clarion hxd1 kond antik,muluuuuuus,lengkap,cd changer dcz-625.(sold,thanks modcom..)
  • Short URL:  http://modifika.si/129613
    Cool clarion hxd1 kond antik,muluuuuuus,lengkap,cd changer dcz-625.(sold,thanks modcom..)
    clarion hxd1 kondisi antik,muluuuuuus,lengkap dus,buku plus cd changer dcz-625...........sold
    HXD-1 PROFILE :
    * Clarion high fidelity CD player without built-in amplifier
    * CeNET control of: 6-disc CD changer
    * Dual 24-bit D/A converter
    * HDCD disc playback
    * High-capacity DC/DC converter ( 15 V)
    * 4-volt / 4-channel RCA output (Max 9 V)
    * High purity OFC cable
    * 2-channel AUX input
    * High visibility blue-white VF display
    * Copper plated chassis
    * Optical input terminal for connection with DCZ625
    * Aluminium analogue rotary volume control
    * 18 FM, 6AM station presets
    * FM diversity
    Next-generation technology that spins the captivating crystallisation of sound
    HXD-1 SPECIFICATION:
    TUNER SECTION
    Frequency bands
    FM: (MHz) 0.05MHz steps 87 to 108
    MW: (kHz) 9 kHz steps 531 to 1629
    LW: (kHz) 3 kHz steps
    FM usable sensitivity (dBf) 9
    FM 50 dB quieting sensitivity (dBf) 15
    FM alternate channel selectivity (dBf) 60
    FM stereo separation @1 kHz (dB) 35
    FM stereo freq. resp. @ 3 dB (Hz) 30 to 15,000
    CD SECTION
    Wow/Flutter (WRMS) Below measurable lmits
    S/N ratio (dB) 110
    Frequency response (Hz) 5 to 20,000
    Dynamic range (dB) 100
    Harmonic distortion (%) 0.005
    GENERAL
    Dimensions (W H D), mm 178 50 182
    Weight (kg) 1.6
    Power consumption: less than 1.1 A
    Speaker impedance 4Ω(4Ω to 8Ω allowable)
    DCZ-625 PROFILE :
    * 6-disc magazine
    * CD-R/RW ready
    * 8 Oversampling digital filter
    * Horizontal or vertical mounting capability
    * Fibre optical digital output
    DCZ-625 SPECIFICATION :
    Wow/Flutter (WRMS) Below measurable limit
    S/N Ratio (dB) 105
    Dynamic Range (dB) 95
    Frequency Response (Hz) 5 to 20,000
    Harmonic Distortion (%) 0.01
    Dimensions (W H D) 225 x 63 x 167
    call
    081388575788
  2. Hokinusa
    up,..........
    up..............
    up.............
  1. ***FS:CLARION HXD1+CHANGER***
    By ansugi_78 in forum Head Unit & Processor
    Last Post: 20th July 2011, 07:41
  2. Replies: 26
    Last Post: 11th November 2009, 02:44
  3. CLARION HXD1 kondisi muluuus n segel.......(sold,thanks modcom...)
    Last Post: 27th June 2009, 00:44
  4. Replies: 18
    Last Post: 19th June 2009, 19:43
