4ch alpine mrp f250 muluuuuus n segel alpine indonesia....(sold,thanks modcom....)
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/132758
    Cool 4ch alpine mrp f250 muluuuuus n segel alpine indonesia....(sold,thanks modcom....)
    4ch alpine mrp f250 muluuuuus n segel alpine indonesia...........sold
    Technical Specification
    * RMS Power Range : 50-400 Watts
    * Number Of Channels: 4
    * Low Frequency response: 10 Hz
    * High Frequency Response: 50000 Hz
    * Built In Crossovers: Yes
    * Channel Separation: Yes
    Features
    * 4-channel car amplifier
    * Frequency Response: 10Hz - 50kHz (+0,-1dB)
    * 40 watts RMS x 4 at 4 ohms (50 watts RMS x 4 at 2 ohms)
    * 100 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
    * 2-, 3-, or 4-channel output
    * Variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
    * Tuned Bass EQ (0-12 dB bass boost at 50 Hz for channels 3 & 4)
    * Subsonic filter (24 dB at 15 Hz for channels 3 & 4)
    * Tri-way capable (Tri-Way Crossover required)
    * MOSFET power supply
    * CEA-2006 compliant
    * STAR Topology (minimizes internal noise and prevents ground interference)
    * Speaker- and preamp-level inputs
    * Preamp outputs
    * Gold-plated screw terminals
    * Fuse rating: 25A x 1
    * 10-gauge power and ground leads recommended — wiring and hardware not included with amplifier
    * 9-1/4"W x 2-3/8"H x 9-1/2"D
    * Input Impedance: 10k Ohm
    * Speaker Impedance: 4 or 2 ohm Bridged
    * Weight: 2.7 Kg.
    call
    081388575788
  2. clickbet88.com
    buat yang system mur mer sih bgs nih barangnya... up deh bos...
    he..he..,bos smooth tau aja...
    thanks ya bos.........
    up...................
    up................
    up................
    up............
    up.........
    6 Days 2 Hrs 59 Mins 50 Secs
    nettnya sekalian pasang brapa boss?
    cek pm ya bos,thanks.....
Datsun 300x250 GT Radial
  1. Replies: 5
    Last Post: 17th March 2010, 10:11
  2. Replies: 7
    Last Post: 17th March 2010, 10:06
  3. Replies: 1
    Last Post: 7th March 2010, 08:03
  4. Replies: 3
    Last Post: 22nd February 2010, 10:29
  5. Replies: 27
    Last Post: 21st February 2010, 19:33
