SCAN-SPEAK ILLUMINATOR D3004/602010 deep chamber garansi nexindo(sold,thanks modcom.)
  • Short URL:  http://modifika.si/129597
    Cool SCAN-SPEAK ILLUMINATOR D3004/602010 deep chamber garansi nexindo(sold,thanks modcom.)
    SCAN-SPEAK ILLUMINATOR D3004/602010 deep chamber lkp dus, baru hampir break in,nexindo 06-09...........sold
    Scan-Speak Illuminator D3004/6020-10 Tweeter
    * 1" soft dome
    * deep chamber
    * ring neodymium magnet
    * aluminum face plate and chamber
    * protective grill
    * 61.9mm (2.44") diameter flange with 55.4mm (2.18") depth
    The Illuminator tweeters continue on with the heritage of the renowned Revelator D29. The large-roll surround and textile dome diaphragm provide a flat frequency response to above 30KHz with outstanding off-axis dispersion.
    The face plates are die cast in aluminum for a beautiful look with maximum mechanical stability.
    D3004/602000 is optimized to offer small package sizes that can fit into tight spaces such as compact cabinets and automotive trim pieces.
    The back chamber is die cast in aluminum and designed with a contoured shape that functions as a heat sink in high power applications.
    Electrical Data
    Nominal Impedance Zn 4 ohm
    DC Resistance Re 3 ohm
    TS Parameters
    Resonance Frequency fs 600 Hz
    Force Factor Bl 2.8 Tm
    Effective Piston Area sd 8 cm^2
    Sensitivity 2.83V/1m 89.5 dB
    Power Handling
    Long-term Max Power IEC 18.3 90 W
    Voice Coil and Magnet Parameters
    Voice Coil Diameter 25 mm
    call
    081388575788
    Wah, langsung banyak ni brang barunya.. Ini model barunya scanspeak ya bro?
    iya bos rinal,illuminator seri barunya scan-speak bos...
  1. WTS: Scan Speak Illuminator D3004/6020-00 mulus bgt
    By whatzzap in forum Speaker - SubWoofer
    Last Post: 12th January 2011, 05:59
  2. FS: Scan Speak Illuminator Tweeter D3004/602010
    Last Post: 1st May 2010, 15:21
  3. Replies: 13
    Last Post: 27th October 2009, 00:36
  4. WTS Tweeter Scan Speak Illuminator <--- SOLD (Tnx-Modcom)
    By Birdsongs in forum Speaker - SubWoofer
    Last Post: 5th October 2009, 13:15
  5. Replies: 0
    Last Post: 11th June 2009, 05:56
