SACD, etc., to pinpoint the reason why the CD and LP differ much in their tonal quality.
    The general consensus among most audiophiles being that when comparing with LP, CD (including normal CD, 24K CD, XRCD, SACD and DVD-Audio) would sound tight, tensed and compressed (especially when playing at loud sound level, one would find it difficult to maintain concentration in appreciating the music and the sound system). Besides, the lack of extension at the low and high sonic frequencies has resulted in a harsher treble, inelastic bass, poor dynamics, etc. Being an LP audiophile, Mr Aik is well aware of the problem. He reckons that the only way to seek out the answer is to listen to his own recordings extensively and repeatedly, before he is entitled to voice his views.
    Presently, the manufacturing of CD from the master tape requires changing the digital audio formats 5 to 6 times in the following processes: Master Tape - Master CDR - Glass Master - Metal Stamper - Pressing - CD. The last two processes are especially important as they could make or break the sound quality. It is common knowledge to audiophiles that whether it is LP or CD, the first pressing always sounds the best. A simple experiment of duplicating a CD 5 or 6 times on a home computer will prove that the last pressing will sound much inferior to the original CD.
    How then to ensure that audiophiles who have been faithfully supporting the HUGO Label can enjoy the highest level of sonic fidelity? Having identified the digital distortion problem of CD, Mr Aik has focused his research of the LPCD in the following two parameters:
    1. LPCD mastering
    Applying HUGO's proprietary sonic spectrum processing software system on the following procedures:
    (a) Using the highest specifications to convert the original analogue master tape into a digital format;
    (b) Upsampling the original digital master to the highest specifications. Thereafter, adjust the tonal density, dynamic range, bandwidth, etc., using a highly precise digital processing system. Finally the digital master is encoded into a 16 bit/44.1KHz CD format. Throughout the entire digital processing, the digital system is operating in an optimal configuration with the highest purity of the AC power supply and a highly precise, military-grade digital clock. All the equipment used were protected by a proprietary anti-vibration system to ensure that all the components and the production process are free of distortion.
    Although the top-notch equipment can effectively benefit the mastering production, mastering process is still very much a complex manual project which requires the mastering engineers to apply their skill and artistry meticulously at each step of the process. It is therefore not just a simple technical "transfer" from one medium to another. It is hardly surprising that the mastering of a LPCD takes a labourous 20 studio hours!
    2. LPCD Production
    The primary objective is to minimize the signal distortion of the digital laser reading system embedded in the CD player, and the "over-correction" by the signal correction system. In addition, a specially treated material is used to eliminate the diversion of the laser beam; thereby improving the accuracy of the laser output signal, enhancing the stability of the disc rotation, reducing the rumple and flutter rate. All of these help to reduce the pressures on the CD servo-system which otherwise can generate signal loss and distortion.
    After numerous experimentations, the above process is finally adopted to produce the LPCD. What is presented to audiophiles is a disc which is many times more precise than the ordinary disc. Very fine artistry is put into the stamping / pressing processes as well as the digital format change processes to eliminate any significant noise intrusion. Special material is also used to help preserve and enhance the durability of the LPCD.
    Hugo Productions not only produces its own LPCDs, it also provides the technical expertise to other companies or producers to manufacture the LPCDs on the premise that the recordings qualities are of the highest level.
    LPCD products are classified into two categories, i.e. LPCD33 and LPCD45. LPCD33 is a specially manufactured CD product whereas LPCD45 is the top-of-the-line audiophile master product that is built on the best CDR master specification. Consumers need to ascertain whether their CD players could playback the CDR before they purchase the LPCD45 discs.
    Now, there is no need for audiophiles to slave over their LP players. Audiophiles also need not be tortured by the noise and wow and flutter of the LP and yet still able to enjoy the highest sonic quality equivalent to an LP system. Come and enjoy the wonder of music and sound effects brought to you by LPCD.
    HUGO Productions
    Seminar dari Aik Yew Goh Tentang LPCD :
    http://www.youtube.com/watch?v=FiEAe3pLrhg&fs=1" width="644" height="390">http://www.youtube.com/watch?v=FiEAe3pLrhg&fs=1" />BORKED
    2. The Ultimate Demostration Disc - A Guide to Critical Listening by Chesky Record
    Harga rp. 28.000
    The Ultimate Demontration Disc has a most important mission making those tough choices regarding your audio system a lot easier. Our goal is to create a system that will provide musical satisfaction and it will be the ‘best’ in the areas that are the most relevant to you.
