WTS >> POWER simpanan..Kondisi OK..!!
Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
  • Short URL:  http://modifika.si/142753
    Jual POWER AMPLIFIER simpanan..Free BONUS..!!
    Power monoblok merk BLACKMORE made in Korea
    speifikasinya:
    230 watt RMS X 1Channel at 4 ohm,440 watt RMS X 1 Channel at 2 ohm,700 watt RMS X 1 Channel at 1 ohm,dynamic power:460 watt at 4 ohm,freq.Response:20hz-350hz,BASS BOOST:0-18DB,Subsonic Filter:20-50HZ,Low Pass X-Over:50-350HZ,Remote Input Level Control
    Harga:1,5JTnegooo..
    Barang ada 2 pcs
    2nd Power 4chnl BLACKMORE made in KOREA 1jtnegooo..
    * 560 Watt 4 Channel Amplifier
    * Power Output: 70 Watts RMS x 4 Channels at 4 Ohms and
    * Signal to Noise Ratio: 80dBA (reference: 1 Watt into 4 Ohms)
    * Dynamic Power: 560 Watts total at 4 Ohms
    * Frequency Response: 20Hz – 50kHz, -3dB
    * Additional Power Output: 120 Watts RMS x 4 Channel at 2 Ohms and
    * Additional Power Output: 200 Watts RMS x 2 Channel Bridged at 4 Ohms and
    * Features:
    * Variable Bass boost: 0 – 18dB
    * Variable low pass X-over: 30Hz – 250Hz
    * Variable high pass X-over: 30Hz – 250Hz
    * RCA pass-thru outputs
    * Dimensions: 18.75" L X 9.75" W X 3.25" H
    * CEA-2006 Certified
    Klo Bos2 ambil semuanya adaBONUS yg bisa dibawa pulang:
    1.Kabel RCA 2,5m AVIONICS APACHE seharga 500rb
    2.kabel RCA 5m ISOTERIC PREMIUM seharga 400rb
    Minat : 081910000073
    TV PLAFON MOBIL >> 15 INCH..KLIK AJA..!!
    Sundul dulu!!
    Post
    PM harga netnya boss...
    Quote Originally Posted by cangkir_penyok View Post
    cek pm bos
    malam...
    sundul lagi
    Kelapa Gading
    2 Wks 5 Days 19 Hrs 45 Mins 7 Secs
    bos... kuat buat angkat solobaric l7 dual 2 ohm ga monoblock nya?? dpt deepnya ga????? pm ya... thanx
    Quote Originally Posted by Lancer93 View Post
    Kuat bos,tp 2 power di paralel utk 1 subwoofer maen di 1ohm
    uuuuuuuuuppppppppp,,,,,,,,
    uuuupppppppp........
    uuuuuuuuppppppppp..........
GT Radial Venom 300x250
  1. Replies: 3
    Last Post: 23rd August 2012, 15:59
  2. Replies: 24
    Last Post: 2nd December 2011, 19:49
  3. Replies: 27
    Last Post: 9th August 2011, 13:08
  4. Replies: 23
    Last Post: 16th March 2011, 10:51
