WTS : bbrp perabot audio bekas mbl ane ...
Results 1 to 10 of 34
  • Short URL:  http://modifika.si/136815
    Jl. Cimindi Raya No. 111-115 Cimahi Jawa Barat
    1 Mth 3 Wks 2 Days 21 Hrs 36 Mins 40 Secs
    Thumbs up WTS : bbrp perabot audio bekas mbl ane ...
    Dear frend,
    Ane mau jual bbrp POWER & SUBWOOFER bekas peninggalan mobil ane, yaitu :
    Spec detail bisa diliat disini = http://www.signalauto.net/gallery_lancer_ro.htm
    1. Subwoofer Agako type 12S, ada 8 ekor ... kondisi sip !!! cocok buat SPL @1.2jt ===> sisa = 4 ekor
    2. Agako Power XT4080 x1channel, ada 2 ekor @1.25 jt ===> sold out !!!
    http://www.agako.com/sub_agako2_4080.htm
    FEATURES :
    • High pass variable crossover ( 40Hz-240Hz at 12dB Oct ) -1,2 CH
    • Low pass variable crossover ( 40Hz-240Hz at 12dB Oct ) -1,2,3,4 CH
    • Bass boost switch (12dB) at 45Hz
    • Mode switch (2,3,4CH)
    • Low input
    • 2 ohm stable
    • Adjustable input gain volume
    • Bridgeable
    • Protection circuit for thermal, Sp short , DC reverse, DC offset
    • Power on Led, Protection Indicator Led
    • Remote turn on ( soft start )
    • PWM mosfet power supply
    • Power band width 20Hz~20KHz at 0.05%
    SPECIFICATIONS :
    • Frequency Response 10Hz~40KHz
    • RMS power at 4 OHM Stereo 80W x 4CH
    • RMS power at 4OHM Stereo 230W x 2CH
    • RMS power at 2 OHM Stereo 100W x 4CH
    • Max Power 800W
    • T.H.D 0.05%
    • Input Sensitivity 200mV~4V
    • Input Impedance 10K ohms
    • Damping Factor >200
    • S/N Ratio 100dB
    • Channel Separation 60dB
    3. Agako Power XT-4500D ada 2 ekor = @ 2.75jt aja ===> sold out !!!
    http://www.agako.com/sub_agako2_4500d.htm
    FEATURES :
    • Mono block digital subwoofer amplifier
    • Remote bass boost at 60Hz control :0-18dB
    • Balanced low input & high input
    • Line out ( by pass )
    • Variable Subsonic filter : 15~30Hz, 18dB /oct
    • Variable low pass filter : 40~230Hz, 24dB/oct
    • Variable bass boost at 60Hz control :0-18dB
    • Variable phase control 0~180
    • Protection circuit for thermal, short circuit and reverse polarity connection of Battery
    SPECIFICATIONS :
    • Frequency Response 15Hz~250KHz
    • RMS power at 4 OHM Stereo 600W
    • RMS power at 2 OHM Stereo 1200W
    • RMS power at 1 OHM Stereo 1800W
    • Max Power 2000W
    • T.H.D 0.1%
    • S/N Ratio 100dB
    4. Soundstream Reference Class A 6.0 = 1.75 jt aja ...
    • High Power:
    • 2 x 50 @ 4 ohms (1 x 100 @ 8 ohms bridged)
    • 2 x 100 @ 2 ohms (1 x 200 @ 4 ohms bridged)
    • 2 x 200 @ 1 ohm (1 x 400 @ 2 ohms bridged)
    • 2 x 300 @ ohm (1 x 600 @ 1 ohm bridged)
    • High Current:
    • 2 x 25 @ 4 ohms (1 x 50 @ 8 ohms bridged)
    • 2 x 50 @ 2 ohms (1 x 100 @ 4 ohms bridged)
    • 2 x 100 @ 1 ohm (1 x 200 @ 2 ohms bridged)
    • 2 x 200 @ ohm (1 x 400 @ 1 ohm bridged)
    • 2 x 300 @ ohm (1 x 600 @ ohm bridged)
    • Fuse: 40A
    Info = http://ampguts.realmofexcursion.com/Soundstream_Reference_Class_A_6.0/
    5. Monoblock Prokick 800 watt = 1jt aja ...
    Prokick DG-800 1X200W @ 4 ohms 1x400w @ 2 ohms (Guessing at power since I can't find anything on this thing except that it's good, Class-D mono subwoofer amp, very well made)
    6. Precision Power PPI 2CH 200W Amplifier = 1.3jt aja ...
    Spec :
    * Made in USA, mulus, segel masih perawan
    * Cocok buat yg main SQ suaranya jernih & detail
    * 18 dB/ Octave X-Over
    * Balanced Differential Output
    * AP-III Protection Circuitry
    * RCA X-Over Output
    * 4 ohm 50 Watt x 2
    * 2 ohm 100 Watt x 2
    * Bridged 200 Watt x 1
    Info : http://www.woofersetc.com/index.cfm?...roduct_ID=2988
    buat yg berminat, SMS aja ke 0856-1099998 ato 0856-2099998 ato ym ke r1ckeych4ng ( 24 jam )
    thanks yahh ..
    up .. up .. up !!!
    Arrow up .. up .. up !!!
    Arrow up .. up .. up .. !!!
Mega Glodok Kemayoran MBtech
  1. Paket Audio Second / Bekas
    By yudhibayu in forum Bursa Audio Lainnya
    Last Post: 13th October 2012, 11:18
  2. WTS paketan audio bekas: JBL , MA audio , ADS (surabaya)
    By L 1723 GQ in forum Power Amplifier
    Last Post: 21st July 2012, 22:45
  3. WTS blaupunk audio set bekas NE 230 97
    By creesteel in forum Head Unit & Processor
    Last Post: 22nd January 2012, 09:37
  4. jual kabel audio by estoric audio bekas pke sendiri
    By tegar in forum Bursa Audio Lainnya
    Last Post: 24th October 2010, 22:23
