How to buy a car audio speaker
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/13872
    hermy
    When shopping for a car speaker listen to it before buying it because there is no other way to know how it will sound to you. Keep in mind the following . . .
    • Ensure you take along with you a CD that you normally listen to when you audition the speakers. This will help you get a better idea of how the speaker reproduces sounds you are familiar with.
    • Listen closely for low level details and how instruments sound.
    • After narrowing down your choices to a couple of different speakers, audition them at length. A poor quality speaker has an exaggerated low and high end.
    • Adjust the bass and treble as well as the volume to levels that are comfortable for you.
    • Beware of salespeople that turn up the volume slightly on the expensive speakers and persuade you to buy them.
    When choosing loudspeakers, be realistic. If you don’t want any modification in your existing speaker holes, buy speakers that fit in the current available space. Also keep in mind depth considerations, like in doors where speakers may interfere with windows rolling down. Take note of dashes where speakers may be limited by ducts (for heat and air) and rear decks where depth is limited by torsion bars.
    :smt006
    1 Day 1 Hr 30 Mins 17 Secs
    ga ngerti dkt2 neh...
    artiin k Indo aj bozz
    byar smua pd ikt tau
    Surabaya - Ambon
    1 Mth 5 Days 6 Hrs 28 Mins 53 Secs
    hahaha.. artiin biar smua ngerti donk..
    HiddeN_ C i T y
    17 Secs
    duh duh...
    1st posting dah nyusahin...hehe
    piss bro
    7 Hrs 24 Mins 24 Secs
    Ini buat newbie. Kalau udah gak newbie gak perlu baca kok
  1. Speaker-speaker Home Audio
    By rbtrzl in forum Bursa Audio Lainnya
    Last Post: 22nd November 2013, 16:35
  2. Replies: 12
    Last Post: 18th October 2010, 12:30
  3. Replies: 19
    Last Post: 21st April 2010, 11:59
  4. Paket Speaker Warung Audio New n 2nd (Audio Quart)
    By e1dos in forum Speaker - SubWoofer
    Last Post: 21st January 2010, 19:10
  5. Hustler Audio NEW X2 and X3 Speaker Set from Audio-Works
    By BadakSinga in forum Diskusi Speaker
    Last Post: 19th March 2009, 23:55
