[connection] White EVO 7 Project *UPDATE* Featuring All New ACCORD EURO [connection]!
Page 1 of 20 12345 ... LastLast
Results 1 to 10 of 196
  • Short URL:  http://modifika.si/142097
    Jakarta & Melbourne
    4 Mins 6 Secs
    Full version nya masih dalam process ya, tunggu tanggal main nya.
    Specs?? Masih belum final, new parts masih berdatangan dari Jepang setiap minggu.
    PERSIAPAN PERANG!!!!! THE WHITE TRACK WARRIOR!!!!!
    EVO VII [connection] ft All New Accord Euro [connection]
    UPDATE:
    with work emotion cr kai 18x9.5 +20
    with gramlights 57d 17x9 +22
    with te37 17x9+30
    track wheels advan RC II 17x8.5 +31 with RE55 235/45/17
    SPARE semi slicks RE55 245/40/17
    Engine and Driveline Modification and Specs:
    - EVO 9 turbo swap
    - EVO MR Blow-off Valve
    - Brian Crower 272degree intake camshaft
    - Brian Crower 272degree exhaust camshaft
    - Brian Crower adjustable cam gears
    - Gates racing timing belt
    - Gates racing balance belt
    - Precision 1200cc injectors
    - HKS EVC VI Electronic Boost Controller
    - Exedy heavy duty cushion button clutch
    - HKS Silent Hi power cat back
    - Invidia dump pipe
    - TurboXS front pipe
    - Magnaflow 3" metal cat
    - Walbro GSS342 500hp 255lt/hr fuel pump
    - HKS Racing Suction pod intake
    - x3e 52mm alloy radiator
    - 1.3bar radiator cap
    - NGK Super Power Cables ignition leads
    - NGK Iridium BPR7EIX spark plugs
    - Pivot Raizin volt stabilizer
    - Pivot Super Earth grounding kit
    - Beatrush radiator cooling panel
    - Blox billet engine mount
    - Engine torque dampener
    - ETS Version 2 Lower Intercooler Pipe
    - Reflashed ECU by Matt Lowth (RE Customs)
    Handling Modifications:
    - Cusco zero2r Coilovers for daily driving & BC type ER coilovers with external reservoir for track use
    - Whiteline 22mm adjustable rear sway bar
    - Whiteline 25mm adjustable rear sway-bar-link with spherical rod end
    - Stock Brembo Caliper front and rear
    - DBA 4000s slotted rotors front and rear
    - x3e street pads front and rear
    Interior:
    - Alpine CDA-9853 head unit
    - Black faced boost gauge
    - APEXi Full auto turbo timer
    - Trust shift knob Type N
    - Canon 500D with fixed racing mounts
    - CAMS Approved 1kg fire extinguisher with fixed racing mount
    - Carbon fibre wrapped panels, stereo surround, window switches
    - 52mm Autogauge Oil Pressure gauge
    - 52mm Autogauge Oil Temperature gauge
    - 52mm Autogauge Water temperature gauge
    - Evo 9 Steering wheel
    Exterior & Cosmetics:
    - EvoXenon's Custom Headlight & Projector
    - Evo 9 bar with tow hook cover
    - Voltex genuine CF rear diffuser
    - Chargespeed side skirt extension
    - Carbon fiber boot lid lip
    - Carbon fiber vortex generator
    - Zaklee Corp clear cam pulleys cover
    - Work emotion CR KAI 18x9.5 +20 with Toyo Trampio 245/40/18
    - XXR 527 17x9.75 +25 with Bridgestone RE001 for street, Advan AO48 255/40/17 semi slicks for track
    - Gramlights 57D 17x9 +22 with Kumho KU31 235/45/17 for street, Bridgestone RE55 semi slicks 245/40/17 for track
    - Advan RC2 17x8.5 +31 with Bridgestone RE55 semi slicks 235/45/17 for track
    3 Wks 3 Days 15 Hrs 58 Mins 14 Secs
    PERTAMAX.....!!!
    wuanjengg manteb nee...
    maenan baru d melbourne neee.......
    Jakarta & Melbourne
    4 Mins 6 Secs
    doy cara bikin signature gimana sih?
    semarang
    4 Days 12 Hrs 35 Mins 33 Secs
    wew . .mantapp . .kerenn . . .
    Jakarta & Melbourne
    4 Mins 6 Secs
    thanks bro
    Jakarta Selatan
    4 Days 2 Hrs 17 Mins 17 Secs
    wets harus ikutin perkembanganny nih gw heheheheehe http://www.modifikasi.com/showthread.php?t=115992 mampir ya bos
    Jakarta & Melbourne
    4 Mins 6 Secs
    thx bro hehe
    KL, MY
    Thumbs up
    Nice car! Target powernya brp nih?
    1 Wk 7 Hrs 21 Mins 57 Secs
    conection ada jg y d melb...baru tau,,,hehehe.,.,,
    dah brp mbl sob..??
    keren bos mblnya,,,hehehehe
MBtech Venom 300x250
  1. Replies: 81
    Last Post: 27th July 2013, 11:30
  2. [CONNECTION] Accord CM5
    By Sachiko in forum Honda
    Last Post: 27th July 2013, 10:42