    Cd ini sering di pakai majalah 'Audio Mobil' untuk mengetahui transparansi suara, kedalaman suara (lapisan suara), vocal, kedinamisan suara…dll. Dengan mendengarkan berulang-ulang, anda akan bisa mengetahui perbedaan detail-detail suara dari rekaman CD ini. Mungkin anda juga bisa menilai kualitas sound system anda apakah mendekati/menyerupai suara aslinya.
    Klik DiIsini untuk Foto Detail
    3. FIM - Audiophile Reference IV (SACD)
    Selections:
    1. La Vezina Catina (E. Ferstl, A.White/A.White)
    2. The Swan (Camille Saint-Saens)
    3. Olde London (Traditional)
    4. Fiddler on the Roof (Manuel Compinsky)
    5. Georgia on My Mind (S.Carrol, H.Carmichael)
    6. Sometimes I Feel Like a Motherless Child (Spiritual)
    7. Han AR Fodd (Ulla Homborg)
    8. Lover’s Tear (Yiu Man)
    9. Misty (J.Burke, E.Garner)
    10. High Life (African Folk)
    11. Yang City Variations (Chinese Traditional)
    12. Excerpts from Messiah (George Frederic Handel)
    a. Hallelujah
    b. I Know That My
    13. Deer Hunter (Palestrina)
    14. Marias Vaggsang (MaX Reger)
    15. The Look of Love (B.Bacharach, H.David)
    16. Canon in D (Pachelbel)
    This disc features a Super HDCD 24 Bit encoded Stereo CD layer as well as Stereo SACD or Surround Sound SACD versions of the music on the album.
    "A true Audiophile Reference for all with ears to hear! Ye Olde Editor's very highest recommendation...with greatest enthusiasm!" -- David W. Robinson, Editor, Positive Feedback Magazine.
    Produced by Joe Harley and recorded at Record one, Ocean Way Studios, Hollywood, CA using Live direct to 2-track pure analogue tapes and Live direct to Sony Direct Stream Digital System, Advanced Intelligent tape. Features a large selection of First Impression label artists with a focus on jazz.
    4. Audiophile Jazz Prologue III - 1 CD (rp. 28rb) + 1 DVD master file (Rp. 50rb)
    RARE & Limited Edition
    Master File Disc contains high resolution file 24 bit / 192 KHz, 24 bit/ 96 Khz, Master tape AIFF files for computer or HDD Playback.
    1 Track saja bisa 250-400 MB per file :o
    NB : untuk playback yg versi 24 Bit / 192 Khz dan 24 Bit / 96 KHz, pastikan sound card anda mendukung yah..
    5. SACD Calix audiophile recordings Rp. 28.000
    6.Manger Test CD Rp. 28.000
    Info: http://www.tnt-audio.com/topics/mangertest_e.html
    http://www.soundlabsgroup.com.au/p/MGR-Demo-CD/Manger+Demo+CD
    SMS Orderan langsung ke 061 77014920
    wah,mantep nich bro....
    ada judul2 lain lagi ga bro yang sudah LPCD?
    Medan
    ini pas kemarin dapetnya yg LPCD45 Andy Lau saja... susah sih nyarinya.. harganya juga hehehe... mau coba bro?
    Medan
    Upppppppp....................
    Medan
    uppppppppppppp hari minggu
    Medan
    Up Up Up Up Up Up Up Up
    Medan
    sundul ke atas..............
    Medan
    upppppppppppppp
    1 Day 3 Hrs 28 Mins 24 Secs
    Bos cd andylau ny laguny apa aja?
    Medan
    judulnya sih ngga tau ya. coba di search aja album nya yg cover seperti itu..
    yg gw tau semuanya enak enak walau agak oldies
    Lai Sen Yen
    Ru Kuo Ni She Wo Ti Chuan Suo
    dll...
    yg jelas cd ini suaranya berasa banget analognya..
GT Radial NGK Busi
  1. wta format cd "xrcd 24bit super analog"
    By yosua778 in forum Diskusi Audio Lainnya
    Last Post: 1st January 2012, 11:30
  2. PIRINGAN HITAM LAWAS
    By ciklele in forum Bursa Audio Lainnya
    Last Post: 25th September 2011, 21:51
  3. jual Piringan hitam....harga nego
    By syabna in forum Bursa Audio Lainnya
    Last Post: 26th January 2011, 11:58
  4. Harga player Piringan Hitam
    By shinosuke in forum Diskusi Audio Lainnya
    Last Post: 26th February 2007, 10:33
