STRI Racing Gauges
Results 1 to 10 of 93
  • Short URL:  http://modifika.si/134772
    Phone: 08179845168 - Klender Jakarta
    4 Days 23 Hrs 46 Mins 8 Secs
    STRI Racing Gauges
    STRI Racing Gauges
    DSD = digital stepper drive
    Control and operates by Advance Digital Microprocessor
    Stepper Motor Driven (PM Type Gearless)
    1. Micro Stepping Movement high resolution and accurate readings
    2. Super high torque maintains the pointer accurately in toughest racing environments / prevents pointer from overshooting at high speed movements
    3. Fast response eliminates reading lag / real time display
    4. Gearless noiseless operation / more durable
    Special Note
    1. Unlike conventional gear type stepper motors which are noisy and respond in slower reaction speed.
    2. DSD stepper motors have been test proven in the toughest vibration environments which is a general characteristic of race tuned vehicles.
    The following standard features can be found in all DSD series:
    Open / Closing Ceremony in sequences
    270 Degree Sweep - Wide viewing angle for higher resolution reading
    Warning Setting User Preset (User preset warning values alarm by LED)
    Peak Recall - On demand, view highest value achieved
    Automatic Self Calibration - Each DSD meter is equipped with self calibration function that resets the pointer position after each installation. Or can be manually activated by shutting off the constant power source.
    Short-Circuit Auto Detect - If the sensor wire is incorrectly connected or the signal extension wire cut, the meter will detect the error and alarms the driver. (Backlighting will go off / pointer flashing)
    Dimmer (DSD-SLM II Only) - Reduce backlighting brightness for night time driving.
    Extreme Accuracy Racing Spec Sensors (All DSD are equipped with racing spec sensors for accurate reading)
    Gorgeous Titanium Color Finish Casing
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    4 Hrs 14 Mins 52 Secs
    bos warnanya cm merah???
    pm nett buat volt, vacum, oil temp donk?? sklian pasang ga??
    Quote Originally Posted by bobby1987 View Post
    Check PM-nya yaaaa...
    Thanks...
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    2 Mins 14 Secs
    pm nett buat volt, vacum, oil temp donk? sklian pasang ga? dapat dudukannya gak buat taro di dashboard..ada yang lampunya warna putih gak?
    surabaya, malang
    1 Hr 37 Mins 46 Secs
    bro pm in harga tacho yg rpm aja sekalian cara pasang d corolla dx ysaaa
    ntu ukuran brapa inchi
    makasihhhh.
    Quote Originally Posted by B171RC View Post
    Sorry yang saat ini ada baru Oil Temp... Volt dan Vacuum belom masukin sih...
    Dan lampu juga adanya yang amber...
    dapet lengkap dengan dudukan dan sensor2 + wiringnya...
    Harga barang (belom termasuk pemasangan) dikirimkan lwt PM yaaa..
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Quote Originally Posted by dodied aryo View Post
    makasihhhh.
    PM sent yaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Tokyo-Seoul PP via Pantura
    14 Hrs 25 Mins 19 Secs
    Barang2nya manteps bangets boss...
    Masih belom lengkap banget sih nih, pelan2 ngelengkapin stock-nya...
    Thanks ya bosss..
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    3 Wks 3 Days 15 Hrs 58 Mins 14 Secs
    bos buat boost meter ama oil press nya harganya brp masing2 ?? tlg pm... thx
Venom 300x250 Tekiro
  1. Replies: 9
    Last Post: 18th March 2013, 02:33
  2. STRI DSD SLMOil Temp Gauge 60mm.. 99%
    By 3VO7 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 24th September 2012, 22:52
  3. wts stri original starlet kotak 86 muluus 250rb
    By yama_holic in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 20th July 2011, 12:21
  4. jual stri isota
    By bagus77 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 29th July 2008, 21:57
