Hidden Camera Detector [alat pendeteksi kamera tersembunyi]
Page 1 of 17 12345 ... LastLast
Results 1 to 10 of 169
  • Short URL:  http://modifika.si/133397
    Spy Pen Camera, Spy Phone
    Giro Point
    1 Day 8 Hrs 18 Mins 24 Secs
    CALL : 081 22866 9696
    HARGA TERBARU LIHAT DI WEBSITE !!! Http://2mata.com
    CAMERA LENS DETECTOR : Rp 1.200.000
    MADE IN CHINA [ GARANSI 1 MINGGU ]
    dgn alat ini, anda bisa memantau apakah disekeliling anda ada camera tersembunyi
    LENS FINDER & WIRELESS CAMERA DETECTOR : Rp 2.500.000
    Fungsi :
    - Dgn menggunakan IR Laser Light, pantulan dari lensa kamera tersembunyi akan sangat mudah ditemukan
    - Alat ini akan mendeteksi adanya pancaran radio frequency disekitarnya : wireless camera, alat sadap suara, gps tracker, pancaran signal UHF, VHF dan GSM
    SPESIFIKASI:
    - IR LASER LIGHT DETECTING DISTANCE: UP TO 10M
    - ELECTRONIC WAVE DETECTING DISTANCE:
    50mw-200mw (30-50cm)
    300mw-600mw (100-200cm)
    800mw-1200mw (300-800cm)
    - POWER SUPPLY: AAA BATTERY X 2
    - DETECTING WAVE DISTANCE: 920nm
    - RECEIVING RANGE: 1MHz-6500MHz
    - OPTIC LENS: PROFESSIONAL IR LENS
    - MATERIAL: ABS
    - DIMENSION: 108mm x 48mm x 18mm
    - WEIGHT: 50g
    WIRELESS HIDDEN CAMERA SCANNER : Rp 7.000.000
    Fungsi :
    - Dgn menggunakan alat ini, keberadaan kamera2 tersembunyi disekitar anda bisa tau apa yang terekam dan hasil rekaman akan tampil di layar lcd scanner
    FEATURES:
    - Professional wireless 900MHz~2700MHz scanner.
    - Practical design for portable usage.
    - World wide compatible.
    - Audio sub carrier: 5.5MHz , 6.5MHz auto detect .
    - Build-in Auto/Manual switch scan feature.
    - 2.5” Color TFT LCD.
    - PAL?NTSC?CCIR?EIA system auto-select.
    - Backlight LCM display frequency band and function adjustment.
    - 32 set programmable of frequency memory.
    - Power Save mode for long-term usage.
    - Dual power supply design. (ALKALINE AA/1.5V/4PCS)
    - The best equipment for wireless-hidden-camera detector.
    - For use at hotel rooms, private bedrooms, meeting rooms, conference rooms, museums, galleries, theatres, concert halls, churches, temples, restaurants, classrooms, training centers, factories, banks, trains, buses etc.
    INSTALLATION AND OPERATION GUIDE
    - Dual power supply design: Please use 4pcs of ALKALINE AA battery or plug the attached power adaptor to supply the power. (Please notice, taking re-chargeable Ni-MH batteries will last longer working hours but it can't be charged by WCS-99X-II itself).
    - Install both of the professional antennas, H in the H and L in the L position accordingly.
    - Turn on the Power. WCS-99X-II will start to scan automatically.
    - If you receive the image after scanning, please press the Intelligent shuffle button down to lock up.
    - After lock up the image, turn the intelligent shuffle button up or down slightly to get clear image.
    - If using manual scan searching the signal, please shuffle the Intelligent shuffle button up and down.
    SPECIFICATIONS:
    Frequency band : 900MHz~2700MHz
    Scan Switcher : Auto / Manual
    Auto scan : In every 12 sec.
    Manual scan : Once: 1MHz & Shuffle: 10MHz/ sec
    Sensitivity : L (-20dBm ) ML (-30dBm) M (-40dBm)MH (-50dBm)H (-60dBm)
    Antenna : Dipole(SMA)
    TFT Display : Color / B&W Switch
    Receiver TV system : PAL&NTSC / CCIR&EIA
    Audio sub carrier : 5.5MHz , 6.5MHz auto detect
    Preset Frequency : 32 set
    Power consumption : MAX. 650mA
    Battery Working Time : 3~8Hrs(ALKALINE AA/1.5V/4PCS)
    Power Supply : INPUT:100~240VAC 50/60Hz 120mA / OUPUT:5VDC 1A
    Weight & Dimension of Body : 120(L)×74(W)×35(H)mm(240g)
    Package Weight & Dimension : 220(L)×120(W)×45(H)mm(640g)
    Product Package Detail : Scanner Receiver?RX Ant×2?Power Supply?Adaptor
    (3.5phone to RCA) ?Earpiece
    Effective Radius : 0-200m
    Jogja
    Giro Point
    2 Days 13 Hrs 26 Mins 51 Secs
    wah ngeri juga nih jualannya... bisa bobol rumah orang dong?
    Giro Point
    weekend telah tiba !!!
    mari kita lihat barang2 yang bisa dibeli
    ayo beli barang2 ku ... ^o^
    Giro Point
    Selamat Pagi !!!
    Selamat beraktifitas di hari senin ini
    semoga anda byk rezeki dan bisa beli barang2 gue ...
    ^o^
    Driver Seat
    Giro Point
    1 Day 10 Hrs 9 Mins 2 Secs
    wedew.. sangar-sangar Bos barang nya..
    cuman maklum gaptek, jadi ga gitu ngerti SP+ itu buat apa..
    N.E.V.E.R. regret anything that once made you S.M.I.L.E.
    Giro Point
    Selamat Pagi !!!
    di bulan baru september ini
    anda harus mengoleksi barang2 unik milik saya
    silahkan dibeli ^o^
    Giro Point
    Selamat Pagi !!!
    mari mari silahkan di lihat2 barang dagangan gue ...
    mariiiiiiiiiiiiiiiiiiiiiiii
    ^o^
    Giro Point
    Semangat pagi menuju masa depan yang cerah ... ^o^
    Kesusahan hari ini cukup untuk hari ini ... ^^
    Giro Point
    Selamat Pagi !!!
    semoga anda tetap sehat dan byk rezeki
    ^o^
    Giro Point
    Terima kasih atas pembelian nya ... ^o^
    Sering sering mampir ya ...
  1. WTS: Hidden Camera Detector [pendeteksi kamera tersembunyi]
    By talam in forum Barang Lain-lainnya
    Last Post: 30th October 2012, 22:26
  2. WTS: Spy Pen Camera, Kamera Pengintai MURAH !
    By talam in forum Camera & Aksesoris
    Last Post: 30th October 2012, 21:56
  3. Camera Hunter! Alat utk menyadap camera wireless spy cam
    By roeh1970 in forum Home Electronics
    Last Post: 18th January 2010, 03:08
  4. Replies: 0
    Last Post: 13th October 2008, 02:05
