"TOP OF THE LINE" ScanSpeak R2904/7000 Ring Radiator (sold,thanks modcom....)
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/130597
    Cool "TOP OF THE LINE" ScanSpeak R2904/7000 Ring Radiator (sold,thanks modcom....)
    "TOP OF THE LINE" ScanSpeak R2904/7000-00 Ring Radiator, Silver plate face nexindo,muluuuuuus...sold
    price : USD 398/piece
    The Scan-speak R2904/7000 tweeter is the new flagship tweeter in the Scan-speak line. This tweeter incorporates many innovative design concepts.
    The first notable difference is the use of a phase plug. The dome is attached to the phase plug, so the radiating area is now concentrated around the voice coil. This offers more control and reduces distortion and loss that occur at the center of the dome on dome tweeters. The phase plug also acts as a wave guide, reducing high frequency cancellations. A specially designed venting system uses a needle to cut down on turbulence in the air cavity. Better dynamics are achieved by not using ferrofluid, voice coil cooling is performed by the venting system and conduction through copper rings. The new SD-2 neodymium magnet system improves transient response.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 94.5dB
    Free air resonance Fs 520 Hz
    DC resistance 3.0 ohm
    V.C. inductance 0.01 mH
    Power 12dB@Hz 150W@2.7K
    Effective cone area 5.6 cm2
    V.C. diameter 28 mm
    Lin. & max. excursion 0.2 / 1.6mm
    Force factor BL Product 2.8 Tm
    Moving mass incl. air 0.3 g
    Net weight 0.42 kg
    Outside diameter: 104mm
    Cut out: 70mm
    Depth: 30.9mm
    25.4mm = 1" = 2.54cm
    call
    081388575788
    JAKARTA
    3 Hrs 48 Mins 54 Secs
    nett brp bang chris ?
    2 Wks 4 Days 9 Hrs 12 Secs
    nah INI DIA, br kmrn diomongin hahahahahaha, cocok dah bos, harga bersahabat nih kynya
    Jakarta Pusat
    1 Wk 1 Day 23 Hrs 37 Mins 1 Sec
    wew.... kaya baru euy tampangnya ^^ bantuin up ah
    3 Hrs 16 Mins 23 Secs
    bantu up MR.GASOLINE...
    brightside dilayanin tuh, nanti kburu nangis hehe
    1 Day 4 Hrs 42 Mins 11 Secs
    wowww jualannya serem bgt nih bos satu ini
    mau nanya harganya tp kayanya ga sanggup beli nih
    bantu doa aja yah bos
    1 Wk 3 Days 15 Hrs 55 Mins 7 Secs
    Barang manstap.... udah ada yang incer kan, udah ditawarin belum?
    wah,pas liat udah banyak bos2 modcom disini yach....
    om afung,tar g bel yach...
    thanks bos nakamichi,bos kawa,bos nanami,bos edwin...
    tar coba g contact d bos edwin...
    bos besar jemmy,jangan belgi lah bos,tar bener2 ga sanggup gimana jadinya bos besar?he..he..he...
    JAKARTA
    bos besar jemmy,jangan eblgi lah bos,tar bener2 ga sanggup gimana jadinya bos besar?he..he..he...
    belgi mulu tar g demen gila beneran , hahaha......
NGK Busi GT Radial
  1. Replies: 0
    Last Post: 4th May 2012, 15:13
  2. Replies: 54
    Last Post: 28th April 2010, 09:33
  3. Replies: 22
    Last Post: 4th September 2009, 07:11
  4. hi-end scanspeak R2904/7000 ring radiator (sold,thanks modcom....)
    Last Post: 14th July 2009, 05:09
