2pcs hi-end MUSEE XA-802 , MADE IN JAPAN........(sold,thanks modcom.....)
  • Short URL:  http://modifika.si/137009
    Cool 2pcs hi-end MUSEE XA-802 , MADE IN JAPAN........(sold,thanks modcom.....)
    2pcs hi-end MUSEE XA-802 (MADE IN JAPAN) with link muluuuus sekali,lengkap dus.................sold
    Pulse width modulation power supply
    Power supply is formed with toroidal core transformer which features litz wire for good response for high frequency and decent current capacity. This power supply keeps steady voltage, also gives wider dynamic range.
    Individual input level control
    Each channel has individual input level control, which allows you set individual level for multi channel system, or 5.1 channel system.
    Powerful output final stage
    Final stage is driven by Pc=100W 1c=10A bipolar power transistor in single push-pull. Out put simple and straight sound.
    Blue grass epoxy circuit board
    Durable, reliable and long endurance blue glass epoxy circuit board with 70um(100um for MA1502) thick copper foil is featured for all wiring.
    High density aluminum chassis
    Almite hairline finished thick and heavy aluminum chassis with real wood ornament gives elegant look and luxury satisfaction. Of course, works efficient as heat sink.
    musee xa-802 :
    XA802
    Rated Power 80Wx2ch(4Ω)(215Wx1ch(4ΩBridged))
    Maximum Output Power 160Wx2(4Ω)
    Load Impedance 2Ω-8Ω/4Ω-8Ω(Bridged)
    Input Sensitivity 0.2-5V(Each channel can be individually)
    Total Harmonic Distortion 0.01%(1KHz/4Ω)
    Frequency Response 5Hz-100kHz(+0,-2dB)
    Signal-to-Noise Ratio 100dB(1KHz/IHF-A)
    Standby Time Short Circuit/Over Voltage/Over Load/Thermal
    Input Voltage DC12-16V
    Current Consumption 0.8A(Idle)/20A(Rated Power)
    Dimensions 411(W)x210(D)x55(H)mm
    Weight 4.7Kg
    CALL
    081388575788
    klaten
    Keluar lagi barang ajib.........ck ck ck.....mantab boss...
    Bantu uppp.....
    thanks ya bos danny....
  1. Replies: 1
    Last Post: 23rd June 2012, 08:16
  2. Replies: 19
    Last Post: 20th June 2009, 23:40
  3. Replies: 12
    Last Post: 16th June 2009, 03:38
  4. (sold-thx modcom)Mugen RNR R-15 silver (made in japan) pic
    By prayudi in forum Bursa Kaki Lainnya
    Last Post: 31st March 2008, 11:26
