JL AUDIO 12 W6V2 super muluuuuuusss,baru pakai sebentar....(sold,thanks modcom....)
Results 1 to 10 of 67
  • Short URL:  http://modifika.si/142428
    Cool JL AUDIO 12 W6V2 super muluuuuuusss,baru pakai sebentar....(sold,thanks modcom....)
    JL AUDIO 12 W6V2 super muluuuuuusss,baru pakai sebentar..............sold
    12W6v2 D4 DRIVER SPECIFICATIONS
    Free Air Resonance (Fs): 25.0 Hz
    Electrical Q (Qes): 0.480
    Mechanical Q (Qms): 7.100
    Total Speaker Q (Qts): 0.450
    Equivalent Compliance (Vas): 2.82 cu. ft. / 79.9 liters
    One-Way, Linear Excursion (Xmax)*: 0.65 in. / 16.5 mm
    Reference Efficiency (no): 0.250%
    Efficiency (1W/1m)**: 85.9 dB SPL
    Effective Piston Area (Sd): 77.8 sq. in. / 0.0502 sq. m.
    DC Resistance (Re): 6.75 ohm***
    Nominal Impedance (Znom): Dual 4 ohm
    Thermal Power Handling (Pt): 600W
    Driver Displacement: 0.090 cu. ft. / 2.5 liters
    Net Weight: 19.4 lbs. / 8.8 kg
    * Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied.
    ** Efficiency (1W/1m) is not an accurate indicator of a subwoofer's output capability and should not be used as a comparison to other subwoofers to determine which one is "louder".
    *** Re (DC resistance) is measured with the voice coils in series, for parallel-wired specification divide Re by 4. All other specifications remain the same.
    W6v2 Subwoofer Drivers
    What if the compromises inherent in speaker design could be negotiated to create exceptional sound quality and output in very compact enclosures?
    What if you could apply years of intense research and vast experience in subwoofer driver design to such a project?
    What if the freedom existed to engineer every component of the new design from the ground up?
    You are looking at our answer to these questions, the W6v2 drivers.
    At first glance, you're likely to notice the striking cast alloy frame design. These frames are much more than cosmetic enhancements, having been specifically engineered to provide increased clearance for greater excursion and to incorporate our patented Elevated Frame-Cooling technology. This cooling scheme directs high-velocity air flow over the top surface of the top-plate and onto the upper portion of the voice coil windings (the two hottest parts on a woofer). For style points, the mounting flange of the frame is dressed with a removable black trim ring (Patented) which can be painted to match the theme of the installation.
    Like the W7's, the W6v2 subwoofers benefit from JL AUDIO's proprietary Dynamic Motor Analysis system (DMA). This advanced technology allows us to optimize motor behavior, while taking into account the effects of real power flowing across the voice coil. The result is dynamically stable and linear motor behavior, which translates directly into reduced distortion and improved transient performance.
    The diaphragm design also relies on W7 technology, utilizing our W-Cone (Patented) design and Floating Cone Attach Method (Patented). This results in a lightweight, stiff and critically aligned moving assembly (again enhancing sound quality). The diaphragm also incorporates a new (Patent-Pending) "NeckVent" design to enhance cooling performance.
    Co-extruded, insulated lead wires lead to a configurable patch panel which makes it easier and cleaner to interconnect the dual voice coil windings. A single pair of high-grade push terminals acts as a main input connection.
    All this technology comes together to deliver subwoofers that excel in thermal power handling, linear excursion capability and dynamic stability; all of which contribute to the original goals: The ability to have amazing low-frequency extension in compact enclosures, razor sharp definition of complex bass material and audiophile sound quality at any volume level...
    ...in other words, the balance of power and finesse.
    All W6v2 Subwoofers are built, with fanatical attention to detail, in our Miramar, Florida factory.
    call
    081388575788
    Yogyakarta
    1 Day 11 Hrs 37 Mins 55 Secs
    Pertamax dulu....buat Sub bagus...........
    klaten
    Mangstab boss Chris....betelor lagee neh kantong dora emon nya...
    thanks bos rafiq n bos danny...........
    UP...............
    22 Mins 56 Secs
    UP...............
    bos, tlg pm net dong, buat JLW6V2
    thks
    klaten
    Quote Originally Posted by the_soe View Post
    thks
    Hajaarrr bossss.....mantab tuh buat temen Morel Elate nya....
    pm sent bos the soe.....
    thanks ya bos danny..........
    22 Mins 56 Secs
    wah, bro danny dimana2 muncul trus nih,
    jangan jadi kompor bro ntar i hangus loh
    wkakakakka
    thks,
    he...he...he....,bos danny bukan kompor koq bos,cuma panggangan aja,he...he...he...
    just kidding loh bos danny,thanks ya bos danny bantuan2 up-nya.....
MBtech Tekiro
  1. Barang-barang Aksesoris Mobil Baru Pakai Sebentar!!!
    By autoklasse in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 18th April 2011, 23:18
  2. SALE dastek tipe Q baru pakai sebentar seperti baru
    By ucup in forum Jual Beli Mesin Lainnya
    Last Post: 24th January 2011, 10:37
  3. <WTS>jual dastek & unichip q 2nd like new pakai sebentar doank...
    By anthony29 in forum Jual Beli Mesin Lainnya
    Last Post: 24th August 2010, 11:31
  4. Replies: 135
    Last Post: 8th August 2010, 09:22
