scanspeak d6000 kondisi super muluuuuus.....(sold.thanks modcom....)
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/137733
    Cool scanspeak d6000 kondisi super muluuuuus.....(sold.thanks modcom....)
    scanspeak d6000 kondisi super muluuuuus...........sold
    ScanSpeak D2904/6000-00 28 mm Dome Tweeter, Neo Magnet, Grill
    Scan-speak D2904/6000-00 tweeter with grill. For home or automotive use.
    The D2904/6000-00 tweeter w/ grill has a 1" coated textile dome and a neodymium magnet system. This speaker uses a compact self shielding Symmetric Drive magnet system, utilizing three powerful neodymium magnets. The cavity under the voice coil is coupled to the chamber through eight holes in the top plate. Pure cotton is used as damping material. The textile diaphragm is carefully hand coated. The reproduction is very dynamic and open, with low levels of compression. Perfect for A/V.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 90.5dB
    Free air resonance Fs 750 Hz
    DC resistance 3.5 ohm
    V.C. inductance 0.02 mH
    Power 12dB@Hz 150W@2.7K
    Effective cone area 8 cm2
    V.C. diameter 28 mm
    Lin. & max. excursion 0.25 / 1.3mm
    Force factor BL Product 2.7 Tm
    Moving mass incl. air 0.4 g
    Net weight 0.13 kg
    Outside diameter: 59.5mm
    Cut out: 41mm
    Depth: 29mm
    25.4mm = 1" = 2.54cm
    call
    081388575788
    2 Hrs 59 Mins 36 Secs
    Brapaan neh bos??
    10 Hrs 15 Secs
    bantuin up boz ......
    10 Hrs 15 Secs
    up>>>>>>>>>>>>>
    thanks bos harold..............
    5 Hrs 31 Mins 43 Secs
    mulus banget nih
    thanks bos greco............
    up..................
    up............
Venom 300x250 GT Radial
  1. ((((WTS))) Tweter SCANSPEAK D6000 (SOLD!!!) Thanks MODCOM!
    By rafiq sulaiman in forum Speaker - SubWoofer
    Last Post: 19th February 2010, 12:53
  2. Replies: 17
    Last Post: 25th January 2010, 14:12
  3. Replies: 23
    Last Post: 26th November 2009, 03:14
  4. Replies: 45
    Last Post: 18th September 2009, 07:39
  5. Replies: 7
    Last Post: 11th June 2009, 05:25
