hi-end scanspeak 23w revelator subwoofer.....(sold,thanks modcom....)
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/137125
    Cool hi-end scanspeak 23w revelator subwoofer.....(sold,thanks modcom....)
    hi-end scanspeak 23w revelator subwoofer kondisi muluuus.....sold
    ScanSpeak 23W/4557T 9" Aluminum Cone Subwoofer, Silver Cone
    Same model as 23W/4557T-02 except with a silver cone.
    The Scan-speak 23W/4557T is a very high end subwoofer, designed to be used with a passive radiator in a small enclosure. This sub has a very rigid aluminum cone, low loss rubber surround and cast frame. The passive radiator is similar, but with a weight attached to the bass of the cone. The 23W/4557T is using the SD-1 motor system. There are gold plated binding posts and the woofer is covered by a decorative rubber cap.
    Frequency response with the passive is down to 25Hz. One cubic foot sealed has an F3 of 33Hz.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 82 dB
    Free air resonance Fs 20.5 Hz
    DC resistance 3.45 ohm
    V.C. inductance 0.45 mH
    Power 225 W
    Effective cone area 232 cm2
    V.C. diameter 50 mm
    VC height -
    Air gap -
    Lin. & max. excursion 13 / 20 mm
    Air gap flux density -
    Force factor BL Product 9.3 Tm
    Moving mass incl. air 101 g
    Net weight 4.6 kg
    Vas 45.6 ltrs
    Qms 4.8
    Qes 0.52
    Qts 0.47
    Outside diameter: 255mm
    Cut out: 225mm
    Depth: 135mm
    25.4mm = 1" = 2.54cm
    Call
    081388575788
    up................
    3 Hrs 3 Mins 17 Secs
    bantu up, bro chris... barang bagus neh...
    klaten
    bantu up buat sub SQ nya boss
    1 Day 12 Hrs 18 Mins 7 Secs
    check PM bos
    Jakarta Pusat
    1 Wk 1 Day 23 Hrs 37 Mins 1 Sec
    wah... sub impian neh.... pm nettnya dunk om ^^thx
    Jakarta-Medan
    3 Hrs 53 Mins 33 Secs
    liat harganya kondisi 99,99% ya bro? kl tidak, pm nettnya bro....
    thanks ya bos bayu n bos danny.....
    pm sent bos ave,bos kawa n bos tavares...
    thanks....
Mega Glodok Kemayoran MBtech
  1. Replies: 3
    Last Post: 31st December 2009, 06:34
  2. Replies: 1
    Last Post: 11th November 2009, 04:13
  3. Replies: 32
    Last Post: 31st July 2009, 00:44
  4. scanspeak revelator 15w/4531-G00 (sold,thanks modcom....)
    Last Post: 30th July 2009, 05:39
