nakamichi ec-302 kondisi muluuuuuus dan lengkap bracket..(Sold,thanks modcom......)
Results 1 to 10 of 113
  • Short URL:  http://modifika.si/131957
    Cool nakamichi ec-302 kondisi muluuuuuus dan lengkap bracket..(Sold,thanks modcom......)
    nakamichi ec-302 kondisi muluuuuuus dan lengkap bracket...........sold
    Electronic Crossovers With Unsurpassed Sonic Performance And Flexibility
    The EC-204 and EC-302 are extremely versatile electronic crossovers that ensure the highest level of performance in a wide variety of multi-amp system configurations. Both feature state-of-the-art circuitry and are constructed of the finest materials and components. Examples of Nakamichi's attention to detail include fully balanced internal circuit configurations that permit phase inversion without additional stages. All level controls precede the active filters so that output impedance is unaffected by their settings. Bypass outputs provide unaltered throughput of the input signals, ensuring the simplest, highest quality signal path when the EC-204 and EC-302 are combined in more sophisticated multi-way systems. The bypass provision also makes it possible to adjust one part of the system without affecting subsequent parts of the chain.
    Both units incorporate DC-DC converter bipolar power supplies, which make it possible to use the most advanced, low-distortion, wide-dynamic-range circuitry. Both also feature floating ground and Nakamichi's Isolated Ground topology to maintain high signal purity and virtually eliminate the effects of external interference. 18dB/octave filters are used to minimize multi-source interference across driver ranges. And low-impedance outputs increase resistance to inductive noise pickup.
    The EC-204 is a 2-way, 4-channel network designed specifically for multi-amp systems using the SP-1010 or SP-80 subwoofer. It provides front and rear left/right inputs; front and rear left/right outputs; plus constant bass outputs. The front and rear bass-to-mid/high crossover frequencies can be independently adjusted in 10Hz increments from 10Hz to 310Hz.
    The EC-302 is a 3-way, 2-channel design that can be used in two types of multi-amp systems: woofer/midrange/tweeter or subwoofer/bass-midrange/tweeter. In the latter case two EC-302 units can be used to allow the head unit's front/rear fader to control the bass-midrange drivers and tweeters while the subwoofer operates in constant bass mode. A multiplier switch permits the low-mid crossover frequency to be selected from the 10Hz to 310Hz range in 10Hz increments or the 100Hz to 3.1kHz range in 100Hz increments. The mid-high crossover frequency can be adjusted from 500Hz to 15.5 kHz in 500Hz increments.
    call
    081388575788
  2. SbcAgent
    3 Hrs 3 Mins 17 Secs
    barang bagus neh, bantu up bro chris..
    thanks banget ya bos bayu.....
    uup............
    barang antikz... mulus nih broo... cocok buat analog lovers nih... up..uppp...
    wah,thanks banget ya bos smooth review n up nya...........
    up.................
    1 Day 4 Hrs 3 Mins 50 Secs
    bro 800 ribu boleh nggak? pm gw yah.....
    bantu up, bro chris... barangnya mulus abis nih, sesuai banget sama subjectnya... udah gitu barang bagus lagi, x-over aktif 3 way yang paling digandrungi sejak dulu... :smt003
    sorry belum bisa bos good cop....
    thanks ya bos bayu.....
  1. Replies: 11
    Last Post: 20th February 2010, 10:22
  2. Replies: 66
    Last Post: 7th January 2010, 06:14
  3. Replies: 26
    Last Post: 11th November 2009, 02:44
  4. Replies: 43
    Last Post: 9th July 2009, 03:57
  5. Replies: 6
    Last Post: 22nd June 2009, 05:39
