Bikin Lampu Kristal jadi Kinclong...
Results 1 to 10 of 15
  • Short URL:  http://modifika.si/13158
    Malang
    6 Hrs 29 Mins 43 Secs
    mau nanya dong para master....
    bisa nggak ya lampu angel eyes yang depannya udah kusam dibikin kilap lagi??? kira2 brapa duit bos???
    trus klo lampu kotanya yang bulat (kaya lampunya audio yang kaya selang/ ring) itu mati bisa diganti / dibetulin ga ya??? klo yang ini brapa duit??
    di bandung ada yang tau nggak tempatnya dimana???
    thx bgt bos....
    1 Wk 16 Hrs 22 Mins 21 Secs
    maksudnya depannya tuh mikanya bro?? kalo mikanya bisa liat d majalah motor edisi 304
    Jkt
    3 Mths 3 Wks 1 Day 21 Hrs 3 Mins 59 Secs
    majalah motor edisi 304 yang depannnya gambar apa yah, bingung gw punya ilang semua hiks
    Malang
    Quote Originally Posted by haruka
    iya mikanya bos... ya ntar aku cari tau deh di majalah motor...
    thx bos atas infonya...
    Malang
    Quote Originally Posted by std aja de
    eh ktemu lagi ama si bos std aja de... :smt020
    eNZed
    8 Hrs 56 Mins 27 Secs
    gw dapet ini dr forum tetangga:
    (http://www.honda-tech.com/zerothread?id=1523524)
    Quote Originally Posted by honda-tech.com
    I got bored today, so I decided to clean up my headlights again. One is on its way to Virginia, the other is right here beside me.
    WHAT YOU WILL NEED:
    - 1500 grit wet sandpaper
    - 2000 grit wet sandpaper
    - some clean rags / towels
    - a bucket of water
    - a bottle of plastic polish (I went with Mother's Plastic Polish )
    - a lot of patience
    THE PROCESS:
    Step #1: Set the headlight(s) down on a secure platform, and under a towel.
    You really don't want them to move while you are sanding, especially if you're sanding the edges where the two parts of the headlight meet. The reason for the towel is because you are using wet sandpaper, so it does get a little messy.
    Step #2: Take a small piece of the 1500 grit wet sandpaper, dip it in a small bucket of water, shake it a tad to remove some water, then go to work with medium pressure. Re-wet the sandpaper when it starts to slip during your hand motions.
    I used a horizontal motion the entire time. I've seen people go up, and down, and diagonally, but I just decided to keep with the lines of the headlight. You will get this sort of look after a while. Don't be alarmed.
    Step #3: Wet the headlight down, and then dry completely.
    The headlight will be hazy, and cloudy. The benefit to doing this is the fact that you can see your blemishes completely. If there are still any imperfections, just simply sand away until they are gone.
    Step #4: Repeat Step #2, but with 2000 grit sandpaper.
    Step #5: Wet the headlight down, and then dry completely again.
    Step #6: Take a clean towel, and apply a bit of polish to it. Start making passes on the headlight itself. Repeat as you see fit.
    Trust me. This part is going to take a while if you don't have a buffer, or anything. The purpose of the polish is to fill in any minor scratches, and then leave the headlight looking clear as a crystal.
    Step #7: Using a clean piece of the towel, wipe down the headlight completely in order to remove any excess polish.
    Step #8: Step back, and enjoy your work.
    LAST WORDS: I may follow up with a coat of wax, or clearcoat just to help preserve their clearness. Now that the clearcoat is gone, the headlights will start to look hazy after two weeks, or so, depending on the weather. A coat of polish once a while will go a long way.
    If you any questions, or comments, feel free to share.
    susah2 gampang ternyata...
    Jkt
    Quote Originally Posted by complicated
    hehehe iya donk :smt003
    Chino,CA
    1 Mth 2 Days 9 Hrs 33 Mins 12 Secs
    lo kan bandar majalah
    heheh
    Jkt
    sonic_gaul sini
    Jkt
    Quote Originally Posted by sonic_gaul
    heheh
    ym lo ol donk
  1. Replies: 6
    Last Post: 28th November 2011, 16:05
  2. wta tempat custom lampu mobil jadi kristal??
    By Pisang Sehat in forum Diskusi Aksesoris
    Last Post: 3rd March 2010, 20:44
  3. Mau tanya yg bisa bikin lampu depan model kristal
    By xe_nia lovers in forum Diskusi Interior
    Last Post: 2nd October 2006, 13:49
  4. [ASK] bikin velg makin kinclong
    By ruudy in forum Diskusi Kaki-Kaki
    Last Post: 4th September 2006, 01:34
  5. dimana bisa bikin lampu depan kristal???
    By ineb in forum Diskusi Aksesoris
    Last Post: 7th October 2005, 09:14
