CLARION HXD-1 mulus,lengkap dc/dc converter......(sold,thanks modcom...)
Results 1 to 10 of 27
  • Short URL:  http://modifika.si/131955
    Cool CLARION HXD-1 mulus,lengkap dc/dc converter......(sold,thanks modcom...)
    CLARION HXD-1 mulus,lengkap dc/dc converter...............sold
    * Clarion high fidelity CD player without built-in amplifier
    * CeNET control of: 6-disc CD changer
    * Dual 24-bit D/A converter
    * HDCD disc playback
    * High-capacity DC/DC converter ( 15 V)
    * 4-volt / 4-channel RCA output (Max 9 V)
    * High purity OFC cable
    * 2-channel AUX input
    * High visibility blue-white VF display
    * Copper plated chassis
    * Optical input terminal for connection with DCZ625
    * Aluminium analogue rotary volume control
    * 18 FM, 6AM station presets
    * FM diversity
    TUNER SECTION
    Frequency bands
    FM: (MHz) 0.05MHz steps 87 to 108
    MW: (kHz) 9 kHz steps 531 to 1629
    LW: (kHz) 3 kHz steps
    FM usable sensitivity (dBf) 9
    FM 50 dB quieting sensitivity (dBf) 15
    FM alternate channel selectivity (dBf) 60
    FM stereo separation @1 kHz (dB) 35
    FM stereo freq. resp. @ 3 dB (Hz) 30 to 15,000
    CD SECTION
    Wow/Flutter (WRMS) Below measurable lmits
    S/N ratio (dB) 110
    Frequency response (Hz) 5 to 20,000
    Dynamic range (dB) 100
    Harmonic distortion (%) 0.005
    GENERAL
    Dimensions (W H D), mm 178 50 182
    Weight (kg) 1.6
    Power consumption: less than 1.1 A
    Speaker impedance 4Ω(4Ω to 8Ω allowable)
    Next-generation technology that spins the captivating crystallisation of sound
    call
    0813885757888
  2. Hokinusa
    up.................
    up..................
    2 Days 12 Hrs 32 Mins 31 Secs
    up.................
    Harganya bos
    Hh
    harga donk boz,g naksir neh & lokasi
    sorry bos,yang ini sudah booked...
    kalau sempat datang aja bos ke mgk lt 6 blok f1 no 6...
    g masih ada 2 unit lagi bro disana..
    thanks.....
    yg 2 unit,mulus ga bos & harga dong.
    yang 2 unit lebih mulus dari yang ini bos ancua...
    haragnya 2,8jt n 3jt bos...
    thanks....
    thanks....
    bisa di goyang pak harganya,
  1. [WTS] Clarion DRX 9255 Limited, Mulus, Lengkap.(SOLD)
    By nuevo_ciudad in forum Head Unit & Processor
    Last Post: 4th August 2010, 16:56
  2. Replies: 11
    Last Post: 14th February 2010, 17:20
  3. Replies: 26
    Last Post: 11th November 2009, 02:44
  4. CLARION HXD-1 mulus,lengkap dc/dc converter......(sold,thanks modcom...)
    Last Post: 17th September 2009, 06:07
  5. Replies: 18
    Last Post: 19th June 2009, 19:43
