[WTS] Sub JL W3V3
  • Short URL:  http://modifika.si/129530
    Makassar, Jakarta
    4 Days 17 Hrs 36 Mins 43 Secs
    [WTS] Sub JL W3V3
    jual Subwoofer JL Audio type 12w3v2 Kondisi 98%
    kenapa gw bilang 98% karena baru dipake 2 minggu, trus ganti sub yg lebih galak.
    Spesifikasi :
    ▪ Free Air Resonance (Fs): 24.3 Hz
    ▪ Electrical “Q” (Qes): 0.475
    ▪ Mechanical “Q” (Qms): 8.483
    ▪ Total Speaker “Q” (Qts): 0.449
    ▪ Equivalent Compliance (Vas): 3.65 cu. ft. / 103.4 liters
    ▪ One-Way, Linear Excursion (Xmax) : 0.513 in. / 13.0 mm
    ▪ Reference Efficiency (no): 0.300%
    ▪ Efficiency (1W/1m) : 86.7 dB SPL
    ▪ Effective Piston Area (Sd): 81.5 sq. in. / 0.0526 sq. m.
    ▪ DC Resistance (Re): 3.82 ohm
    ▪ Nominal Impedance (Znom): Dual 2 ohm
    ▪ Thermal Power Handling (Pt): 300W
    ▪ Driver Displacement: 0.07 cu. ft. / 1.98 liters
    ▪ Net Weight: 5.0 kg
    lengkap dus dan spek, ada stiker SAS juga.
    asli lah yaw.
    jual @1,6jt nego tipis.
    ada sepasang
    thanks,
    yg minat bisa PM or SMS
    08159152647
    Jakarta Timur
    4 Wks 1 Day 7 Hrs 25 Mins 10 Secs
    Picnya donk bos...
  1. 10" W3v3
    By WI288 in forum Speaker - SubWoofer
    Last Post: 28th October 2010, 23:45
  2. jbl GTO 1214 Vs JL W3V3
    By kingkong in forum Diskusi Subwoofer
    Last Post: 8th May 2010, 22:57
  3. ask harga JL w3v3 12 inch
    By shikimori in forum Diskusi Subwoofer
    Last Post: 7th November 2008, 20:38
  4. p2 dan w3v3.. bagusan mana?
    By dhana/8796LE in forum Diskusi Subwoofer
    Last Post: 11th March 2008, 22:46
  5. P1 vs W3V2 vs W3V3 vs P2
    By leonardo_tan in forum Diskusi Subwoofer
    Last Post: 9th September 2006, 04:22
