Buat yang Kebanyakan Duit
Results 1 to 10 of 25
  • Short URL:  http://modifika.si/129917
    4 Hrs 19 Mins 42 Secs
    Anda merasa Audio anda sudah mahal ?
    Anda merasa duit anda nggak ada serinya
    Lihat ini
    http://www.audiojunkies.com/blog/839...ogue-acoustics
    http://www.audiojunkies.com/blog/268...the-world-259k
    hue he he
    Kabuurr
  2. clickbet88.com
    Kalau duitnya kurang dan mau bikin sendiri, eceran
    Powernya
    Rockford Fosgate T15kW
    Rated Power 500 W x 4 @ 4 Ohms RMS
    1000 W x 4 @ 2 Ohms RMS
    2000 W x 4 @ 1 Ohm RMS
    3750 W x 4 @ 0.5 Ohm RMS
    2000 W x 2 @ 4 Ohms bridged RMS
    4000 W x 2 @ 2 Ohms bridged RMS
    7500 W x 2 @ 1 Ohm bridged RMS
    Total Power 15000 Watts RMS
    Bridgeable Yes
    Crossover Controls High-Pass (HP): 32-300Hz 12db/Octave Butterworth
    Low-Pass (LP): 32-300Hz 12db/Octave Butterworth
    Infrasonic filter: -6db @ 20Hz 24db/Octave
    Signal Input Low level: 2 RCA pair
    Input switch: 2/4 ch.
    Power Wire Gauge 1/0 AWG
    Speaker Output Connector Block
    Speaker Wire Gauge 4 AWG to 12 AWG
    Heat Sink Type Extruded aluminum
    Cooling Fan Cooled
    Circuit Topology Class Class A/B with Hybrid Technology (HT)
    Frequency Response 10Hz to 40kHz +/- 0.5 dB
    Dimensions 37.5 x 22 x 10 (in) 95.3 x 55.9 x 25.4 (cm)
    Weight 180 Lbs. 81.8 Kg.
    atau
    Critical MASS UL-A5
    The Critical MASS UL-A5 is the most powerful amplifier of it's kind! Having 5 channels in total, with 4 full range channels @ 200W x 4 @ 2 Ohms + a single monoblock @ 2500W at .75 Ohms. Delivering up to 2500W at .75 Ohms to one of out UL-12's or 2000W to four SS subwoofers at .5 Ohms.
    SPECIFICATIONS AND FEATURES:
    - Monoblock digital subwoofer amplifier
    - Remote bass boost at 60Hz control: 0 - 18 dB
    - Balanced low input and high input
    - Line out ( by pass )
    - Variable subsonic filter 15 ~ 30 Hz, 18dB/OCT
    - Variable low pass filter 40 ~ 230Hz, 24dB/OCT
    - Variable bass boost at 60Hz control: 0 - 18dB
    - Protection circuit for thermal, short circuit and reverse polarity connection of battery.
    atau
    http://cgi.ebay.com/CRITICAL-MASS-UL...#ht_2773wt_754
    Kalau duitnya kurang beli yang ini aja
    http://cgi.ebay.com/STEG-Master-Stro...4#ht_500wt_924
    Processor
    http://cgi.ebay.com/Alpine-PXA-H900-...4#ht_546wt_903
    Capek ah. percuma nggak mungkin beli.
    sayang duitnya. he he he
    Buat Yang super tajir.
    Jangan lupa di rumah juga Buat Audio yang bagus juga
    Speakernya pakai
    Transmission Audio Ultimate
    http://www.transmissionaudio.com/
    Murah Bos, Cuma 2 juta.
    kalau duitnya kurang
    Kharma Grand Enigma
    http://www.kharma.com/
    Cukup 1 juta saja
    Powernya
    Ultrasound Otello Stereo amp
    http://www.ultrasound-hifi.com/Us_wh_1/main_frame_en.html
    Cukup 600 Ribu bos
    Speakernya pakai
    Kharma Grand Enigma
    Cukup 1 juta saja
    Powernya
    Cukup 600 Ribu bos
    plat R
    2 Days 7 Hrs 1 Min 47 Secs
    cek du;u ya gan....
    Quote Originally Posted by thomas_platinum View Post
    cek du;u ya gan....
    Silahkan bos. dilihat lihat dulu.
    kalau cocok silahkan di beli.
    Maaf harga nett ya. Jangan nawar ke saya.
    Oh iya kalau mau beli Sub woofernya
    http://cgi.ebay.com/Critical-Mass-UL...4#ht_607wt_958
    Tar kalau masih sisa duitnya jangan lupa ber amal ya bos
    Jakarta - Surabaya
    7 Hrs 40 Mins 53 Secs
    wih gila2 nich..mahal abis
  1. Replies: 66
    Last Post: 24th August 2012, 06:23
  2. Replies: 0
    Last Post: 3rd May 2010, 22:31
  3. TIPS &trik buat ngumpulin duit buat modip!!
    By blinkz in forum Automotive
    Last Post: 22nd April 2008, 09:36
  4. sisa duit 10jt lg buat audie nie...
    By Seth in forum Diskusi Instalasi
    Last Post: 20th November 2006, 15:47
