BMW E30 318is >> AC Schnitzer Edition << code name : Smokey
Page 1 of 35 12345 ... LastLast
Results 1 to 10 of 345
  • Short URL:  http://modifika.si/138694
    48 Mins 21 Secs
    Smile BMW E30 318is >> AC Schnitzer Edition << code name : Smokey
    A quick BMW needs straight six, 100% i agree !
    But... a great handling, perfect weight balanced, better fuel economy they're only needs four pot’s
    This is my BMW E30, build from E30 M40B18 1991 DiamantSchwarz Metallic (Diamond Black) to M42B18 SterlingSilber Metallic (Sterling Silver).
    Engine
    - M42 B18 1990
    - 16v DOHC Direct Ignition
    - Port polished head
    - Crankshaft balanced
    - Larger throttle body
    - Custom Exhaust Manifold
    - 4,34 open differential
    - K&N Replacement Air Filter
    - M40 Flywheel conversion
    - ECU remapp by Mark D’Sylva, 95 RON
    - Vitesse Motorsport clutch stop
    - 2" exhaust pipe
    - Twin pipe sport muffler
    - Z3 1.9 short shift P/N : 25117527252
    Suspension
    - Eibach Pro-Kit p/n : 2021-140
    - Bilstein Yellow Sport, fr : P36-0335 rr : B36-2027
    - M-Technic 19mm anti roll bar kit
    - E30 M3 control arm bushing centered
    - Alutec Strut Brace front
    - Sparco Strut Brace rear
    - Rogue Engineering rear guide support
    - AC Schnitzer type I wheel 16x7,5
    - Achilles ATR Sport 205/50/16
    Brake
    - Stock E30 325i conversion
    - OEM BMW disc front (ventilated)
    - OEM BMW disc rear
    - Ate Brake Disc front + rear
    - Ate Brake Pads front + rear
    - Ate Brake fluid
    - E28 520 Brake Master Cylinder conversion
    Interior
    - Recaro SR-3
    - AC Schnitzer Steering Wheel
    - AC Schnitzer Shift Knob
    - AC Schnitzer pedals
    - OEM BMW Mirror with Map Lights
    - Euro Cluster conversion in MPH
    - Black kidney grille
    Exterior
    - Spray in Sterling Silver Metallic (OEM BMW E30) – Spies Hecker
    - AC Schnitzer body kit
    - AC Schnitzer grille badge
    - AC Schnitzer trunk badge
    - Hella Smoke head lamp
    - MHW Germany smoke tail lamp
    - Foha heckspoilerl
    - OEM BMW Wiper head lamp
    - E30 325i Oil Cooler Grille
    - Clear side indicator
    - Smoke front indicator
    - HID 4500K -- headlamp
    - GE Megalight+ -- H1 beam
    - GE H3 All Season -- foglamp
    ICE
    - Nakamichi TD-45z
    - Nakamichi MF-51 changer
    - Fusion 4ch power amp
    - Rodek split speaker front
    - Hart 6,5" 2way rear speaker
    and the pics....
    Special thanx to..
    Parts :
    - Patrick & Yves from bmaparts.com
    - Mark for the chip
    - ebay.com
    - ebay.co.uk
    - Pak Yayat (Astra BMW Cilandak)
    - Pak Irs (ianparts.com)
    Worskshop :
    - Paint and body repair : Perfect Auto Body (the name you can trust)
    - Engine blue printed : Prof. Darji
    - Engine, Brake, Suspension set up / installation : ALTA Racing
    - Custom Exhaust Manifold : SR Motor
    Friends :
    - twilitesbmw (Technical Director)
    - Mas Pungky (Think Thank man)
    - Alam (awesome paint brader !!)
    - Adam a.k.a qimis (inspired me with his old beautiful Alpine White E30)
    - Posmaxx (thanks for shock and injectors)
    - Teddy, Sandy, Wiwi (BMW Fanatics)
    comments, ideas, advices are highly appreciated
    JKT-BKS
    6 Days 10 Hrs 30 Mins 43 Secs
    akhirnya muncul juga...
    buat yg satu ini dah ga bisa ngomong lagi dach... dach lengkap...kap.. hehe...
    6 Days 16 Hrs 8 Mins 14 Secs
    keren bgt om mobilnya.
    Minal aidin wal faidzin ya......
    6 Days 20 Hrs 58 Mins 37 Secs
    very nice cars sob
    keep on the good work!
    regards
    Sby
    12 Hrs 11 Mins 43 Secs
    wah, gila, mantapp nih, old car with complete ACS , one of my dream .
    more picture donk.
    salam kenal sesama pengguna ACS.
    http://www.modifikasi.com/showthread.php?t=115294
    2 Days 9 Hrs 33 Mins 24 Secs
    ahh speechless deh liat yg satu ini,
    pngen punya :p
    6 Days 9 Hrs 29 Mins 54 Secs
    cakep banget nih.. M42 di body kecil gitu bisa tembus 1:10 dalkot ga ya?
    Depok
    1 Wk 3 Days 16 Mins 49 Secs
    keren banget boss...
    boleh saya jadikan pedoman untuk mobil saya gak ???
    saya juga bercita2 swap engine kaya ente bos....
    Mgb
    5 Hrs 1 Min 31 Secs
    mas koko, kayaknya udah pantes deh dimasukin bmw performance atau total bmw.. supaya mereka2 tau di sini juga banyak bmw lover yg bener2 'gila'.. hehe..\
    Jakarta,Indonesia
    2 Days 19 Hrs 25 Mins 2 Secs
    Mantab! FULL ACS tinggal mesinnya nih..
    '83 AE86 - '94 E36 325i - '96 E36 2JZ - ' 94 E36 332i - '92 E36 332i - '96 E36 316i - '98 E36 318i
    www.goodrides.co
Mega Glodok Kemayoran MBtech
  1. Replies: 14
    Last Post: 5th March 2012, 14:09
  2. Replies: 22
    Last Post: 22nd August 2011, 03:06
  3. Replies: 5
    Last Post: 6th July 2010, 17:07
  4. WTA: HID Code
    By Atoon in forum Diskusi Aksesoris
    Last Post: 27th October 2007, 01:00
