#PORTFOLIO# 480HP Toyota Corolla Altis 1ZZ 2002 with GT3071R
Results 1 to 10 of 108
  • Short URL:  http://modifika.si/136161
    1 Wk 3 Days 2 Hrs 38 Mins 2 Secs
    TOYOTA COROLLA ALTIS 2002 (Non-VVTi)
    Toyota 1ZZ-FE engine can do nothing? Yeah right..
    Menggunakan mesin bawaan Toyota Corolla Altis 1ZZ-FE 1800cc memberikan tantangan tersendiri bagi kami untuk membuat Altis tersebut sebagai The Fastest Toyota (2WD) Front Wheel Drive di Indonesia.
    Seluruh sistem Power Steering dan AC masih tetap terpasang dan dapat dipergunakan sebagaimana normal nya sesuai permintaan pemilik mobil agar dapat dipergunakan harian.
    Transmisi masih menggunakan standar nya, karena kami perhitungkan gear ratio nya masih cukup ideal untuk dipergunakan harian dan sesekali turun di ajang drag race.
    So, this is a simple built car, easy and nice to drive..
    NOW..! With the new Red Look:
    Boost : 0,95 Bar
    BBM : Pertamax Plus
    Dyno Test : Sigma Speed
    Horsepower Gain : 300 HP @7000 RPM
    Max Torque Gain : 305 Nm @7000 RPM
    Boost : 1,5 Bar
    BBM : Bensol
    Dyno Test : RS Tuning-Lestari
    Horsepower Gain : 362 HP @7000 RPM
    Max Torque Gain : 426 Nm @7000 RPM
    Boost : 2,0 Bar
    BBM : Bensol
    Horsepower Gain : 476 HP @7500 RPM
    Max Torque Gain : 467 Nm @7000 RPM
    POWER DYNO CHART
    TORQUE DYNO CHART
    Specification :
    Turbo Garrett GT2560R Ball Bearing
    CROWER I-Beam Connecting Rods
    WISECO Forged Piston 79,50mm Compression 8,8:1
    CROWER Valve Spring & Titanium Retainer Kit
    ARP Head Stud Kit (Special Order)
    ACL Race Series Main & Rod Bearings Kit (Special Order)
    SUPERTECH Valve Seals
    TOGA Performance Hi-Flo Oil Pump
    TRD Thermostat 170F
    SAMCO SPORTS Siilicone Radiator Hose Kit
    COMETIC MLS Head Gasket Bore 80mm & 0.030" Thick
    BLITZ Blow off Valve SS-DD
    TiAL MV-S External Wastegate 38mm
    JR PROJECT Oil Cooler Kit & Relocation Kit
    JR PROJECT One-Sided Intercooler
    WALBRO Fuel Pump 255 L/H
    PRECISION Extra Injector 440cc (2pcs)
    HKS Super Power Flow Air Filter 200/80mm
    Custom Stainless Intake Manifold
    Custom Stainless Turbo Exhaust Manifold
    Custom Stainlees Piping Intercooler
    Custom Exhaust System
    MEGAN RACING Universal Muffler Inlet 2,5inch
    JR Project Silicone Hoses
    ACT Heavy Duty Racing Clutch with 6-Puck Disc
    CUSCO Oil Catch Tank
    STRI DSD-SLM II Boost Gauge Meter 2 Bar
    STRI DSD-SLM II Oil Pressure Gauge Meter
    STRI Turbo Timer - Black
    A'PEXi AVC-R Boost Controller
    HKS Silicone Hose Vacuum Hose 4mm
    HKS Silicone Hose Vacuum Hose 6mm
    NGK Iriway 9 Spark Plug
    KSPORT Coilover Kit - Street
    ULTRA RACING Front Bar 2 Points
    ULTRA RACING Front Lower Bar 3 Points
    ULTRA RACING Rear Lower Bar 2 Points
    ULTRA RACING Rear Bar 2 Points
    DASTEK Unichip Type Q+
    DRAG RACE - BEST TIME ACHIEVEMENT :
    0-201m : 8,8 Second @Harapan Indah
    0-402m : 13,4 Second @Sentul
    UPGRADE PROJECT
    DARTON Iron Sleeve Block 82mm
    WISECO Forged Piston 82mm (Oversize 300) Compression Ratio 8,8:1 (Special Order)
    COMETIC MLS Head Gasket Bore 82mm & 0.030" Thick (Special Order)
    GARRETT TURBO GT3071R Dual Ball Bearing
    CUSTOM Stainless Intake Manifold (New Design)
    CUSTOM Stainless Turbo Exhaust Manifold (Tubular)
    BLOX RACING Air Filter Inlet 6 inch
    RC ENGINEERING Extra Injector 750cc (2pcs)
    done with the upgrade :
    Boost : 2,0 Bar
    BBM : Bensol
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    Jakarta, Indonesia
    2 Wks 14 Hrs 32 Mins 2 Secs
    adem juga liat mesin kinclong gini
    Quote Originally Posted by h&n View Post
    mau sekalian di kinclongin gini bos? hehehehe
    CP : Coki Siboro
    Jak-tIM
    1 Wk 1 Day 8 Hrs 5 Mins 30 Secs
    mblna ari king2 y bos???
    hehehe..
    Quote Originally Posted by rico moreno View Post
    hehehe..
    iya bos.. kenal ari ya bos?
    CP : Coki Siboro
    PUSING PALA BAPA'
    2 Wks 6 Days 17 Hrs 32 Mins 10 Secs
    wew..td ngliat nih..hehe...mantep dehh...btw portfolio civic ga ada bos? hihihi...
    Suzii Baleno sangat amat setandar bang ---> KLIK
    "Anda Puas, Kami Lemas..."
    Quote Originally Posted by Daniel Sirait View Post
    civic? civic yg mana si maksudnya?
    kalo yg item sih culun.. hohoho
    CP : Coki Siboro
    intercooler piping in progress..
    CP : Coki Siboro
    gunung putri - Princess's mountain
    5 Mths 3 Wks 4 Days 1 Hr 31 Mins 24 Secs
    itu nyang diatas foto intake manifold apa exhaust manipol siy yah??
    kok ngga ada bolongan injektornya kalo emang intake?
    mohon maaf nanya doank....maklum nyubie....
    bos coki...pahe kapan lagi neeh keluarnye ...heuheuheuheuheu.....
    Quote Originally Posted by F3174FO View Post
    itu intake manifold bos..
    kalo injector nya ada di depan nya.. lubang dan dudukannya nyatu di cylinder head.
    CP : Coki Siboro
  1. Dijual Mobil Toyota Corolla Altis 1.8 G MT 2002
    By firstmobil77 in forum Toyota
    Last Post: 30th November 2012, 13:16
  2. Toyota Corolla Altis G A/T 2002 Terawat
    By nolandddd in forum Toyota
    Last Post: 5th January 2012, 15:57
  3. WTS : Toyota Corolla Altis 2002
    By Woolong in forum Toyota
    Last Post: 21st October 2011, 19:22
  4. Toyota Corolla Altis 2002 Black A/T
    By thurob in forum Toyota
    Last Post: 12th October 2011, 09:04
  5. Toyota Corolla Altis G 2002
    By iklaninternet in forum Toyota
    Last Post: 18th August 2011, 22:38
