WTS Tweeter Scan Speak Illuminator <--- SOLD (Tnx-Modcom)
Results 1 to 10 of 84
  • Short URL:  http://modifika.si/132545
    North JKT
    1 Wk 4 Days 4 Hrs 38 Mins 48 Secs
    Sesuai judul, mau jual nih Tweeter Scan Speak Illuminator versi deep chamber...
    Kondisi 98% n boleh dibilang 99% tapi ga pake koma 99 karena udah kena setrum buat test doank...
    Price 4,3jt... turun Harga jadi 4jt... turun lagi 3.750 deh biar cepet buruan sikat..... BU nih... haha
    Minat Pls call : Hp 0812 9009 373
    Scan-Speak Illuminator D3004/6020-10 Tweeter
    * 1" soft dome
    * deep chamber
    * ring neodymium magnet
    * aluminum face plate and chamber
    * protective grill
    * 61.9mm (2.44") diameter flange with 55.4mm (2.18") depth
    The Illuminator tweeters continue on with the heritage of the renowned Revelator D29. The large-roll surround and textile dome diaphragm provide a flat frequency response to above 30KHz with outstanding off-axis dispersion.
    The face plates are die cast in aluminum for a beautiful look with maximum mechanical stability.
    D3004/602000 is optimized to offer small package sizes that can fit into tight spaces such as compact cabinets and automotive trim pieces.
    The back chamber is die cast in aluminum and designed with a contoured shape that functions as a heat sink in high power applications.
    Electrical Data
    Nominal Impedance Zn 4 ohm
    DC Resistance Re 3 ohm
    TS Parameters
    Resonance Frequency fs 600 Hz
    Force Factor Bl 2.8 Tm
    Effective Piston Area sd 8 cm^2
    Sensitivity 2.83V/1m 89.5 dB
    Power Handling
    Long-term Max Power IEC 18.3 90 W
    Voice Coil and Magnet Parameters
    Voice Coil Diameter 25 mm
    Tnx guys...
    North JKT
    Morning....
    PangkaL Paha
    2 Wks 5 Days 7 Hrs 45 Mins 39 Secs
    wakakakaka,, udh ga tahan ya bos,,
    1 Day 12 Hrs 18 Mins 7 Secs
    wah udah ada yang jual nih
    North JKT
    Quote Originally Posted by b2okane View Post
    Ga tahan apa nih??? Hehe...
    G masih pake tweeter ini nih so far g suka banget, yg dijual simpanan bang...
    hehe...
    North JKT
    bump up....
    North JKT
    bump up...
    PangkaL Paha
    Quote Originally Posted by Birdsongs View Post
    hehe...
    ga tahan mao beli mp Z signature wakakaka
    North JKT
    Busetttt MP Z, Doain g bang semoga bisa mampu beli MpZ... :p
    2 Hrs 16 Secs
    tweeter mantap.....
  1. FS : Mid +tweeter Scan speak Illuminator + pasif custom
    By jeam in forum Speaker - SubWoofer
    Last Post: 23rd September 2011, 11:04
  2. FS: Scan Speak Illuminator Tweeter D3004/602010
    By whatzzap in forum Speaker - SubWoofer
    Last Post: 1st May 2010, 15:21
  3. Replies: 13
    Last Post: 27th October 2009, 00:36
  4. Replies: 2
    Last Post: 1st August 2009, 06:48
