[WTS] Power Amp Alphasonik PMA 600HC High Current Built-up
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/142521
    6 Days 12 Hrs 21 Mins 51 Secs
    ALPHASONIK PMA 600 HC HIGH CURRENT POWER AMPLIFIER
    (made in USA) BUILT-UP
    PMA SERIES
    HIGH CURRENT POWER AMPLIFIERS
    Virtually identical in topology to the Class A/B Series, the High Current Series is designed to drive 1-ohm mono loads. Ideal for powering multiple voice coils in parallel or for running 4-ohm loads where maximum damping and minimum distortion is desired. Fully variable 24dB/octave low-pass, high-pass and subsonic crossovers. Includes the PMA100V Remote Digital Volt Meter and PMA10B Remote Bass Boost Controller as standard features.
    STANDARD FEATURES
    > Bridgeable
    > Hour Meter
    > Remote Mount PMA100V Digital Volt Meter
    > Remote Mount PMA10B Bass Boost Control
    > Heavy Duty One-Piece Extruded Aluminum Heat Sink
    > Beveled Clear Acrylic Protective Cover
    > Tiffany-Style RCA Jacks
    > Parallel Line-Out RCA Jacks
    > Removable Aluminum Side Covers Conceal Control & Terminal Panels
    > MOSFET High-Speed Switching Power Supply
    > Milspec Double-Sided Glass Epoxy Circuit Board w/ Through-Hole Plating
    > Heavy 4 oz. Pure Copper PC Traces at All Preamp & Amplification Stages
    > Solid Brass Nickel-Plated Terminal Blocks (PMA800 & 1000HCA
    2-Gauge Power, 8-Gauge Speaker) (PMA150, 300, 600 & 640HCA
    4-Gauge Power, 8-Gauge Speaker)
    > Variable Low-Pass Filter: 50Hz~250Hz, 24dB/Octave
    > Variable High-Pass Filter: 50Hz~250Hz, 24dB/Octave
    > Variable Subsonic Filter: 20Hz~60Hz, 24dB/Octave
    > Variable Bass Boost @ 45Hz: 0 ~ +18dB
    > Variable Phase Shift: 0~180˚
    > THD: < 0.05%
    > Signal-to-Noise Ratio: >100dB
    > Frequency Response: 5Hz~50kHz
    > Input Impedance: 10kΩ
    PMA600HCA
    2-CHANNEL HIGH CURRENT AMPLIFIER
    > 300 Watts x 2 @ 4Ω Stereo
    > 550 Watts x 2 @ 2Ω Stereo
    > 900 Watts x 2 @ 1Ω Stereo
    > 950 Watts x 1 @ 4Ω Mono
    > 1550 Watts x 1 @ 2Ω Mono
    > 1800 Watts x 1 @ 1Ω Mono
    > Dimensions (W x H x L) 9 1/16 x 2 5/8 x 19 3/4”
    Dus, sarung ampli, aclyric msh ada semua.
    Stiker Segel waranty masih terpasang dan tidak rusak , belum pernah dibongkar/direpair/diservis.....
    Pic menyusul ya bos....
    Price Best Offer aja
    2 Days 10 Hrs 30 Mins 19 Secs
    ditutup kapan nih bos? Starting bid ada ngga? tq
    nda ada batasnya bos, nunggu ada penawar tertinggi aja
    jualnya agak nyantai
    penawar terakhir by sms 1,5 jt COD jakpus bos
    sorry aku jarang online
    1 Day 5 Hrs 33 Mins 8 Secs
    Setuju Bos nToeng
    Penawaran Best offer harus ada starting Bid dan batas berakhirnya...
    Dan harus jelas Penawar tertinggi siapa.... ( bisa lewat Threat ini )
    Jadi Konsumen tidak kebingungan dan tidak salah membuat bid - ny...
    Jadi semuanya jelas... Penjual dan pembeli harus bertangging jawab dalam hal ini...
    Thank's
    Quote Originally Posted by suyanto_1976 View Post
    Setuju Bos nToeng
    Thank's
    hehehe si om nongor eh nongol juga,terserah penjual aja
    Emang sih lebih enak kalau terbuka dan penawaran sebaiknya dilakukan di thread,dan bukan melalui sms
    Jadi semua tahu siapa nawar berapa,dan tawaran terakhirnya berapa.
    No offense ya buat TSnya
  1. Jual : 1 Power ORION 250 HCCA 2 Ch High Current
    By d3cibel in forum Power Amplifier
    Last Post: 23rd May 2013, 13:18
  2. ((Jual)): POWER 2 ch U.S.AMPS type USA-100HC (high current)
    By audiocarsundajaya in forum Power Amplifier
    Last Post: 25th May 2011, 19:30
  3. WTS : MA audio power HK802sx 2ch high current
    By eb_club in forum Speaker - SubWoofer
    Last Post: 16th February 2010, 13:30
  4. WTS: POWER AUDIO ART 50 HC(HIGH CURRENT)
    By tandy suhendra in forum Power Amplifier
    Last Post: 4th November 2009, 14:32
  5. POwer High Current
    By earone in forum Diskusi Power Amplifier
    Last Post: 15th August 2006, 14:50
