ARC FD4100 2'nd masih mulus 95%
Results 1 to 10 of 67
  • Short URL:  http://modifika.si/139182
    48 Mins 9 Secs
  2. clickbet88.com
    48 Mins 9 Secs
    up...up...up...up...up
    48 Mins 9 Secs
    10 Hrs 15 Secs
    bantu up boz rikky ...
    10 Hrs 15 Secs
    sekalian bantu info specnya nih buat barangnya juragan audio di bandung nih
    Power 4 Channels ▪ Independant front and rear 12dB stereo crossover 55Hz to 5.5KHz ▪ Seperate front and rear high/low/full range select switch ▪ 4 channel/2 channel or 2 channel with bass select ▪ Seperate front and rear mono/stereo/bridged select feature ▪ 18dB bass control at 45Hz select feature ▪ Protection against: reverse voltage, over voltage, speaker short, and thermal overload ▪ Heavy duty construction ▪Output power :50x4@4ohms, 90x4@2ohms, and 180x2 4ohms bridged ▪Transient distortion :< 0.1% @4ohms ▪Frequency response:20Hz-20Khz ▪S/N ratio(A wtg) :> 95dB ▪Bass boost :+ 18dB @45Hz ▪Input sensitivity :250mV - 2.5V ▪Crossover :55Hz-5.5KHz variable 12dB ▪Fuse :40A x1 ▪Dimensions :10 3/8 " x 16 1/2" x 2 3/8"
    48 Mins 9 Secs
    Quote Originally Posted by harold View Post
    Ok bos makasih banyak yah :smt023 :smt023 :smt023 :smt023
    48 Mins 9 Secs
    48 Mins 9 Secs
    up.................
    48 Mins 9 Secs
    up...up...up...up
    48 Mins 9 Secs
    up....up....up
  1. WTS : ARC DSP 8 masih mulus, dan masih garansi :)
    By CARTENS in forum Bursa Audio Lainnya
    Last Post: 14th July 2011, 17:16
  2. Masih adakah mobil di Jakarta yg spionnya masih mulus???
    By Project atLantis in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 29th March 2010, 12:18
  3. [SOLD OUT] ARC FD4100 by Foose Design.
    By seraphim in forum Power Amplifier
    Last Post: 12th November 2009, 09:50
  4. KAR Black Paint dg board FD4100?
    By nobe in forum UnSCAC- Hwely Audio
    Last Post: 7th October 2009, 00:32
  5. HELP ME :Bagusan mana profile 5 vs FD4100
    By denkris in forum Diskusi Power Amplifier
    Last Post: 11th July 2009, 02:40
